Author Topic: Soldering is Easy!  (Read 3961 times)
Offline Gawkbasher
Soldering is Easy!
« on: Wed, 01 February 2012, 15:25:38 »
I saw a couple of posts recently of people talking about not being so confident in their ability to solder.
I figure this will be useful to some here who are considering trying it:  http://mightyohm.com/files/soldercomic/FullSolderComic_EN.pdf (direct link) or http://mightyohm.com/blog/2011/04/soldering-is-easy-comic-book/ (which has the comic in several other languages)
« Last Edit: Wed, 01 February 2012, 15:42:37 by Gawkbasher »
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline alaricljs
  • I be WOT'ing all day...
Soldering is Easy!
« Reply #1 on: Wed, 01 February 2012, 15:43:52 »
Truthfully, soldering is ridiculously easy, you just have to learn a tiny bit and have confidence in yourself.
Filco w/ Imsto thick PBT
Offline WhiteFireDragon
    • youtube
Soldering is Easy!
« Reply #2 on: Wed, 01 February 2012, 15:50:58 »
That comic works for pretty much all keyboard applications. But try soldering tiny chips on a laptop. They're so tiny and takes a steady hand to do. Btw, where can I find a micro soldering iron?
Offline Gawkbasher
Soldering is Easy!
« Reply #3 on: Wed, 01 February 2012, 15:52:40 »
Quote from: WhiteFireDragon;505548
That's where you need a Portalsol Piezo Pro, IMO.
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline alaricljs
Soldering is Easy!
« Reply #4 on: Wed, 01 February 2012, 15:57:08 »
I just got a sharp tip for my Weller soldering station.  That and some solder-wick and I have no problem with SMD's
Offline hazeluff
  • 光復香港
    • Hazeluff
Soldering is Easy!
« Reply #5 on: Wed, 01 February 2012, 20:29:18 »
Quote from: alaricljs;505541
And a steady hand if you're doing really really small pins.
Fight For Freedom. Stand with Hong Kongers
Offline nineteensc2
Soldering is Easy!
« Reply #6 on: Thu, 02 February 2012, 10:25:01 »
Thanks, this should be rather helpful.
Offline commandercup
Soldering is Easy!
« Reply #7 on: Thu, 02 February 2012, 13:03:35 »
I have tried and failed miserably in the past (terrible solder points/joints). Next time I solder, I will use this awesome comic. Thanks!
Offline Ekaros
Soldering is Easy!
« Reply #8 on: Thu, 02 February 2012, 13:49:01 »
Atleast switches aren't easily destroyed I think... So good practise...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline SidusNare
  • Do, or do not; there is no try.
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
Offline Zamorph
Soldering is Easy!
« Reply #10 on: Thu, 02 February 2012, 15:05:49 »
Soldering is Easy!
« Reply #11 on: Thu, 02 February 2012, 18:25:11 »
Great comic.
Thanks for posting it.
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
