Author Topic: Inexpensive ergonomic desk?  (Read 9269 times)
Offline cupraikso
« on: Sat, 11 February 2012, 17:41:20 »
Does anyone have a recommendation for a good, inexpensive, simple ergonomic desk?
I'm just looking for a basic table with a keyboard/mouse tray and that's it. I don't need holders for computer cases, printers, or speakers. Just a place to work with my laptop connected to a big display.
Extra points if the tray has adjustable height.
Offline cupraikso
« Reply #1 on: Sat, 11 February 2012, 18:58:49 »
Quote from: harrison;512040
are we talking walmart inexpensive, ikea budget, or ...?  'inexpensive' is relative.  i've spent a ~800 on a desk and feel it was still a great deal.  i've also spent $60 on a used desk off craigslist and been pleased.
personally, if a keyboard tray isn't a requirement, finding a used jerker is the way to go.
Yeah, maybe I shouldn't said inexpensive. I don't mind if it's $500; I just want it to be good and my requirements are pretty simple, I think.
Is the keyboard tray problematic on cheap desks? Your comment seems to suggest so.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Sat, 11 February 2012, 20:32:16 »
Generally desks in the inexpensive range that are decent quality don't come with KB trays.  On the more expensive end of cheap you might get a tray, but it won't be adjustable enough.  Better to get a used Jerker or if you can't find one then one of the height adjustable ikea desks (Galant) and retro-fit a good tray.
Filco w/ Imsto thick PBT
Offline isp
« Reply #3 on: Sat, 11 February 2012, 21:29:18 »
I'd like one of these...Geekdesk
You better have a decent wire management strategy though because that's a lot of space for them to hang and look pretty ugly.
hhkb
Offline Snarfangel
« Reply #4 on: Sat, 11 February 2012, 22:54:54 »
It's probably not what you are looking for (the desk height isn't adjustable), but I have a Leda desk similar to this w/o the drawer or lower shelf:
This one runs about $250. I got mine about ten years ago, and it still functions adequately as a desk. :)
Offline kryzis
« Reply #5 on: Sun, 12 February 2012, 00:20:30 »
I use a Galant as well. For keyboard positioning, I just have the table set at it's lowest setting and raise up my chair. I use monitor stands to get my monitors to eye level since my monitors don't have adjustable height. The surface itself is pretty durable and super easy to keep clean. I haven't gotten anything on it yet that I haven't been able to wipe off with warm water and a clean rag. If you just go with the table top and legs you could definitely keep it under $300. If your budget is $500 that gives you plenty to add anything else you want.
Offline Wildcard
  • When caffeine isn't enough
« Reply #6 on: Sun, 12 February 2012, 01:48:12 »
Eventually I'm going to have to build my ideal desk. I can't find anything close to what I'm looking for. As far as ergo goes, a desk built to match your height/chair is ideal, with proper depth for your displays. Most desks I find are just a little two short, not wide enough, and not curved.
Offline pitashen
« Reply #7 on: Sun, 12 February 2012, 02:39:09 »
+1 to the above suggestion of IKEA Galant. Think its one of the cheapest solution with decent appearance.
Offline sordna
« Reply #8 on: Sun, 12 February 2012, 04:46:56 »
I use an IKEA tabletop (VIKA something) and adjustable legs (VIKA KAJ - infinitely adjustable from 23-35" or 60 to 90cm) which I'm very happy with. I keep my work surface high (31.5") but I also installed an adjustable keyboard tray so my keyboard/mouse is low where I want it.
Offline RTbar
« Reply #9 on: Mon, 13 February 2012, 23:04:15 »
that's easy... wait until Antro has their 45% off sale and get a fit adjusta desk... it can be adjusted from sitting to standing, and the whole second shelf acts as a giant keyboard tray that is tiltable. I had a galant and the Antrho blows it out of the water
anthro.com
« Last Edit: Mon, 13 February 2012, 23:06:29 by RTbar »
Offline Parak
« Reply #10 on: Mon, 13 February 2012, 23:48:36 »
The fit adjusta is amazing. I have the 60" one with a bunch of trimmings, shelves, and addons, but I paid retail not knowing and not asking about discounts. At least this was when they offered percentage discounts the more you bought, but I still overpaid. No regrets either way.
Offline volund
« Reply #11 on: Wed, 22 February 2012, 18:37:03 »
Hollow core door, cut down to size (fill the end with appropriate sized block. Use Ikea legs for one side and a file cabinet for the other
Top with a nice sheet of finish luan plywood sanded and polyurithaned, edge with whatever you want (I used angle iron)
you can add a keyboard tray if you want, but building the desk to a good height to start with is the better option
Quickfire Rapid with Cherry white on black doubleshots
Keyboard rest by The_Beast
Offline Awful
  • Don't Topre.
« Reply #12 on: Wed, 22 February 2012, 20:18:50 »
Quote from: RTbar;513750
anthro.com
Any idea of the price on that before the 45% off discount whenever they do it? I think I found a list price of 800.00 but alot of times companies take 50% off the list for the actual sale price (At least Pearl drums/other musical instruments) do this. I've never looked into furniture online so I have no idea if the list is the actual retail/purchase price.
I hate everything.
Offline RTbar
« Reply #13 on: Thu, 23 February 2012, 00:32:25 »
If you go to their website they have the correct prices, but sometimes you can try googling anthro desks and you may find them for slightly cheaper... I called up with intentions of buying the desk full price because I missed the 45% sale, but they ended up giving me 15% off so it wouldn't hurt to call and ask... but if you are considering any antho desks you should just wait a little because I think the 45% promotion comes back in april, leaving money left over for their cable closet or extra shelves/ side tables if you want
Offline Inf3rn0_44
« Reply #14 on: Thu, 23 February 2012, 07:23:12 »
+1 ikea galant, I use it and its height adjustable. Id say its a good ergo desk.
|IMO 1.0 Frankenmouse WMO Internals |
|Access-IS AKC090 Ghetto Reds w/ O-Rings |
