Author Topic: Ebay: Model F or M?  (Read 2065 times)
Offline Icarium
  • I AM A MONKEY!
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
Offline DrSchlock
Ebay: Model F or M?
« Reply #1 on: Wed, 01 February 2012, 13:47:33 »
It would be nice if he posted pictures of the actual keyboard. My model F has a black metal bottom plate. It's even heavier than the model M. I believe model Fs also have capacitive switches instead of membrane.
Offline HoboBob
Ebay: Model F or M?
« Reply #2 on: Wed, 01 February 2012, 14:39:52 »
If it's the original box, the board inside should be a Model F XT.
Same model can be seen on Clicky: http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/11066/subcatid/0/id/529211
Feel free to correct me if I'm wrong.
Offline slueth
Ebay: Model F or M?
« Reply #3 on: Wed, 01 February 2012, 15:01:02 »
Yea it should be a model f.
Offline Icarium
  • I AM A MONKEY!
Ebay: Model F or M?
« Reply #4 on: Wed, 01 February 2012, 15:05:58 »
How much are those worth?
Ebay: Model F or M?
« Reply #5 on: Wed, 01 February 2012, 15:15:16 »
They seem to be selling in the $40-50 range now that Soarer has made an easy conversion available.
I bought a couple last summer for $10-ish, but they seem to be much more desirable now.
- Plato
Offline Icarium
  • I AM A MONKEY!
Ebay: Model F or M?
« Reply #6 on: Wed, 01 February 2012, 17:39:56 »
Conversion? For the cable?
I'd like one but shipping is probably (as usual) prohibitive.
Ebay: Model F or M?
« Reply #7 on: Wed, 01 February 2012, 17:59:21 »
Shipping from US to Euro is approximately $50 for a standard keyboard.
Soarer's conversion uses the Teensy ($20, + small envelope shipped from Washington state) and converts the controller to a mini-USB-B plug. You have to do a little minor soldering, but it works well.
I have not done one on an XT, but you should be able to fabricate an outboard box if you have a female DIN connector.
On my projects, I mounted everything inside the case, but the XT has less room and an outboard box is more versatile.
- Plato
