Author Topic: Complaints about MX Brown  (Read 2618 times)
Offline theOwlol
« on: Thu, 19 January 2012, 16:15:37 »
Hi!,
I own an Ducky Shining with MX Browns, my friend keep complaining on Skype, about the noise.
So I thought I would buy an MX blue Board to shut him up ( thinking about noopoo choc mini )
Anyone have similar story's and how did you "solve" it?
Also if anyone have any other suggestions about the board, I wont mind.
Offline flyball
« Reply #1 on: Thu, 19 January 2012, 16:19:49 »
complaining about what
[SIGPIC][/SIGPIC]
Offline RiGS
« Reply #2 on: Thu, 19 January 2012, 16:21:05 »
probably about the noise
Offline sordna
« Reply #3 on: Thu, 19 January 2012, 16:25:16 »
If so, then the solution is not a different keyboard/switch, but rather o-rings.
Offline theOwlol
« Reply #4 on: Thu, 19 January 2012, 16:27:22 »
yes, it was the noise, gogo edit power...
Offline HeavyArms
  • "Lit"
« Reply #5 on: Thu, 19 January 2012, 16:30:50 »
MX Blacks are quieter, Blues are loud as hell, Browns are in between, speaking from experience.
Head in the clouds.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Thu, 19 January 2012, 16:35:56 »
Buying him blues would make it worst if you're worried about noise. BTW I have o-ring installed on my browns are they are pretty darn quiet.
Here are some examples of boards with and without the o-ring mod.
[video=youtube;lFkl1Vet1eU]http://www.youtube.com/watch?feature=player_embedded&v=lFkl1Vet1eU[/video]
Offline sordna
« Reply #7 on: Thu, 19 January 2012, 16:37:02 »
o-rings will quiet blacks and browns to the same very low noise level. OP check this out:
[video=youtube;lFkl1Vet1eU]http://www.youtube.com/watch?v=lFkl1Vet1eU[/video]
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Thu, 19 January 2012, 16:39:59 »
Quote from: sordna;494333
snip
Well this is embarrassing
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Thu, 19 January 2012, 16:42:03 »
Alternately, buy a better mic / sound card that has good noise cancelling so it dosen't pick it up (as much)... Enjoy the switch of your choice.
Offline dreamingftw
« Reply #10 on: Thu, 19 January 2012, 17:14:55 »
Just don't talk to him anymore.
Offline laffindude
« Reply #11 on: Thu, 19 January 2012, 17:28:12 »
Quote from: laffindude;440088
The Japanese have solution for everything
I'll quote myself.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #12 on: Thu, 19 January 2012, 17:47:16 »
Blues will make it louder... My mate has a BlackWidow and I have a brown switch keyboard. His is so much louder than mine, even when his is over skype...
Get some O-rings and try that out first.
Another is to get good mic/sound card that cancels the noise. If you don't have a mic, a mic makes a lot of difference. The sound picked up from the mic should be from one direction (you) whereas if you have your laptop or something its picking up everything around it (you + keyboard).
I have some friends who play with me, and either they haven't complained (even if I ask them if my button mashing is annoying) or they bring it up and then get used to it. = /
Oh looking at the link from above. A simple solution: put a towel/jumper over your hand when you type.
« Last Edit: Thu, 19 January 2012, 17:50:17 by hazeluff »
Fight For Freedom. Stand with Hong Kongers
Offline Tony
« Reply #13 on: Thu, 19 January 2012, 20:58:20 »
I have complaints about every keyboard that I have.
Luckily all keyboards have no ears to hear such, otherwise they would run away from me.
Offline Henry Allen Venture
« Reply #14 on: Thu, 19 January 2012, 21:04:22 »
Quote from: theOwlol;494310
Yeah... Don't do that.
O-rings, or don't whack the keys so hard. My Browns don't make much noise at all unless I'm bashing on the keys pretty hard.
« Last Edit: Thu, 19 January 2012, 21:07:45 by Henry Allen Venture »
Current collection:
Filco Majestouch 104-Key, w/ MX Browns
IBM Model M 52G9700
Leopold FC200R, "white" w/ MX Clears
Ducky DK9008S \'Shining\', white backlit w/ MX Blues
Cherry G80-3494(LCYUS-2), w/ MX Reds for Portal Mod
Not mine, but I\'ve got access to:
Filco Majestouch Linear R Limited Edition, w/ MX Reds
Filco Majestouch 2 \'Ninja\' Tenkeyless, w/ MX Blues
Leopold FC500R, w/ MX Browns
Offline Graviton
« Reply #15 on: Thu, 19 January 2012, 21:41:35 »
i thought skype was talking and seeing your mate not typing :|
put oring will do...
