Author Topic: I have made a silly switch mod, I think.  (Read 3117 times)
Offline Kibibit
« on: Mon, 09 January 2012, 16:06:17 »
To pass the time, as for the next few weeks I won't have cash to spare for parts as I save up for ANOTHER type of keyboard (Musical), I decided to **** around with the leftover parts from disassembling all of the clears from a board I plan to mod out with ergo clears. one of my curious ideas was to see if a switch would still work if I jammed two clear springs behind one blue stem (leftover from me repairing my Das), and lo and behold, it works. I attempted the ripometer/nickel stacking nonsense and for the moment, I seem to be out of nickels.
At the moment, I plan to make the switch my capslock switch, making it difficult to accidentally hit, but still technically usable. It would be highly useless outside of any keys you almost never want to hit, but for things like capslock for me, It might just work like a charm. I'll update more once I finish the board and see how everything actually runs.
Offline keyboardlover
« Reply #1 on: Mon, 09 January 2012, 16:08:57 »
Welcome to GeekHack! I'd recommend using a stronger spring (like from a black switch) rather than what you're doing. That two spring thing may not hold up too well over time.
Offline Kibibit
« Reply #2 on: Mon, 09 January 2012, 16:14:53 »
Oh, I'm well aware,a heavier spring would be the more reasonable idea, but should it work. I love the amount of force it takes to activate the switch, which is well above a black spring. Like I said, I'll most likely give it a bit of time and testing to see how it works, especially with the possible problems stemming from the sheer pressure of the springs, but it doesn't feel like anything is wrong so far.
Offline False_Dmitry_II
« Reply #3 on: Mon, 09 January 2012, 16:16:13 »
What? Clear springs are stronger than black springs. He just tossed two of them into it.
« Reply #4 on: Mon, 09 January 2012, 16:45:13 »
Quote from: False_Dmitry_II;486847
Good point, I forgot about that. I guess there isn't really a stronger cherry spring I know of then.
Offline Kibibit
« Reply #5 on: Mon, 09 January 2012, 16:56:16 »
Quote from: keyboardlover;486863
Except for TWO cherry springs. :D
Offline whiskerBox
« Reply #6 on: Mon, 09 January 2012, 16:58:52 »
Quote from: Kibibit;486831
[ Attachment Invalid Or Does Not Exist ] 37119[/ATTACH]
use any coin and math FTW!
« Last Edit: Mon, 09 January 2012, 17:01:27 by whiskerBox »
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline whiskerBox
« Reply #7 on: Tue, 10 January 2012, 23:35:49 »
Quote from: ripster;487336
I hate the $1 coins.  I accidentally overtipped by pouring 4 of them into a coffee joint tip jar.
Yes uhh i have done that as well and you can't reach back in and get it even though its quite obvious that the barista skills required to pour my black coffee doesn't warrant a 3$ tip but oh well
Offline squarebox
  • In Omnia Paratus
« Reply #8 on: Tue, 10 January 2012, 23:52:44 »
People seem to forget about the gray switches...
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline JustCallMeCrash
  • ErgoDox Lover
« Reply #9 on: Wed, 11 January 2012, 10:06:39 »
Quote from: squarebox;487771
To my knowledge, Gray switches use the Clear springs and are, in fact, just Clear switches with an identically shaped Gray stem.
A rose by any other name, and all that.
ErgoDoxen 6 total: Cherry MX Browns, Cherry MX Clears, NovelKeys Box Royal, 80g Gateron Yellows, NovelKeys Pale Blues, NovelKeys Box Navy.
Preonic 2 total: OG Gateron Yellows (GMK silencer clips), TBD (unassembled v2).
XD-75 (mixed Gateron Yellows, MX Blacks, MX Clears on layer toggles).
Das S Professional (was MX Blues, now Ghetto Reds).
G80-11900.
ML-4400 (2x) Cherry MY boards.
Offline flyball
« Reply #10 on: Wed, 11 January 2012, 10:10:47 »
Quote from: JustCallMeCrash;487973
nope
[SIGPIC][/SIGPIC]
Offline erw
« Reply #11 on: Wed, 11 January 2012, 10:33:38 »
Why not use your caps lock key for something useful? Like backspace or control. Or as a layer switcher so you can have arrow keys and what not in the letter block.
Kinesis Advantage LF (MX Red), Kinesis Advantage (MX Brown), Ergodox (MX Red), Colemak
Offline Kibibit
« Reply #12 on: Wed, 11 January 2012, 11:11:54 »
Because games occasionally use the key, and the keyboard is going to be mostly used at Lan centers and SC2 events. Anything I can't hard mod in is essentially useless. The Das generally sits as the main Keyboard on my PC. Besides, I have no plans to NEVER use it, just rarely, and it's somewhat annoying to accidentally hit it. Making it Backspace doesn't actually make it less annoying.
EDIT: Also, for a little info, all coin tests have put it in the ballpark of 125g. It's pretty damn hefty, but still usable.
Offline Kibibit
« Reply #13 on: Wed, 11 January 2012, 11:32:57 »
Scratch the note I have here, I thought it wasn't bottoming out due to the springs, but it indeed was, I just wasn't mashing it hard enough to bottom out.
