Author Topic: Overall Keycap request for Cherry Blacks  (Read 6392 times)
Offline Inf3rn0_44
« on: Sun, 15 January 2012, 11:35:05 »
Hopefully am in the process of getting my first mechanical board :D Yay :) Its an Access AKC090 and I wanted to try its layout since I did enjoy they type-matrix 2030 and I don't have all the cash to drop onto a truly ergo just yet! That or the Noopoo Choc Mini. Anyway I wanted to know where I can get the blank solid keycaps. My budget is low and I would prefer if possible that they have a rounder edge to the edges of the caps. Not severely rounded, just so that it feels nicer to the touch.
Post what you find, I am open to ideas. :)
Also is there anything to eliminate keycap wobble and acoustics of key presses?
Thank You GH :)
|IMO 1.0 Frankenmouse WMO Internals |
|Access-IS AKC090 Ghetto Reds w/ O-Rings |
Offline rhizo
« Reply #1 on: Sun, 15 January 2012, 12:25:16 »
wasdkeyboards sell blank keycaps for around 30-35$ a set you should have a look :)
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #2 on: Sun, 15 January 2012, 12:56:15 »
If you look around the groupbuy and classified there are people selling O-rings (rubber rings) that can help you reduce the noise of bottoming out.
Fight For Freedom. Stand with Hong Kongers
« Reply #3 on: Sun, 15 January 2012, 13:21:40 »
Quote from: Inf3rn0_44;491068
Thank You GH :)
Filco/WASD has the "oem" keycap sizing, which is a bit taller than SP/cherry. Some say that the shorter SP/cherry sizes "wobble" a bit less, which makes sense. An far as acoustics, I would recommend o-rings.
Des the access come with a flat profile? Do you want a sculpted profile? I think of the sets I have, the SP PBT keys are the "roundest" on the edge, but it's pretty close to my WASD. They also have a lot less area on the top of the key than unicomp/WASD have. The keys on my unicomp (that won't fit on your access keyboard) have a more acute angle than WYSE/SP, but it looks like the radius of curvature for them is a little bigger. SP has the most obtuse angle. The SP spacebar is really nice, but only if mounted backwards. Otherwise, it's really sharp!
Offline Inf3rn0_44
« Reply #4 on: Sat, 28 January 2012, 10:20:39 »
Yeah, I have ordered O-Rings. Now I am thinking about ordering either PBT keycaps or some POM Jelly keycaps. Whats the better pick?
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #5 on: Sat, 28 January 2012, 13:12:39 »
Quote from: Inf3rn0_44;501505
I Got some Jelly POM on my Choc Mini
[ Attachment Invalid Or Does Not Exist ] 38862[/ATTACH]
I don't think any of the jelly keycaps look great (got them from ebay) and they look rather cheap. I'm having buyers regret atm ><. But I'll see if it'll look better after i get nyancaps in. But that's just my 2 cents.
Offline Ascaii
« Reply #6 on: Sat, 28 January 2012, 13:38:11 »
just a quick FYI...board and extra caps sent yesterday.
