Author Topic: Where to buy rubber feet?  (Read 10642 times)
Offline Daniel Beaver
« on: Mon, 06 February 2012, 18:28:58 »
Where on earth can you find some good material to make replacement rubber feet? My new Model F has a single rubber foot missing, and I've been sort of dumbfounded as to where I can aquire something to replace it. I'm also keen on replacing the rubber on my Topres and Model M, since they slide around a little too much for comfort. The feet on the Model F are very effective, and so I'm keen on buying something like those... would an online retailer specializing in gaming maybe have some?
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline Encryptor
« Reply #1 on: Mon, 06 February 2012, 18:49:09 »
I haven't seen anything online, but I've seen stick-on rubber pads at my local hardware store for putting on the inside of cabinet doors.  I'm not sure if they'd be thick enough but maybe?
Offline Henry Allen Venture
« Reply #2 on: Mon, 06 February 2012, 18:56:58 »
I know its pretty easy to get felt ones at lots of electronics/hardware/furniture stores, but these are more to stop scratching than movement. Don't know about rubber ones, but I'd suggest looking in similar places.
Current collection:
Filco Majestouch 104-Key, w/ MX Browns
IBM Model M 52G9700
Leopold FC200R, "white" w/ MX Clears
Ducky DK9008S \'Shining\', white backlit w/ MX Blues
Cherry G80-3494(LCYUS-2), w/ MX Reds for Portal Mod
Not mine, but I\'ve got access to:
Filco Majestouch Linear R Limited Edition, w/ MX Reds
Filco Majestouch 2 \'Ninja\' Tenkeyless, w/ MX Blues
Leopold FC500R, w/ MX Browns
Offline Disposable Hero
« Reply #3 on: Mon, 06 February 2012, 19:04:56 »
Go to Lowes or Home Depot and where they sell the rubber leg caps,carpet sliders for furniture and what not. There they sell different sizes of self-adhesive little foam-rubber feet,I think you can get square or round. They'll work perfect as they aren't very thick about 1/8"(maybe a tad thicker), and have a little traction pattern on them to keep from slipping. i think they are to prevent scratches on wood floors or something. I've used them on other projects and they are great.
« Last Edit: Mon, 06 February 2012, 19:14:29 by Disposable Hero »
Offline rainb1ood
  • so pretty so plastic
Re: Where to buy rubber feet?
« Reply #4 on: Tue, 07 May 2013, 00:38:21 »
edit: sorry, wrong thread reply and no way to delete own message :(
Offline khaangaaroo
« Reply #5 on: Tue, 07 May 2013, 02:21:46 »
http://www.allelectronics.com/make-a-store/category/545/Rubber-Feet/Bumpers/1.html
This store is actually a couple miles from where I live. I went there specifically to buy rubber feet. Shipping isn't bad, but I would buy a couple to make it worth it.
The clear ones have great grip, and the 100 x 54mm rubber pad can be easily cut to size for lots of different uses.
« Last Edit: Tue, 07 May 2013, 02:26:33 by khaangaaroo »
Offline TheProfosist
  • Custom Layouts Only!
« Reply #6 on: Tue, 07 May 2013, 03:32:17 »
Got a picture of the foot I get all my feet from an old trilling store even found a near exact replacement for my KMAC feet I was missing.
Offline keyton
« Reply #7 on: Thu, 16 October 2014, 20:35:02 »
Any hardware store
Offline strict
  • TKL Zealot
« Reply #8 on: Thu, 16 October 2014, 20:51:55 »
I picked these up at Home Depot and they were very grippy. They are stackable as well.
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #9 on: Thu, 16 October 2014, 21:17:06 »
I've been testing out different types of feet to go along with my wrist rests (I like to include a couple different sizes free so that people can adjust the height if they want).
Had a great suggestion from GSimon that I should start selling these for people who need simple sets of keyboard feet, so I'm going to be offering these in my shop as soon as I get some envelopes to ship them in :)
Right now my standard packages have sets of 10 3.5mm cylindrical bumpons and 10 flat (~1.5 mm) nonslip rubber squares.  Should be enough to fit any keyboard in a couple of different height configurations.
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Offline StefanoDixon
« Reply #10 on: Sun, 13 September 2015, 20:23:20 »
Offline Data
« Reply #11 on: Sun, 13 September 2015, 20:54:09 »
http://www.mcmaster.com
You'll find them under "bumpers".
Offline darkspider
« Reply #12 on: Tue, 15 September 2015, 10:11:21 »
I've found and am using a perfect alternative of Model F rubber foot.
What I'm using is SJ-P5007 manufactured by Takachi electric industrial.
IBM Model F AT         Model M silver label    Model M gray label    Majestouch 2 Ninja
Brand New F62 Kishsaver / F77 Industrial Model F's made this year
