Author Topic: Next GH-brewed KB design - 'The Light' (open for discussion)  (Read 159823 times)
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #100 on: Thu, 02 February 2012, 23:51:13 »
Quote from: Parak;507036
Hmm.. I'm kinda tempted to craft this madness (cobbled together in a spreadsheet in a few minutes):
(Attachment Link) 39405[/ATTACH]
Ahhhh. Left handed numpad. Do not want. (left hander here, but use right hand for numpads).
Fight For Freedom. Stand with Hong Kongers
Offline TheProfosist
  • Custom Layouts Only!
« Reply #101 on: Thu, 02 February 2012, 23:54:49 »
my left hand is not that capable sadly.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #102 on: Fri, 03 February 2012, 00:00:52 »
Yes, an optional knob you can buy that solders to any 2 switch squares. It would have a mini 2x PCB on the bottom that had pins in the same place as mx switches. You just pop it in the board and solder it like any regular mx switch.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline Parak
« Reply #103 on: Fri, 03 February 2012, 00:05:30 »
Considering how infrequently I personally use a numpad, I'd rather have a shorter reach of a TKL to the mouse. I still need a numpad however for a few things, so that's why I put it on the left. I also consider full remapping, layers, and macros to be a functional requirement, so the left hand keypad would most of the time serve as a hotkey macro area for games and the like.
« Reply #104 on: Fri, 03 February 2012, 00:06:49 »
Quote from: Parak;507055
I think it might be interesting to have that functionality on the right and left at the same time
Offline Parak
« Reply #105 on: Fri, 03 February 2012, 00:09:43 »
Quote from: TheProfosist;507057
Right, with full programmability there's no reason why the two could not be interchanged, with the exception of the 1.5 keys. One possibility is to make both sides a 3x6 or 4x6 block of 1x1 keys, and then go to town, though for heavy numpad users having 1.5 keys would be more convenient.
Offline The_Ed
« Reply #106 on: Fri, 03 February 2012, 00:14:03 »
tyrannosaurus rex arms? My arms sit comfortably on the armrests of my chair. My left hand is directly on the wads, while my right is directly on my mouse. If I had a tenkeyless there would be a tenkeyless sized gap between my mousepad and keyboard. How in any way is there any less reaching on a tenkeyless?
R.I.P.ster
Offline Parak
« Reply #107 on: Fri, 03 February 2012, 00:53:30 »
Quote from: The_Ed;507064
Shrug? It's more convenient for me. YMMV obviously as with any other thing one may prefer about their user interface devices. On that note, I'm sure everyone wants a particular feature or particular design, but let's try to keep in mind that we're talking about projects that require significant time and money for typically negative or no financial gain in return. The projects will therefore first and foremost serve their own creator's wants/needs, especially since it's impossible to please everyone. In short, let's try to keep feedback and suggestions constructive for those that will hopefully make this one a reality.
Offline digitalleftovers
« Reply #108 on: Fri, 03 February 2012, 02:23:52 »
Quote from: hazeluff;506919
Don't have to, just need to find what kind of knob it is and how it interfaces with circuitry.
http://hackedgadgets.com/2010/02/01/rotary-encoder-and-shift-registers-explained/:
It spits out grey code for the "position" it is in.
So you'd have to make something in the controller that keeps track of the position and when it changes Inc/Dec the volume. It is possible. You just need to mount it nicely.
That video also nicely addresses most pin count limitations issues, with the use of shift register.  Could be quite handy for doing practically anything with the LEDs
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline The_Ed
« Reply #109 on: Mon, 06 February 2012, 02:34:34 »
Wow... 3 times the posts have gone missing now... I have the diagram drawn hazeluff. I will post it when I have time to scan it. Though this post may go missing too, so It'll be a surprise.
Oh look... pictures work again! So I can finally post the picture of the rotary encoder I bought 4 of, that was referenced in a lost post!
« Last Edit: Mon, 06 February 2012, 02:38:41 by The_Ed »
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #110 on: Mon, 06 February 2012, 07:51:30 »
Damn the rollback went pretty far last night...(also we were hacked =='')
I'll just repost the circuit I had drawn up. And just resummarize:
[ Attachment Invalid Or Does Not Exist ] 39424[/ATTACH]
So the Mechanical Rotary Encoder acts as a mechanical switch.
We use the resistor to make sure that the encoder does not short the voltage at the column pin to ground.
Everything is good. Concept shows that having a knob for volume is possible.
« Last Edit: Mon, 06 February 2012, 07:56:28 by hazeluff »
Offline The_Ed
« Reply #111 on: Mon, 06 February 2012, 11:37:30 »
Here's mine:
Ghosting can happen without those 2 extra diodes. It looks like your diagram is connecting to only one switch trace, and not connected to the circuit at all. And I have no idea why you are putting a resistor in there. The rotary encoders are 2-bit not 1-bit. They need 2 switches for those 2 bits.
Finally broke a hundred posts! Though if that hacker wasn't around i'd have broken it last week.
« Last Edit: Mon, 06 February 2012, 11:56:26 by The_Ed »
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #112 on: Mon, 06 February 2012, 12:09:06 »
Quote from: The_Ed;507353
Here's mine:
Ahaha I've lost like 50 posts = ( was almost at 1337 posts.
I only showed one of the bits. There should be two of them on your whole matrix. The resistor stops the encoder from shorting the column pin straight to ground, in essence the way Its hooked up on mine will cause the bits to be inverted, but that is not a problem.
On yours I don't understand why you have Vol up and Vol down labeled. The encoder doesn't pulse 1 for a increment/decriment. It shows the state it is in. It is up to the MCU to interpret whether or not it is an increment or a decrement. Your design using the "Ground" as the 2nd pin of a switch also works. I hope you know the operation, because the Volup and Voldown labels aren't how the encoder is going to work.
Offline The_Ed
« Reply #113 on: Mon, 06 February 2012, 12:23:53 »
http://www.youtube.com/watch?v=uh27ftADFKo
First part shows with LEDs what will be sent to the teensy. Second half should be skipped... The on/off of the LEDs represent the open/closed of the mx switches. 2 bits, 2 switches, and the teensy will send the appropriate volume key code for each full cycle. I have volume up/down labeled because if they are the first to close in the cycle, then that is the direction I will have the volume go. Even though technically it is the combination of the switches that send the appropriate grey code for volume up/down. 2 extra diodes are needed per rotary encoder to prevent ghosting.
I am using diodes and you don't understand me.
You are using resistors and your bits are inverted, whatever that means. And I don't understand you.
As long as they both work everything is fine.
« Last Edit: Mon, 06 February 2012, 12:28:41 by The_Ed »
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #114 on: Mon, 06 February 2012, 12:31:22 »
Quote from: The_Ed;507373
Yeah, you're good. = P
Waiting for my phantom~
So. Maybe we can get this project rolling soon = p. I need to colaborate the LED stuff with the rest and see what happens.
Offline The_Ed
« Reply #115 on: Mon, 06 February 2012, 12:38:10 »
I will only join if it is a 104 or 104+. 129 keys can be put into a g80/g81 -3000 case without changing the spacing. 13 below the F-keys, 3 below scroll lock, 5 above the arrows, 4 above the numpad. And even with all those keys the "lock" LEDs stay the same, and there is an extra inch and a half above everything still for all the controller crap.
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #116 on: Mon, 06 February 2012, 12:49:27 »
Quote from: The_Ed;507380
It will be 104+ since, it out of the projects here, it is the only layout missing. Definitely will do the +4 above the numpad and the +5 above the arrow. But I don't think we will do the 13 under the function (? There isn't enough spacing to put another row of function keys there). I don't want to reduce the distance between the function and number rows as well.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #117 on: Mon, 06 February 2012, 12:49:47 »
Well, if there's a target case then someone needs to provide measurements for the case.  All the standoff locations and how the holes in the top frame correlate to those standoffs.
And it does look as though the spacing on the g80-3000 F-row is such that a set of keys would fit between it and the num-row.
Filco w/ Imsto thick PBT
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #118 on: Mon, 06 February 2012, 12:55:10 »
Quote from: alaricljs;507383
Ewwww... Thats so far away. I'd target the standard 104 layout case. Filco/Ducky/Whatever?
Offline The_Ed
« Reply #119 on: Mon, 06 February 2012, 14:29:34 »
You could use the added 13 key row as your F-key row. You are free to program it as you wish. The 129 key layout can be anything you want it to be. If the LED windows were moved on a g80/g81 -3000 case you could fit 133 keys. And if the F-key row spaces were removed you could fit 4 more on that and extra row below, totaling 137. I would rather stay at 129 to not mess with the layout.
I just looked at a picture of a leopold and there wouldn't be able to have the extra 4 above the numpad even. Same for filco. I'm seeing ducky's with 4 keys already there.
Maybe I'm just used to "mod room"... Call me old fashioned... I personally prefer the F-keys farther away, so the extra 13 + 3 would be macros or whatever. I don't want to accidentally quick save/load when I didn't mean it... stuff like that... And it's really only like what 6mm farther right?
If I have to I could take apart one of my g80's and measure and take pictures. Should I, or would I just be wasting my time?...
I did some digging and I got all the way back to 1999 for the idea of an individually controlled LED mechanical keyboard! It was DECK Keyboards! -
fredDarmstadt, Great idea(s), individualy addressable LEDs, a whole 104 keyboards worth. we looked at that in aprox 1999 and didn't do it as it's expensive, and we didn't know any 3rd party software developers who would REALY be interested. but maybe the time has come. In about 4 months, we will introduce a standard 104 key layout KB with the same 50 million cycle keys and the same LED backlighting as we have and the same negative image keycaps we now have. Hey keep those ideas coming. you can E-MAIL me at tech support.
TOM g
I think he was talking about the DECK Legend. Which is why in 2008 a guy made the Legend what it almost was.
Almost all of that will be internalized in the teensy and traces, I hope...
« Last Edit: Mon, 06 February 2012, 15:35:49 by The_Ed »
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #120 on: Mon, 06 February 2012, 16:12:50 »
Quote from: The_Ed;507434
Obviously the +4 above the numpad and the +5 above the arrows won't fit in a standard case. This is cos it's a nonstandard layout. BUT you can still go for the extra keys if you wanted to, you'd just need to get your own case. The board will give the option for extra keys, but not compulsary.
As for the mess of wires you see there. That will be reduced significantly. We do the Column/Row polling we do for switches, but with LEDs. The lights are turned on one by one at a high frequency. Also If we do the SMD and use traces for the LED routes, then there should heopfully no wires flying about. = ). Where was the guy doing the LED controll stuff...
As for the Cherry G80 case. No need to rush for it. But I'd prefer it to fit the more standard layout, where the F keys were slightly closer than the G80.
Offline 7bit
  • MX1A-G1DW
« Reply #121 on: Mon, 06 February 2012, 16:44:59 »
Quote from: The_Ed;504992
full 104 keys
fits in cheap g80-3000 cases
LEDs - inside the switches
n-key rollover - diodes next to the switches
PCB mount holes - for if no plate is wanted
This should cover all but the tenkeyless crowd right? But then they already have a phantom.
No 104 key layout is boring. There are so many already in the market!
What about a HHKB clone?
I would not complain about the possibility to have LEDs in the switches.
Quote from: alaricljs;506790
Uh yeah, so where are those cheap cases found?  Someone had said g80-3000 and I go to ebay and look to see the cheapest is $90.  Errr wha?
What about using G81 cases? There are tons of them, once the key caps came off ...
« Last Edit: Mon, 06 February 2012, 16:48:07 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline 7bit
  • MX1A-G1DW
« Reply #122 on: Mon, 06 February 2012, 16:47:26 »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #123 on: Mon, 06 February 2012, 16:51:22 »
Quote from: 7bit;507528
Well 104 is boring, but its one of the layouts not done already and its different in because of the lighting. I'm argueing cos it's what I like. But I'm going for no less than TKL/7bit (but with proper numpad for the right bit; essentiall extra column of switches next to the home/arrow cluster).
As for the HHKB clone, Isn't that like the DOX?
If we can get a ton of cases, it would make it slightly more economical, but I still find it weird that the function row is so far away. I need them for games.
« Last Edit: Mon, 06 February 2012, 16:56:13 by hazeluff »
Offline The_Ed
« Reply #124 on: Mon, 06 February 2012, 17:37:47 »
I've probably posted this like 10 times (most are probably still "missing") here already, but g80/g81 -3000 cases are EXACTLY the same. I use the F-keys for games too, but I've gotten used to and prefer the greater distance now. The cherry cases have the most "mod room" and are EXTREMELY cheap, especially if bought in bulk when they show up. If the extra row of 20 switches is put in between the F and number rows, you can use that as your F-row instead. You can program any switch to be any switch. There are virtual key codes for F1-F24, so make the original F-key row F13-F24. A 129 key layout PCB would have the original 104 in the correct positions for the cherry cases. You would simply cut out the plastic and populate whichever extra switch locations you want. I would for sure use at least 9 extra switch locations for the media keys and knobs. And I may cut out and populate others for macros if I feel like it. That is why the 129 is also known as the 104+. It can be used as a regular 104, or up to a 129, thus it is +.
It is hard to carry on this discussion when parts have disappeared at least 3 times that I've noticed.
« Last Edit: Mon, 06 February 2012, 17:40:54 by The_Ed »
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #125 on: Mon, 06 February 2012, 18:05:32 »
Quote from: The_Ed;507570
But I really like the normal distance between the number and function row ><. I already have enough trouble doing ctrl+f1 with one hand, any more and I'd be stretching way too far. (and no I'm not open to swapping capslock and ctrl).
I also OCD, and if I had a keyboard with the extra distance between the two, It'd feel so wrong.
Also, I'm one of the people who'd rather get a custom case than use the cherry one.
I reckon it'd fit in a rubber dome case:
http://www.rosewill.com/products/1580/ProductDetail_Overview.htm#/Mgnt/Uploads/ImagesForProduct/ImgPrd-1580-Cm[5c0e9ae52d994ac2ba5bff4413bd458d].jpg
These cost like $15...There are probably other brands too with decent cases.
I'd just like to keep the look I'm used to intact.
Offline The_Ed
« Reply #126 on: Mon, 06 February 2012, 18:20:24 »
What part of the F-keys on your board would be closer don't you understand? Your F-keys would be the extra row of keys in the empty space.
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #127 on: Mon, 06 February 2012, 18:30:48 »
Quote from: The_Ed;507605
I Don't like that either...Sorry should of been clear.
Maybe we can HAVE BOTH!. I'm a genius, no more argueing. I can't imagine it adding a lot of routing since the switches for what i want and what you want are in parallel and can never both be used at the same time.
Offline The_Ed
« Reply #128 on: Mon, 06 February 2012, 18:42:48 »
Both? Cherry case and rosewill case universal? I would think that the PCB switch mount holes would make this impossible. But if it's possible then our bickering is done!
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #129 on: Mon, 06 February 2012, 18:54:41 »
Quote from: The_Ed;507619
Its like how the phantom has multiple places to place the shift switch. It should still work, since they are in parallel. I can't seen it adding so much routing that it causes a problem.
Offline The_Ed
« Reply #130 on: Mon, 06 February 2012, 19:06:22 »
Remember that with the LED control there is DOUBLE the routing.
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #131 on: Mon, 06 February 2012, 19:08:20 »
Quote from: The_Ed;507635
I see. But...we're only extending the existing one. I don't think it'll obstruct anything. We'll have to see what happens when we implement such a thing.
Offline The_Ed
« Reply #132 on: Mon, 06 February 2012, 19:16:12 »
FOR SCIENCE!
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #133 on: Mon, 06 February 2012, 19:26:38 »
Quote from: The_Ed;507641
FOR SCIENCE!
And believe me I am still alive
I'm doing science and I'm still alive
I feel FANTASTIC and I'm still alive
While you are dying I'll be still alive
And when you're dead I'll be still alive
STILL ALIVE
still alive
[ Attachment Invalid Or Does Not Exist ] 39507[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 39508[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 39509[/ATTACH]
Offline The_Ed
« Reply #134 on: Mon, 06 February 2012, 19:33:23 »
I LOVE PORTAL!
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #135 on: Mon, 06 February 2012, 19:37:21 »
Quote from: The_Ed;507654
I LOVE PORTAL!
I even have extra portal 1+2 keys on steam. ><
Offline The_Ed
« Reply #136 on: Mon, 06 February 2012, 19:39:41 »
Preordered huh?
CRAP! I just realized... We also need the mounting holes for PCB mount cherry g99 stabilizers!
« Last Edit: Mon, 06 February 2012, 19:51:07 by The_Ed »
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #137 on: Tue, 07 February 2012, 06:25:03 »
Quote from: The_Ed;507661
Preordered huh?
Can it not be plate mount?
Will this affect the board too much?
If alaricljs has a circuit for for the LED stuff, and I can get round to using the software for drawing up PCBs. We can see what space we have available on the board.
« Last Edit: Tue, 07 February 2012, 06:31:39 by hazeluff »
Offline 7bit
  • MX1A-G1DW
« Reply #138 on: Tue, 07 February 2012, 08:57:42 »
That's a good point
I recommend to move over to DT with this ...
Offline 7bit
  • MX1A-G1DW
« Reply #139 on: Tue, 07 February 2012, 09:55:21 »
Quote from: hazeluff;507612
This should work. If not turn the switches around 90 degrees and we have the same situation as with the Phantm PCB (function row).
PCB vs Plate mounting: With the switch-opening-cutouts, there should be no argument against platemounting anymore.
Can we please have an extra column of switches on the left?
Offline 7bit
  • MX1A-G1DW
« Reply #140 on: Tue, 07 February 2012, 09:57:13 »
Quote from: ripster;508131
The trouble with Deskthority.net is it's filled with foreigners.
I will tell webwit to close your account to reduce the number of posts done by foreigners @Deskthority significantly!
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #141 on: Tue, 07 February 2012, 12:58:35 »
Quote from: 7bit;508178
If we do, it won't fit most cases. = /
Plate mounting imo is the way to go, specially with the lovely side holes on the phantom ones <3.
Offline The_Ed
« Reply #142 on: Tue, 07 February 2012, 15:08:18 »
Okay! new list for 104+:
104
+ 5 above arrows
+ 4 above numpad
+ Esc through Pause/Break in double positions - in "regular" and cherry G80/G81 -3000 positions
Individually controlled LEDs - fit through holes in mx switches and solder to traces on the PCB
Fits into "regular" and cherry G80/G81 -3000 cases
n-key rollover - diodes next to the switches - possibly SMD and possibly already preinstalled
PCB switch mount holes - for if no plate is wanted
Cherry G99 stabilizer PCB mount holes - for if no plate is used and cherry stabilizers are wanted
7bit - Do you have a pile G81-3000 cases for those who want a cheap case here? I'll probably just buy a cheap G80-3000 for myself to get the case, PCB mount G99 stabilizers, and PCB mount switch bottoms.
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #143 on: Tue, 07 February 2012, 15:15:32 »
Sadly the idea still doesn't the normal Filco cases. But that's ok with me I guess.
Offline The_Ed
« Reply #144 on: Tue, 07 February 2012, 15:20:10 »
Why wont it fit filco? And I just realized that we will have to have wires running from the 3 "lock" switches' LEDs to also light up the LEDs in the upper right. They will be in parallel.
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #145 on: Tue, 07 February 2012, 15:26:13 »
Quote from: The_Ed;508495
Because the extra "row" added above the numberpad, will make the PCB longer than the case of a FILCO. Tho Why would anyone use a good keyboard's case for this. Might as well get a custom. But just my 2cents on that.
Possible we may need flyovers for those LEDs.
Offline alaricljs
« Reply #146 on: Tue, 07 February 2012, 15:29:36 »
As for why a direct replacement for Filco, plenty of people have a Filco and might be interested in changing it up a little.  1 PCB and a teensy would be all you need, re-use the rest of the Filco and you have a relatively inexpensive way to a custom firmware KB platform.  Even cheaper with a Rosewill.
Offline The_Ed
« Reply #147 on: Tue, 07 February 2012, 15:30:34 »
"flyovers" == wires or traces? By the way, are we going to be using the Teensy++ w/ Pins? I don't see how there would be enough pins otherwise.
R.I.P.ster
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #148 on: Tue, 07 February 2012, 15:32:02 »
Quote from: The_Ed;508509
No i mean wires if it doesn't fit.
I think the firmware may have to alternate between polling and doing the LEDs.
Offline The_Ed
« Reply #149 on: Tue, 07 February 2012, 15:34:32 »
Alternate? There would have to be A LOT of extra diodes to allow that...
R.I.P.ster
