Author Topic: Taking apart HHKB Pro 2  (Read 5761 times)
fossala
  •  Guest
« on: Wed, 01 February 2012, 00:47:12 »
I like to take things apart look at them and put them back together. How do you open a HHKB? Is there any screws under the feet or is it just the 3 at the top? If any one can give me guidance I will be grateful.
Offline HeavyArms
  • "Lit"
« Reply #1 on: Wed, 01 February 2012, 00:51:16 »
Is it bad that I kind of cringed when I read this?
Head in the clouds.
fossala
  •  Guest
« Reply #2 on: Wed, 01 February 2012, 00:56:14 »
Why? You don't break things just by opening them.
Offline forcefollow
« Reply #3 on: Wed, 01 February 2012, 07:38:01 »
only those three if you just want to peek inside or replace the controller, but to reach the rubberdomes and sliders, you need to open 16 more on the PCB
the controller can easily be dislodged from its groove, and so are replacing it, but at my first trial, I got some difficulty to align the USB port so they're as flush as before (1-2mm slight), but several tries later seems to fix it. I'm sure it's just my inexperience handling electronics.
wait.. I thought you've had it for quite some time?
fossala
  •  Guest
« Reply #4 on: Wed, 01 February 2012, 08:49:07 »
Quote from: forcefollow;505153
Thanks, only got it a week ago.
Offline patrickgeekhack
« Reply #5 on: Wed, 01 February 2012, 13:33:55 »
Quote from: fossala;505023
It does not always happen, but it can happen. Some people are even left with extra parts :-)
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline insilica
  • Keyboard Geeza
« Reply #6 on: Wed, 01 February 2012, 13:57:30 »
Quote from: patrickgeekhack;505429
Yea I remember this dodgy garage I took my car too. The guy replaced the passenger side window and was left with 6 or 7 screws can't remember. He was like eh.... these weren't in there. LOL. Total Muppet that guy!
As part of my work I have to dismantle expensive hardware (I won't go into detail) [for litigation] and the only way to keep track for me is to meticulously catalog every item on drawings and sometimes photos.
Good luck fossala!
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
« Reply #7 on: Wed, 01 February 2012, 14:02:23 »
Quote from: insilica;505451
I too think that taking photos is the way to go if you can.
Offline chel-
« Reply #8 on: Wed, 01 February 2012, 15:04:03 »
I have to agree, photos are the best. I've taken computer cases apart before (down to the removing all the rivets and everything) and I would of been absolutely screwed if I hadn't taken any photos.
Offline cheynestoking
    • dischord.org
« Reply #9 on: Thu, 02 February 2012, 05:07:08 »
Damn, that's a lot of screws.  I need to open up one of mine soon as it's developed a clacky spacebar.
