Author Topic: Cherry Plate-mounted Stabilizers  (Read 3967 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« on: Sun, 01 January 2012, 15:23:17 »
For plate-mounted Costar stabilizers, you can install and remove them right from the plate.  I only have Cherry's PCB-mounted stabilizers so I don't know what Cherry's plate-mounted stabilizers look like.
Is it the same with Cherry's plate-mounted stabilizers?
Thanks.
EDIT:
Hum, I think I found my answer here:
Looks like it is sandwiched between the plate and PCB, so you can't really remove Cherry's stabilizers without de-soldering every switch and separate the plate and the PCB first.
« Last Edit: Sun, 01 January 2012, 15:34:09 by litster »
Offline Dox
« Reply #1 on: Sun, 01 January 2012, 15:38:17 »
You just need to remove a single switch to remove the stabilizer with plate mounted cherry stabilizers.
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
Offline litster
« Reply #2 on: Sun, 01 January 2012, 15:43:37 »
Oh, cool!  That is much better.  Then I can use the same Phantom prototype to test with both Cherry and Costar stabilzers.  Thanks.
Offline litster
Offline Dox
« Reply #4 on: Sun, 01 January 2012, 16:31:24 »
Did ripster build a keyboard by himself....
I did swap the stabilizers multiple times just by removing the stabilized switch.
Offline litster
« Reply #5 on: Sun, 01 January 2012, 16:38:17 »
Plate-mounted or PCB-mounted?
Offline Dox
« Reply #6 on: Sun, 01 January 2012, 16:38:56 »
Plate mounted
Offline litster
« Reply #7 on: Sun, 01 January 2012, 16:45:53 »
Got it.  Thanks.
