Author Topic: [SHIPPING] R3 Moogle Kits  (Read 294068 times)
Offline Prelim
Re: [SHIPPING] R3 Moogle Kits
« Reply #1150 on: Thu, 23 April 2015, 18:26:57 »
Ivan is suppose to run a small modifiers set made by GMK.
Ivan is quitting it for now... it's time to @intelli78 make a GB/Massdrop for this! ;)
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline intelli78
« Reply #1151 on: Thu, 23 April 2015, 18:31:21 »
I am open to the idea, as long as it doesn't clash with Photekq's GB.
Where did Ivan say he is quitting the idea?
Offline Prelim
« Reply #1152 on: Thu, 23 April 2015, 20:01:23 »
I think will just stick to the full set, CMYKv2, and additional spacebars this time only. I've added windowed caps lock, num lock, scroll lock key to CMYKv2 so that should take care of most of requirement people need for white/black patch kits... granted in different colors.
https://geekhack.org/index.php?topic=70463.msg1719705#msg1719705
Offline Prelim
« Reply #1153 on: Tue, 19 May 2015, 09:14:46 »
so no GMK moogle/patch kits this year? :(
Offline captain
« Reply #1154 on: Tue, 24 November 2015, 09:23:06 »
I have so many moogle kits sitting in a drawer I don't know what to do with them...
You can even find your drawers?!?  Come dig me out from under the collapsed pile of keyboards and key caps when you're done.  ;-)
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #1155 on: Tue, 24 November 2015, 12:40:57 »
captain?!  :eek:
« Reply #1156 on: Tue, 24 November 2015, 13:06:42 »
captain?!  :eek:
Whoa. It's getting old skool up in here. :)
Offline intelli78
« Reply #1157 on: Tue, 24 November 2015, 17:08:36 »
I will do this after GMK SNES.
« Reply #1158 on: Tue, 24 November 2015, 17:31:51 »
I will do this after with GMK SNES.
FTFY.
And huzzah!
Offline intelli78
« Reply #1159 on: Tue, 24 November 2015, 17:35:25 »
Yea, we can get started just as soon as the SNES GB goes live, which should be around the end of the month. This one has been a long time coming...
Offline swimmingbird
  • keyset hoarder
« Reply #1160 on: Thu, 26 November 2015, 07:52:40 »
Good to see someone take it on!
Offline ideus
  • Björkö.
« Reply #1161 on: Thu, 26 November 2015, 08:30:22 »
More Tayloring for the masses.
Offline Wildcard
  • When caffeine isn't enough
« Reply #1162 on: Thu, 26 November 2015, 09:42:59 »
I just teared up a little there.
