Author Topic: das keyboard broken?  (Read 833 times)
Offline revolte
« on: Thu, 09 February 2012, 08:04:33 »
hello,
first... im from germany --> sorry for my bad english.
today i got my new das keyboard model s. but i think its broken because there are arround 6 keys that does not realy click (feels and sounds like mx reds). or is it normal that there is such an huge difference between the click with the mx blues?
i thoughts are, that this keyboard got damaged by an other user and was send back. the cabel sits although not correct so there is a gab of 2-3 mm between the 2 case parts.
thanks for answers!
Offline byFd
« Reply #1 on: Thu, 09 February 2012, 08:11:01 »
do the switches work but not click? or not even work?
you could try do pull a cap and look if there is blues underneath (very unlikely :D)
you got it from getdigital.de?
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline revolte
« Reply #2 on: Thu, 09 February 2012, 08:13:25 »
yes from getdigital.de.
and all switches are blue.
edit: and yes the switches are working.
Offline byFd
« Reply #3 on: Thu, 09 February 2012, 08:21:52 »
seems weird, not sure what the problem is, but i would contact getdigital support about replacement.
a new product should work perfectly :D
KBC Poker X MX Reds
Offline patrickgeekhack
« Reply #4 on: Thu, 09 February 2012, 08:26:12 »
Quote from: revolte;510078
Return it. I had one which had only one key doing this, the " key. It was still annoying though.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
