Author Topic: "Filco" logo removal  (Read 7603 times)
Offline WhiteFireDragon
    • youtube
« on: Wed, 04 January 2012, 01:42:29 »
i'm changing the pure black "Filco" logo from my TKL ninja to the gen1 silver logo. how do i take off the logo to replace it? do i pop it off from inside out, or is it glued on the casing and i have to pry it off somehow? this is my first filco, so i've never opened one up before. i just want to make sure before i start.
EDIT: figured it out on both TKL and full size 104. description and pics on the 2nd page:
http://geekhack.org/showthread.php?25688-quot-Filco-quot-logo-removal&p=505965&viewfull=1#post505965
« Last Edit: Thu, 02 February 2012, 01:31:05 by WhiteFireDragon »
Offline whiskerBox
« Reply #1 on: Wed, 04 January 2012, 01:44:19 »
curious about this as well
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Human
« Reply #2 on: Wed, 04 January 2012, 02:46:02 »
For full size board, removing/poking out the pin/stem of the logo from the inside.
For TKL, not sure.
    • youtube
« Reply #3 on: Wed, 04 January 2012, 03:59:14 »
full size 104 logo looks the same as the TKL 87. it looks like the only way to find out is to bust the warranty sticker first :(
Offline NorrisB
« Reply #4 on: Wed, 04 January 2012, 13:00:17 »
how did you get that silver logo
    • youtube
« Reply #5 on: Wed, 04 January 2012, 16:54:21 »
Quote from: NorrisB;483237
a trade. i wish i can buy all the different kinds though
Offline Reptile
« Reply #6 on: Wed, 04 January 2012, 16:57:11 »
Has anyone ever changed the stock logo's? like shade them a different color or anything?
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline whiskerBox
« Reply #7 on: Wed, 04 January 2012, 16:59:42 »
I had original thought about casting some clear ones when I was making the my clear filco case but I ran out of clear acrylic :( next time
Offline Reptile
« Reply #8 on: Wed, 04 January 2012, 17:03:27 »
Quote from: whiskerBox;483390
Is it done? I don't think I have seen that before sounds cool.
But my idea would be like the yellow filco:
But not yellow! I think a red tinted one on a filco with reds would be the sex
Offline whiskerBox
« Reply #9 on: Wed, 04 January 2012, 17:11:06 »
Quote from: Reptile;483397
Oh yeah it is done you can see pics of my failure in the MYOC thread lol.
Offline Reptile
« Reply #10 on: Wed, 04 January 2012, 22:30:45 »
What kind of metal is it?
Offline Saviant
« Reply #11 on: Thu, 05 January 2012, 03:28:18 »
I pulled apart my Filco Multicam TKL and it appears that the Filco logo is glued in, there was no pin to push it out or hole either. Hope this helps
    • youtube
« Reply #12 on: Thu, 05 January 2012, 04:25:48 »
Quote from: Saviant;483671
thank you, best post of the thread. it looks like TKL is different than full size 104 :frown:. your TKL was a majestouch-2 right? i wonder why the 104 logo is removable while the 87's version is not.
« Last Edit: Thu, 05 January 2012, 04:29:50 by WhiteFireDragon »
Offline Saviant
« Reply #13 on: Thu, 05 January 2012, 04:39:06 »
On the box it is listed as Majestouch 2 Camoflage Tenkeyless
    • youtube
« Reply #14 on: Thu, 05 January 2012, 05:10:07 »
Quote from: hotgirl2012;483704
good topic . up for any one................................
are you a bot? lol no one serious about a geekhack account will name themselves "hotgirl". now i'm just waiting for the ban hammer
    • youtube
« Reply #15 on: Wed, 01 February 2012, 22:54:56 »
If you guys are still wondering, both full size and TKL logos are put on by sticky stuff in the back of the logos. They're not screwed on or punched on or anything. I took them out by carefully taking an exacto blade and gently pry up one side first, then just took my finger and lifted the rest up. The sticky stuff was still on the back, so I just swapped and pressed the logo back into the carved out hole.
Full size 104 case with logo pulled out. Also notice there are two little holes in that slot, which you can poke out the logo from the inside out if you took the case apart.
TKL case with logo pulled out. Notice the two holes to push out the logo is not present in the TKL case. Only way to take off the logo is use a sharp blade and carefully pry out the logo.
There are the two logo I'm about to swap. There's sticky stuff on the back, so that's how they stick to my fingers.
I replaced the gunmetal colored logo with a pure black colored logo onto this full size case.
Offline laffindude
« Reply #16 on: Wed, 01 February 2012, 23:02:36 »
!!!!!! I <3 you. I was wondering how to remove the logo on tenkeyless the other day when I decided I want to paint my case to IBM industrial grey.
Offline naranja
« Reply #17 on: Wed, 01 February 2012, 23:06:40 »
Quote from: laffindude;505972
How are you going to paint it?
    • youtube
« Reply #18 on: Wed, 01 February 2012, 23:11:57 »
!!!!!! I <3 you.
Who doesn't? lol jk.
You're welcome :)
Offline laffindude
« Reply #19 on: Wed, 01 February 2012, 23:53:57 »
Quote from: naranja;505981
I am just going to use a plastic safe primer then rattle can it. If it doesn't look good. um well. There is that Vortex aluminum case coming >____>
Some other ideas: Pearl white the whole case with the logo, color the top of the Filco logo red. Red on red and polish the logo to a shine. Gun Metal, original MJ1 logo.
Edit: I was browsing and ran into some 3m carbon vinyls. I think I am gonna try that first ;o Carbon with a polished silver logo. sounds good in theory.
« Last Edit: Thu, 02 February 2012, 03:11:49 by laffindude »
Offline captain
« Reply #20 on: Mon, 06 February 2012, 10:39:54 »
Quote from: WhiteFireDragon;483714
Interesting....  What just happened there?
Oh, and thank you for the logo removal tutorial!  I was thinking of removing my Filco logos and filling in the holes with metal filler, or something like that.
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
