Author Topic: HHKB Pro 2 Problem  (Read 1953 times)
Offline MyNameIsFinn
HHKB Pro 2 Problem
« on: Fri, 13 April 2012, 11:21:54 »
The delete key on my hhkb pro 2 doesnt work without me pressing fn, is there any way I can change this it is really annoying
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
Offline sth
  • 2 girls 1 cuprubber
HHKB Pro 2 Problem
« Reply #1 on: Fri, 13 April 2012, 11:22:43 »
RTFM
But seriously, RTFM.
« Last Edit: Fri, 13 April 2012, 11:25:39 by sth »
Offline jooks1184
HHKB Pro 2 Problem
« Reply #2 on: Fri, 13 April 2012, 11:27:45 »
Not sure if this will help but you try flipping the DIP switch to switch the function of the DELETE key?
HHKB Pro 2 Problem
« Reply #3 on: Fri, 13 April 2012, 11:29:19 »
How do I read a manuel that is in a completely different language?
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
Offline sth
HHKB Pro 2 Problem
« Reply #4 on: Fri, 13 April 2012, 11:31:30 »
Flip dat dip!
You have the whole web at your disposal. I don't even own a HHKB and it took me all of two seconds to find that out. I'm overreacting because I'm a nerd, not because you're lazy.
HHKB Pro 2 Problem
« Reply #5 on: Fri, 13 April 2012, 11:32:41 »
Quote from: sth;574620
Flip dat dip!
I already did, does the keyboard have to be unplugged/
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
HHKB Pro 2 Problem
« Reply #6 on: Fri, 13 April 2012, 11:34:14 »
Problem solved, turns out it had to be unplugged
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
Offline o2dazone
HHKB Pro 2 Problem
« Reply #7 on: Fri, 13 April 2012, 11:35:55 »
for Macs I have to unplug it and plug it back in to re-recognize the dipswitches. I didn't find this out until I got a shorter cable that required I unplug it to easily flip the board around haha.
Offline sth
HHKB Pro 2 Problem
« Reply #8 on: Fri, 13 April 2012, 13:05:28 »
Cool, glad you figured it out. I'm just bitter cause I haven't bought a HHKB yet.
