Author Topic: Model M Cracked Frame Repair  (Read 131215 times)
Offline rknize
    • metaruss
« on: Fri, 06 April 2012, 14:15:48 »
One of the Model M failures that is harder to deal with is cracking of the plastic plate that contains all of the key cap cylinders.  Unicomp refers to this as the keyboard "frame".  Severe cracking is usually caused by extended use with broken rivets and/or severe abuse.  Between each row are channels where the plastic is thin so that the frame can follow the contour of the backplate.  The plastic gets brittle over time and will crack along these channels.
Your choices for dealing with frame cracking are:
1) Find a different keyboard and use this one for parts.
2) Do a bolt mod and swap the frame from another good keyboard.  This only makes sense if you have a good donor and the one you are fixing is more vintage or otherwise has some nostalgic value.
3) Get a replacement frame from Unicomp.  This still requires a bolt mod, but they will sell you the frame for $10.  I assumed that they only stocked the full sized frames, but I was wrong.  They have 84 key frames in stock.  (hmmm...why would they have those?)
4) Attempt to repair the cracks.
The keyboard I was repairing was an SSK, so the only option I thought I had was #4.  I later bought a new frame from Unicomp, but only after I did the crack repair.  I can't tell if the new frame is old stock or if it's a brand-new part.
Testing revealed that the frame is likely made out of ABS.  This makes it a good candidate for gluing, as lots of solvents can cut ABS.  Regular model cement usually has MEK in it, making it an easy choice.  There are other, more aggressive glues out there as well that work well with ABS.  You can also bond ABS with just solvent, but this is tricky as it requires a good fixture to hold everything together.  The result is sometimes more brittle than when using a glue that has a filler, like model cement.
My plan was to cut some long, narrow strips and glue them to the top of the frame along the cracks.  There is plenty of gap between the top of the frame and the bottoms of the key caps.  This turned out to be unnecessary.  All you'll need besides the usual nut-and-bolt stuff is a tube of model cement (the stuff you glue plastic models together with).  It should be easy to find at a hobby or hardware store.  Here are the steps that I followed:
1) Follow the usual procedure for the "Nut and Bolt Mod" and stop after you have driven all of the screws into the frame.  Be extra careful while handling the damaged frame.
2) Now test fit the frame to the backplate.  Leave out the membranes and rubber mat.  You might want to lay a piece of wax paper down over the plate to keep the glue from sticking to it in step 5.  I didn't have any issues, but it's something I thought of afterwards.  Spin a few nuts on along the center and the corners to make sure all of the screws line up well.  Check that the frame is following the contour of the plate.  Look at the cracks and try to get the plastic aligned again so that the top is even.  Usually one side of the crack will be above or below the other.  Some pressure will pop them back in place.
3) Once you are happy, remove the backplate again and set the frame face-down.  Be ready to reassemble them quickly.
4) Lay down a bead of model cement into each channel between each row, completely filling them.  Keep it neat.  Don't get any glue in or around the area where the pivot plate sits.  Don't fill the channel higher than the adjacent ridge or it will squirt out.  I did this to all of the channels, even the ones that hadn't completely cracked yet.
5) Reattach the frame to the plate as you did in step 2.  Add as many nuts as needed to make sure the frame is following the plate contour snugly, especially around areas of severe cracking.  Be sure to check the cracks to make sure the plastic is still aligned.  Pop them back into place as necessary.
6) Once you are happy with it, set the assembly frame-down and leave it for 24 hours.  The glue normally dries quickly, but it takes longer when it can't breath well.
This is after the glue dried.  Kitty finds the result to be satisfactory.
7) The next day, remove the frame from the plate and check your work.  The glue will shrink some as it dries, so you shouldn't have issues with extra glue sticking out.  If you do see glue where it doesn't belong, it can be cut back with an exacto blade and smoothed-out with a paper towel dampened with acetone or MEK (wear gloves).  Be careful not to get solvent where you don't want it.
8) Continue the Nut and Bolt Mod procedure from where you left off.  It's a good idea to test it with a few nuts in place before completely finishing the reassembly.
I was so impressed with how strong the frame was after doing this that I didn't bother gluing any strips on the top.  The reassembled SSK is working well!
Here is a picture of the new frame from Unicomp.  You can see that it has drain channels; something my '93 SSK lacks.  I don't know if this is an NOS part or a new frame for their rumored SSK revival.
Russ
Offline rknize
    • metaruss
« Reply #1 on: Fri, 06 April 2012, 14:58:24 »
Yep, that's good stuff.  it would work well here too, since the filler is what adds strength and it won't shrink.
Russ
Offline hasu
  • @tmk
« Reply #2 on: Sat, 07 April 2012, 05:05:21 »
Also my specific gravity test says barrel plate is ABS and  keycap, slider and case enclosure is NOT ABS(PBT probably). Although I know you guys already know that :)
My repaired plate.
