Author Topic: My leopold moves around.  (Read 3255 times)
Offline ReAzem
« on: Thu, 15 March 2012, 20:37:48 »
I have a leopold TKL, it keeps moving around. Is there such things as keyboard mats? I made a small google search about that and I haven't found anything except the razer goliathus.
Thanks, GeekHack!
« Reply #1 on: Thu, 15 March 2012, 20:42:50 »
Go to Wal-Mart and buy a roll of shelf liner or drawer liner. It will be foam rubber about 3 mm thick in a square waffle grid. Color choices, too!
Great stuff, under $5, and you can use it for a lot of things, including sound deadening.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline ReAzem
« Reply #2 on: Thu, 15 March 2012, 20:44:48 »
Quote from: fohat.digs;547221
Ohh, and I'll also be able to rest my hand on it. Atleast it will be more comfortable than wood hah.
Thanks, great idea.
Quote from: ripster;547222
Shoulda got a Filco.
Rubber feet.
Actually I have tried using the leopold withouut the feets and it still glides around, I'm blaming that on my desk and the way I play starcraft lol. Typing is no problem because I don't bottom out and mash my keys as hard as I do when I play.
« Last Edit: Thu, 15 March 2012, 20:47:39 by ReAzem »
Offline ReAzem
« Reply #3 on: Thu, 15 March 2012, 20:47:19 »
Rubber feet.
Offline All The Fire
« Reply #4 on: Thu, 15 March 2012, 20:50:08 »
I've found the Leopold feet to be generally useless. Even after a good cleaning they slip easy.
« Reply #5 on: Thu, 15 March 2012, 20:58:13 »
Quote from: ripster;547230
The Xtrac Super XXL  is pretty cheap and VERY big.  Somebody posted one even larger but I never did track it down.
Were you looking here where they claim the XXL is a 3XL and the XL is a 2XL? I don't really get it.
http://www.xtracpads.com/sections.php?section=1
Been thinking of getting the XXL, currently using a Cyborg Glide 7 for my keyboard and a Roccat Sota for my mouse, would be easier with just one mat and the sota is my first hardmat in over a year and I think I do prefer the cloth pads.
Offline ReAzem
« Reply #6 on: Thu, 15 March 2012, 21:43:55 »
Those huge mats are great but I am using a plastic mouse mat (4HD) and I only swear by plastic mats. So I would have to put my mouse mat on my other mat.
mat-ception!
Maybe you guys have a proposition to make my feets stickier? Is there such thing as rubber tape that I could wrap around  the feets?
Offline lorem3k
    • http://twitter.com/#!/lorem3k
« Reply #7 on: Thu, 15 March 2012, 21:46:29 »
My Leopold must be defective. It doesn't move around at all, even when using the feet... I'll RMA it
Leopold FC200RT/AWN | Logitech G400 | Sennheiser HD25-1 II | Pounds in the fridge, hundred stacks in the armoire
Offline Ahlitah
« Reply #8 on: Thu, 15 March 2012, 21:52:18 »
Buy some Plasti-dip and dip the feet in it, and you have a custom rubber coating!
Offline ReAzem
« Reply #9 on: Thu, 15 March 2012, 22:16:48 »
This sound like something I cannot remove afterwards, is that it ?
« Reply #10 on: Thu, 15 March 2012, 22:28:42 »
Quote from: ripster;547267
Don't get it?  What's not to get?
The XL is a 2XL and the 2XL is a 3XL man!!
I don't know what to believe anymore.
Offline ReAzem
« Reply #11 on: Thu, 15 March 2012, 23:59:07 »
« Last Edit: Fri, 16 March 2012, 00:29:27 by ReAzem »
Offline ReAzem
« Reply #12 on: Fri, 16 March 2012, 00:03:52 »
You are deceiving me, #1. You don't know the answer to my question?
Offline ReAzem
« Reply #13 on: Fri, 16 March 2012, 01:35:42 »
I told you I would if I could change my vote.
Offline ReAzem
« Reply #14 on: Fri, 16 March 2012, 02:02:46 »
Quote from: ripster;547546
Don't have a Leopold
Will you fix that soon?
« Reply #15 on: Fri, 16 March 2012, 02:12:04 »
Measuring the image on screen it would seem the 28mm measurement matches the width.
But the channel for the Leopold is 25mm.
[ Attachment Invalid Or Does Not Exist ] 44406[/ATTACH]
Even if it was actually 22mm wide it might sit in but I'd bet it'd be wobbly.
Offline Ahlitah
« Reply #16 on: Fri, 16 March 2012, 07:47:15 »
Quote from: ReAzem;547316
nope, very easy to remove. You just peel it off!
