Author Topic: Having trouble deciding on a keyboard. (MX blues)  (Read 2692 times)
Offline eltocliousus
« on: Thu, 08 March 2012, 03:53:03 »
I've put £100 aside to buy a new keyboard ($160, give or take) but I can't make up my mind, my main runners are the Das keyboard ultimate and the KBC poker however anything is on the table at this point.
I'm wanting to order before Monday so I've got a couple days to decide, I'm mainly looking for a great looking keyboard with MX blues, blank keys are bonus but not necessary and the layout is not an issue I can adapt, a compact design is fine too (like the KBC poker or HHKB).
I appreciate any suggestions or replies, thankyou very much!
fossala
  •  Guest
« Reply #1 on: Thu, 08 March 2012, 03:55:18 »
For 100gbp I would get a filco.
« Reply #2 on: Thu, 08 March 2012, 03:59:29 »
Quote from: fossala;538850
Anything specific in mind? I should add, I'm very new to this, however most filcos I've seen so far don't look nearly as sophisticated as a KBC poker or the full-sized Das ultimate, but I may be viewing them at a shallow point of view.
And cheers!
« Last Edit: Thu, 08 March 2012, 04:08:08 by eltocliousus »
fossala
  •  Guest
« Reply #3 on: Thu, 08 March 2012, 04:37:02 »
Filco are the best made cherry keyboards IMO. Pokers are cheap crap.
Offline All The Fire
« Reply #4 on: Thu, 08 March 2012, 04:56:52 »
Plenty of Ninja Filco's at The Keyboard Company for £100 too.
http://www.keyboardco.com/
They may not be the prettiest, but they're highly regarded as the most solid cherry keyboards, and for the money quality should be major concern.
« Last Edit: Thu, 08 March 2012, 04:59:53 by All The Fire »
« Reply #5 on: Fri, 09 March 2012, 09:12:42 »
Quote from: All The Fire;538862
Those filco ninjas do look quite good, quite similar to the KBC poker, although the cheapest is £130 with shipping which is a little over budget and unfortunately I can't afford to pay the extra.
What makes the KBC poker cheap? I don't doubt your information, I just want confirmation before I make a bad purchase, as the KBC Poker is still my first choice due to price/visuals.
Thanks again, very helpful so far.
« Last Edit: Fri, 09 March 2012, 09:48:54 by eltocliousus »
Offline stingrae
« Reply #6 on: Fri, 09 March 2012, 09:34:00 »
Quote from: eltocliousus;540031
Those filco ninjas do look quite good, quite similar to the KBC poker, although the cheapest is £135 with shipping which is a little over budget and unfortunately I can't afford to pay the extra.
So you aren't from England?
Perhaps look into the quickfire rapid?
Filco Ninja Tenkeyless  -Noppoo Choc MiniCm Storm Quickfire Rapid
fossala
  •  Guest
« Reply #7 on: Fri, 09 March 2012, 09:37:04 »
It is a bit bizzare saying your amount in gbp when you don't live in the UK.
« Reply #8 on: Fri, 09 March 2012, 09:48:13 »
I do live in the UK yes, the cheapest Filco Ninja is £120, £10 shipping.
And the quickfire rapid, I'm not a massive fan of the keycaps (a little game oriented) unfortunately.
fossala
  •  Guest
« Reply #9 on: Fri, 09 March 2012, 09:50:39 »
Shipping is free if you spend over 50gbp.
fossala
  •  Guest
« Reply #10 on: Fri, 09 March 2012, 09:52:26 »
Just thought I would let you know that ninjas only come in cherry brown.
Offline hcry4
  • HHKB Hoarder
« Reply #11 on: Fri, 09 March 2012, 09:58:30 »
They have ninjas with black or blue too.
fossala
  •  Guest
« Reply #12 on: Fri, 09 March 2012, 10:04:12 »
Only in US layout.
« Reply #13 on: Fri, 09 March 2012, 10:07:50 »
Oh I see, I really would like the blues for the full on mechanical experience (tactile with audible click clack) plus the £20 really is beyond my budget, I'll have £108 free of my next paycheck and I don't want to wait another two weeks, and borrow money is never fun, I'm still leaning towards the KBC poker but if it really is built badly then I will stay away, from the small amount of reviews I've seen it doesn't look badly built at all though.
fossala
  •  Guest
« Reply #14 on: Fri, 09 March 2012, 10:11:02 »
It is the worst built board I have had. The selection that is from is kbc poker, cherry 11800, compaq 11900, unicomp spacesaver, model M, filco blue full size, kinesis, hhkb pro 2, hhkb type s, dell at 102 and various pos keyboards.
EDIT: And a 86u realforce for 48hrs before sending it back.
« Last Edit: Fri, 09 March 2012, 10:16:05 by fossala »
« Reply #15 on: Fri, 09 March 2012, 11:04:35 »
Have you had any time with the KBT Race 75%? It's similar to the poker with a slightly different layout, green backlit keys and cherry reds rather than blues, but it still has the desirable aesthetic I'm after (an almost HHKB look to it).
Offline TheProfosist
  • Custom Layouts Only!
« Reply #16 on: Sat, 10 March 2012, 05:34:04 »
Ill sell you my fully modded wasd which has blues if you wish though you have to cover shipping 100%
« Reply #17 on: Sat, 10 March 2012, 07:30:26 »
Quote from: TheProfosist;540947
I ended up buying a HHKB but thankyou for the offer.
« Reply #18 on: Sat, 10 March 2012, 07:31:27 »
Quote from: eltocliousus;540975
thats an odd choice after looking for blues but you wont be sorry.
« Reply #19 on: Sat, 10 March 2012, 07:42:45 »
Quote from: TheProfosist;540976
I thought that myself too, but It'll stop upgrade-itis for a while atleast, and thanks!
