Author Topic: Filco OEM 104 Key Caps - SP POS Doubleshot Keycaps  (Read 3746 times)
Offline fuah
  • Trade Count: (0)
« on: Thu, 12 April 2012, 08:39:25 »
Hey all,
Spring cleaning continues! I have for sale a few things below. The prices listed below do not include shipping from me in Canada. Send me a PM and I will get you a quote for the cost of shipping.
B. Access-IS/SP Doubleshots + Key Blockers - From the AKEOCT1418/1 - Used, discolored - $0.75 per key + shipping
(Decided to list these seperately from the keyboard because they're in less than perfect shape. I left these in denture cleaner for too long and some of the keys came out discolored)
SOLD: F1 - F8, SPACE, ENTER, BACKSPACE, ALT, TAB, CAPS LOCK, 2xSWITCH COVERS
[ Attachment Invalid Or Does Not Exist ] 48151[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 48150[/ATTACH]
A. AKEOCT1418/1 - Access-IS Keyboard - Dark Grey - Modular PS/2 - 15x6 Matrix - Programmable - Plate mounted MX Black - Used, great condition - $80.00 + shipping
SOLD
[ Attachment Invalid Or Does Not Exist ] 48147[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 48149[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 48148[/ATTACH]
C. Filco OEM caps with legends - Black - 104 key set + red esc - Used - $15.00 + shipping
(Used for approximately one year. A few keys are shiny lctrl has lost some of the legend + factory coating)
SOLD
[ Attachment Invalid Or Does Not Exist ] 48152[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 48153[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 48154[/ATTACH]
« Last Edit: Tue, 01 May 2012, 11:11:38 by fuah »
Offline TheProfosist
  • Trade Count: (0)
  • Custom Layouts Only!
« Reply #1 on: Fri, 13 April 2012, 01:57:21 »
may i ask how you program the keyboard?
fossala
  •  Guest
  • Trade Count: (0)
« Reply #2 on: Fri, 13 April 2012, 02:00:01 »
There is a program (windows 32bit only). It works quite well, you use the gui and then upload it to the keyboard.
http://www.access-is.com/softprog.php
  • Trade Count: (0)
« Reply #3 on: Fri, 13 April 2012, 02:03:01 »
Quote from: fossala;574361
if the program wont run on 64 bit windows im SOL as i dont have any 32bit computers anymore
also since its PS/2 does it work properly when used with a usb adapter like the belkin?
Also would you happen to know if its possible to program layers into it.
« Last Edit: Fri, 13 April 2012, 02:05:13 by TheProfosist »
fossala
  •  Guest
  • Trade Count: (0)
« Reply #4 on: Fri, 13 April 2012, 02:05:20 »
I don't use windows, so I had to pull out a spare hard drive and install windows to play.
Offline Tranquilite
  • Trade Count: (0)
« Reply #5 on: Fri, 13 April 2012, 03:57:51 »
Quote from: TheProfosist
  • Assign scan codes to any key
  • Redefine the key layout with multiple space keys and blanking tiles
  • Define key legends
  • Define momentary and toggle layer shift keys
  • Assign the LED's to any function
  • Enable or disable auto repeat
  • Disable Control + Alt + Delete key combination
  • Set the default Caps Lock & Num Lock states
  • Define MSR operation (where fitted)
I would assume that means layers are a go. As for programming it, you may be able to do that using a virtual machine like XP mode in windows 7, assuming the VM can get proper PS/2 access...
Also, out of curiosity, what profile are the SP double shots from the access board? They look to be the same profile, but I am unsure.
EDIT: Heck, I might as well toss in that I am interested in the ESC, INS, and green F2 key, provided that they are all function row profile.
« Last Edit: Fri, 13 April 2012, 04:08:15 by Tranquilite »
  • Trade Count: (0)
« Reply #6 on: Fri, 13 April 2012, 04:19:38 »
That all sounds great im completely interested. PM Sent.
Offline Nunez
  • Trade Count: (0)
  • BACK!
« Reply #7 on: Fri, 13 April 2012, 04:27:22 »
Quote from: TheProfosist;574364
You could always try Virtual machine with a 32bit OS. Not sure if that'd work or not, not entirely sure.
I miss Ripster :(
HHKB Pro 2 || KBC Poker || Filco MJ2
Offline fuah
  • Trade Count: (0)
« Reply #8 on: Fri, 13 April 2012, 08:05:50 »
My experience with the Access-IS keyboard
  • Programmed over PS/2 under WinXP using Softprog
  • Used it over PS/2 to USB passive adapter under Win7 32bit
Softprog is not user friendly software but it works, it's free, and it's fully featured.
The board looks great with the Filco OEM keys on it. Buy both and I'll discount your purchase (plus you'll save on shipping)!
Offline Jigo
  • Trade Count: (0)
« Reply #9 on: Sun, 15 April 2012, 12:14:55 »
If TheProfosist backs out for whatever reason, I would be interested in the board itself :)
Just shoot me a PM if it becomes available again.
  • Trade Count: (0)
« Reply #10 on: Sun, 15 April 2012, 18:19:38 »
Quote from: Jigo;575287
I passed on it because i dont think its compatible with any of my systems
Offline Jigo
  • Trade Count: (0)
« Reply #11 on: Mon, 16 April 2012, 14:21:11 »
Quote from: TheProfosist;575617
Well hold on a sec, I'd assume this thing would still work witha 64 bit platform once the programming has been pushed to it, no? Does it need some sort of program running constantly to interpret the presses? Or can it work on any platform once configured/programmed?
Edit: After reading more of the site, the board itself has non-volitile memory to store its programming, and I'm pretty sure that once set, it just presents itself as a simple PS/2 keyboard to the computer. The programming determines the macros it sends at a single keypress.
« Last Edit: Mon, 16 April 2012, 14:27:10 by Jigo »
Offline Ascaii
  • Trade Count: (0)
« Reply #12 on: Mon, 16 April 2012, 19:17:47 »
That is correct. Once programmed, it will work in 64bit OS.
Offline fuah
  • Trade Count: (0)
« Reply #13 on: Mon, 23 April 2012, 14:56:52 »
The keyboard and most of these keys are still available!
Offline fuah
  • Trade Count: (0)
« Reply #14 on: Mon, 30 April 2012, 12:15:07 »
Price drop!
Many SP POS doubleshots still available.
« Last Edit: Tue, 01 May 2012, 11:11:58 by fuah »
