Author Topic: EBAY.co.uk: Black AT102W  (Read 2947 times)
fossala
  •  Guest
« on: Fri, 30 March 2012, 16:06:01 »
Not very well listed at102w in black. Only 13gbp including shipping.
http://www.ebay.co.uk/itm/220988698924?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Last Edit: Sat, 31 March 2012, 00:41:26 by fossala »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1 on: Fri, 30 March 2012, 16:17:25 »
umm missing link?
Fight For Freedom. Stand with Hong Kongers
fossala
  •  Guest
« Reply #2 on: Sat, 31 March 2012, 00:41:10 »
Quote from: hazeluff;561840
umm missing link?
Sorry. Updated OP.
Offline javifast
« Reply #3 on: Sat, 31 March 2012, 10:01:56 »
I think, that's a good deal.
Too many keyboards....
fossala
  •  Guest
« Reply #4 on: Sat, 31 March 2012, 10:53:49 »
Quote from: javifast;562508
It is a very good deal, who bought it then?
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #5 on: Sat, 31 March 2012, 11:22:59 »
I didn't...I was tempted, then I think "ISO" and I forget about it.
fossala
  •  Guest
« Reply #6 on: Sat, 31 March 2012, 11:40:53 »
I was tempted but then I remebered I hate ISO, pad printed keycaps and black alps.
Offline koralatov
« Reply #7 on: Sat, 31 March 2012, 15:39:43 »
The seller had two, and I grabbed one. *I love the white ALPS in my AEKII, so thought I’d try the black ones since they were so cheap. *If it works out, I’ll use it with my PC at work. *If not, I’ll just sell it on.  Thanks for the heads up.
Offline andrewjoy
« Reply #8 on: Thu, 05 April 2012, 03:50:25 »
Hmm must resist the itch to buy alps !!!!
I am tempted after i striped several tracks on my Dell removing the switches to paint the rusty plate ( crappy soldering by dell bending the pins !)
Offline koralatov
« Reply #9 on: Thu, 05 April 2012, 04:28:46 »
Quote from: andrewjoy;567444
The seller has none left now, so no willpower required to resist them!  I noticed that there’s rusting on the plate under the keys.  I wasn’t very impressed by that, especially since the keyboard is in otherwise excellent condition.  I’ll strip it down and clean the rust out some time.
Offline andrewjoy
« Reply #10 on: Thu, 05 April 2012, 04:42:28 »
when you de solder keep an eye on the pins
they are bent over and its takes time to de solder them as you have to make sure there is no solder under the pin as you will lift the track i would get some de soldering braid and use that after use have sucked most of it up with a sucker
you may also want to add fresh solder to each switch before de soldeing as fresh solder has a much lower melting point
i have some vv narrow wire and am going to try to fix the tracks on mine
