Author Topic: [feedback] Poker metal case construction  (Read 26491 times)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #50 on: Tue, 21 February 2012, 16:45:11 »
Quote from: h2oxide;521051
How will it work if its a U shape? Won't that completely expose the keyboard pcb?
If by 'completely expose' you mean the edge of the PCB on 2 sides will be exposed, then yes... Is there a problem there that you think needs solving?
Filco w/ Imsto thick PBT
Offline oneproduct
  • @Ubisoft
« Reply #51 on: Tue, 21 February 2012, 16:53:55 »
The whole PCB is already exposed on the top in a sense since if you spill something on a Poker it goes right down onto the PCB. If it were a U shape the only difference would be that you could see the 2mm thick side of the PCB from two directions, but really that exposure wouldn't be that much of a problem at all.
Some people think it's cool to be able to see the insides like that, but for now I plan to do all four walls unless there's an issue with it.
Layout: Colemak
Offline h2oxide
« Reply #52 on: Tue, 21 February 2012, 17:18:54 »
Quote from: alaricljs;521053
That would make the pcb prone to dirt/dust - more-so than it already is and not to mention would make it look ugly (imo)
Offline lightsout714
« Reply #53 on: Tue, 21 February 2012, 18:33:33 »
I would prefer not to see the pcb. Would look incomplete to me.
Is there any estimation on price yet? Or is it to early for that?
Offline oneproduct
  • @Ubisoft
« Reply #54 on: Tue, 21 February 2012, 18:50:11 »
Quote from: lightsout714;521168
Metal = cheap. Labor cost = dunno. I'm getting this done Thursday though so you shouldn't have to wait long to figure out!
Layout: Colemak
« Reply #55 on: Tue, 21 February 2012, 18:53:19 »
Quote from: oneproduct;521184
No worries just wondering if you had that figured out. Can't wait to see the result. With all the group buys I'm not sure if I'll have the dough but I hope so.
Offline alaricljs
« Reply #56 on: Tue, 21 February 2012, 19:19:13 »
Quote from: h2oxide;521090
Somewhat... but it would also be really easy to clean as well.  No taking it apart and finding out just how much more dirt was in there than you expected when you go to clean it.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #57 on: Tue, 21 February 2012, 22:25:47 »
4 walls vs 2 walls the only material difference as far as i'm concerned is that there's no need to bond the edges together. cheaper labor costs, and will probably look better, as the welds will need to be sanded down to be palatable.
Offline h2oxide
« Reply #58 on: Wed, 22 February 2012, 05:09:31 »
Quote from: mkawa;521414
Completely subjective
Offline duncan
« Reply #59 on: Wed, 22 February 2012, 05:14:33 »
Quote from: h2oxide;521661
In other news from the completely obvious network news:
Water runs downhill
China's population quite large
Realforce 86UB || HHKB P2 || FILCO MT 87 Blues || FILCO MT 87 Browns || FILCO MT 87 Ninja  Blacks || Poker X Reds
Offline h2oxide
« Reply #60 on: Wed, 22 February 2012, 05:26:14 »
Quote from: duncan;521664
Water runs downhill
Whats with the attitude, that time of the month?
Offline turbocharged
« Reply #61 on: Wed, 22 February 2012, 08:15:36 »
So what type of steel are you going to use and what thickness? Also, how are you planning on finishing it....paint, just clearcoat?
I honestly think that using something like 14ga 304 stainless and leaving it unfinished would be the best looking and most rugged. I would pay extra for that.
Also, I think four bends is the only way to go. Don't really need to worry about welds/gaps in the corners as long as the cuts are good (i.e. laser or plasma cut). I think the U-shape would look awful and cheap in comparison.
EDIT: I just noticed that you are planning on 3/16" thick steel...I'm interested to see how this turns out (I think it will be a bit too thick). Just so you know...the dimensions you listed with a 3/16" thick piece of steel will weigh in around 3.2 pounds.
Maybe I'll throw something together in Solidworks at some point.
« Last Edit: Wed, 22 February 2012, 11:52:39 by turbocharged »
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline Bertross
« Reply #62 on: Wed, 22 February 2012, 19:28:04 »
Just making a logo now. see how we go.
[ Attachment Invalid Or Does Not Exist ] 41400[/ATTACH]
« Last Edit: Wed, 22 February 2012, 19:36:16 by Bertross »
REALFORCE 86UB / FILCO MJ2 87 BROWN PBT WHITE/BLUE
« Reply #63 on: Wed, 22 February 2012, 20:04:27 »
^^Nice
Offline himynameisbunny
« Reply #64 on: Wed, 22 February 2012, 20:06:26 »
Just my $0.02...
There should be a raised section in the middle of the case that supports the center of the PCB.
While I had my Poker it was the flex in the middle that made it seem inconsistent compared to any other mech.
Obviously you would have to buy some non-conductive tape or something to put on top of it...
[SIGPIC][/SIGPIC]
Happy Hacking Keyboard Pro 2 // Logitech M570 Trackball // Topre Realforce 23UB
Offline h2oxide
« Reply #65 on: Wed, 22 February 2012, 20:21:53 »
Blu-Tack? This isn't the stuff I want to read just before receiving my Poker
Offline mkawa
« Reply #66 on: Wed, 22 February 2012, 20:24:34 »
Quote from: himynameisbunny;522408
Just my $0.02...
can't do this. the case material will be conductive, and besides the bottom of the pcb is uneven due to both components and pins. what this will have instead is room to put a soft esd-safe mechanical coupler (read: a sheet of cushy nylon).
this would be awesome. if you do this, don't feel constrained to oneproduct's construction method. i believe i should have access to a 4-axis cnc on campus.
« Last Edit: Wed, 22 February 2012, 20:27:05 by mkawa »
« Reply #67 on: Wed, 22 February 2012, 20:28:53 »
Quote from: mkawa;522433
One of those non-slip mats would probably be best.
Having now thoroughly read the OP I can see that it's already been thought of :blabla:
Quote from: h2oxide;522429
It's a fantastic board, I wouldn't worry too much. Remember this is the OCD center of the Internet!
[SIGPIC][/SIGPIC]
Offline mkawa
« Reply #68 on: Wed, 22 February 2012, 20:30:07 »
yah, we said the same thing. all good!
h2oxide: poker is awesome. we just want to make it awesomer.
Offline oneproduct
  • @Ubisoft
« Reply #69 on: Wed, 22 February 2012, 21:15:22 »
Nice logo Bertross. Like I said, I don't think that they have anything that could engrave that into the metal, but I'll bring it along to check.
Is the conductivity that big of an issue? Seems like imsto's cases don't do anything to stop the PCB from touching metal nuts seated on the metal case. http://i4.photobucket.com/albums/y146/eddie84/OCN/Mech%20keyboard%20club/KBC%20Poker/Poker%20case/DSC06648.jpg
Layout: Colemak
Offline alaricljs
« Reply #70 on: Wed, 22 February 2012, 21:21:02 »
Those are the only places that the PCB touches.  Those parts of the PCB are designed to come in contact with the case.  If you were to put a ridge in the middle as was requested it would have to be carefully measured and placed so as to not come in contact with any of the solder or leads sticking out the back, nor with any of the plastic parts of the switches so that the PCB can lie properly.
Offline mkawa
« Reply #71 on: Wed, 22 February 2012, 21:35:43 »
a single ridge wouldn't help anyway. you need to mechanically couple the whole damn board to the case or it's always going to flex
Offline Bertross
« Reply #72 on: Wed, 22 February 2012, 22:11:18 »
Quote from: oneproduct;522511
no worries, I've neatened it up a bit, let me know if you need an illustrator file. Ill just email it to you. I have some ideas with its whereabouts to.
I reckon on the underneath, or a small KBC one where the TKL filco sits.
Offline mkawa
« Reply #73 on: Wed, 22 February 2012, 22:21:43 »
he would need a pretty high powered laser cutter to engrave. presumably he doesn't have access to one of these things, or it wouldn't be too hard to cut out the holes we want in the sheet
Offline Bertross
« Reply #74 on: Wed, 22 February 2012, 22:24:34 »
yeah true, was just an idea really. You could even do an insert cut on the bottom and get it engraved at a jewellers on a small trophy plaque or something like that.
Offline mkawa
« Reply #75 on: Wed, 22 February 2012, 22:25:14 »
yah, i think engraving is generally easier than the general machining
Offline oneproduct
  • @Ubisoft
« Reply #76 on: Thu, 23 February 2012, 21:43:23 »
Well, this was suppose to happen today but my friend didn't answer his email or texts, so I presume that he's somewhere over the Atlantic ocean or sleeping off jet lag since he was coming back from England today. Will let you know what's happening as soon as I speak to him again.
Layout: Colemak
Offline oneproduct
  • @Ubisoft
« Reply #77 on: Fri, 24 February 2012, 11:43:23 »
Okay, got to him today and brought it to one of the white collar guys in the shop who will be arranging production. Most likely not going to be doing the indentations so that the PCB can be screwed directly into the base of the case though unfortunately, so it will be more like imsto's version where the PCB rests on nuts. I'll probably have a prototype back late next week.
Layout: Colemak
Offline Elrobo
« Reply #78 on: Fri, 24 February 2012, 12:00:44 »
Awesome, can't wait to see pictures. Now I just need to find myself a poker with red switches.
Offline whiskerBox
« Reply #79 on: Fri, 24 February 2012, 12:29:01 »
Interested in how this turns out!
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
« Reply #80 on: Fri, 24 February 2012, 12:32:43 »
Looking forward to it!
Offline snowboarder3
« Reply #81 on: Sat, 03 March 2012, 03:28:43 »
count me in
Offline digitalleftovers
« Reply #82 on: Sun, 04 March 2012, 00:35:22 »
Also interested to see how this turns out.  I'm especially interested in yours because I feel that the sides on the vortex prototype are too short.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline oneproduct
  • @Ubisoft
Layout: Colemak
