Author Topic: Model M not recognized under Windows 7  (Read 2725 times)
Offline RSSonic92
« on: Fri, 20 January 2012, 18:01:09 »
Hello Geekhackers,
today my SDL-PS2 cable for my Model M arrived.
I plugged my Model M into the computer and booted, Num-LED activates, Windows asks for my password but my keystrokes aren't recognized.
At first I suspected the Model M or the cable were faulty but after a bit of research I found this gentlemen having the same problem.
So I checked the EFI/BIOS and it seems to work perfectly in there. Keystrokes from all kinds of keys are recognized.
What is the problem here, and how do I make my Model M work under Windows?
My mainboard is an Asus P8P67LE and I use Windows 7 Home Premium 64 Bit.
Cherry PS/2 keyboards did not have such problems so far.
Offline RSSonic92
« Reply #1 on: Fri, 20 January 2012, 20:02:28 »
I just figured it out!
For reference: Go into EFI/BIOS, enter Advanced Mode
Advanced > APM > Power On By PS/2 keyboard
select an option like On/Off Button
works like a charm!
Maybe someone will find the right place in the wiki for this
Offline Krunchy
« Reply #2 on: Sat, 21 January 2012, 02:52:36 »
I had this exact same problem when I first got a model M plugged into a Windows 7 box.  Oddly enough, I found that it would always work if I repeatedly pressed numlock while Windows was starting up.  I couldn't tell you why this worked, but it never had trouble recognizing the keyboard when I did that.
Currently hacking away on
IBM Model M || MTek K104 || Dell AT101W || Anne Pro II
Offline RSSonic92
« Reply #3 on: Sat, 21 January 2012, 06:20:53 »
Quote from: ripster;495312
EDIT:  False Positive.  Try removing any/all USB keyboards.  Power down.  Then remove power cord or his power supply switch - wait 10 seconds.
Then reboot.  My keyboard won't work when I do that.
It still works for me. However yesterday shortly after my post I realized, that almost every second boot the Model M wasn't recognized but after rebooting it worked perfectly.
Today it works without compromise.
Quote from: Krunchy;495393
Makes me suspect the NumLock On Boot option for a reason...
Offline Surly73
« Reply #4 on: Sat, 21 January 2012, 08:31:38 »
You've probably already determined this, but Win7 isn't the issue here.  A model M connected via PS2 is my daily driver at work and has no problems with win7.  I remember ripster and a few others posting issues with some Asus boards.  I know my model M works fine with my old Asus P5B-E under Vista x64 and Win7 x64 but I honestly can't remember if I tried my model M with my newer P8P67 Pro or not.
