Author Topic: Lime Green PBT Key Caps  (Read 11722 times)
Offline funxion
« on: Thu, 26 April 2012, 18:59:13 »
Anyone know where I could possibly get my hands on some?
Crush80
Filco MJ2 TKL
Offline snowboarder3
« Reply #1 on: Thu, 26 April 2012, 19:05:05 »
I've seen a set of light green KBC PBT caps on taobao before but I've never seen another set. I bought the light blue version :)
Offline funxion
« Reply #2 on: Thu, 26 April 2012, 19:21:56 »
For reference, here's a picture of what color I'm looking for. I know these are Topre key caps, but someone has GOT to have them for Cherry's...
reaper's Photo:
« Last Edit: Fri, 27 April 2012, 17:04:32 by funxion »
Crush80
Filco MJ2 TKL
Offline reaper
« Reply #3 on: Thu, 26 April 2012, 20:56:02 »
^ That's my pic and you should try WASDkeyboards.com.
Din Eli
Offline tobr1an
« Reply #4 on: Thu, 26 April 2012, 20:56:42 »
WASDKeyboard give out PBTs?
Offline reaper
« Reply #5 on: Thu, 26 April 2012, 20:57:26 »
Nope but perhaps they can try to match the color. lol
Din Eli
Offline alaricljs
  • I be WOT'ing all day...
« Reply #6 on: Thu, 26 April 2012, 21:04:04 »
WASD is trying to have PBT available ~june timeframe, he has a color list somewhere.
Filco w/ Imsto thick PBT
Offline emptythecache
  • out.
« Reply #7 on: Fri, 27 April 2012, 07:05:40 »
i was under the impression WASD's green abs caps are more kelly than lime. I was going to buy a set to put on my blue filco a while ago, but decided against it because i didn't like the (perceived?) shade.
Offline funxion
« Reply #8 on: Fri, 27 April 2012, 17:03:30 »
Quote from: reaper;583372
I know it's your pic :) I'll add a photo credit, sorry!
And I looked, it's not the exact green I'm looking for. Someone had a white HHKB with lime green key caps on it - those are the ones I'm looking for.
Crush80
Filco MJ2 TKL
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Fri, 27 April 2012, 17:39:12 »
WASD current green is indeed more kelly than lime. Try qtan, they are offering a dyeing service and might be able to match that shade. I wish there were some more 'neon' shades readily available in MX too, seems all the good colors are Topre only.
Offline Glockateer
« Reply #10 on: Fri, 27 April 2012, 18:27:51 »
Those lime green topre keycaps look great. I'm jelly. I can't even afford a topre keyboard. = p
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #11 on: Fri, 27 April 2012, 19:03:57 »
Quote from: lysol;584258
Me, too! I want some vibrant stuff and not so much of this dullness.
« Reply #12 on: Fri, 27 April 2012, 19:09:23 »
Maybe it will catch on as more 80's kids are established have money for all these stuffs? Hey stuffy old guys, beige is dead, you hear me?
Offline martinyeah
« Reply #13 on: Sun, 13 May 2012, 15:05:34 »
yellow is good too !
Offline funxion
« Reply #14 on: Sun, 13 May 2012, 20:32:45 »
I want an extremely vibrant lime green. Pretty much neon/highlighter/whatever-you-want-to-call-it.
I need something that pops out, but not too yellow! Need to flow with a white case. Really wish someone would start a GB for neon-colored sets.
Edit: The picture I posted of reaper's Topre keys are perfect, but it could be slightly more vibrant.
Crush80
Filco MJ2 TKL
Offline AKIMbO
  • HHKBro
« Reply #15 on: Sun, 13 May 2012, 22:01:46 »
You could try to Rit dye some white key caps.
| KBD75 (box reds)
Offline funxion
« Reply #16 on: Sun, 13 May 2012, 22:49:50 »
Quote from: AKIMbO;592041
Don't really feel like putting out $40-$50 to mess up :/
Crush80
Filco MJ2 TKL
Offline baldgye
  • Will Smith Disciple
« Reply #17 on: Thu, 17 May 2012, 04:50:26 »
yeah, from spending a fair bit of time creeping these boards all attempts at dying caps have mostly turned out pretty poorly... and my own experiance with dying plastics with rit dye has left me with pretty poor results
Offline MMB
« Reply #18 on: Fri, 18 May 2012, 02:25:32 »
Might I suggest purchasing a blank white PBT set from Feng, and using some rit dye to get the color you want. It's pretty easy. You can test it out on some cheap abs caps first.
Offline captain
« Reply #19 on: Fri, 18 May 2012, 02:56:28 »
Buy a HHKB and reaper's keycaps–problem solved!  :-)
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline longweight
  • philanthropist
« Reply #20 on: Fri, 18 May 2012, 06:35:16 »
Is reaper selling his?
Offline funxion
« Reply #21 on: Fri, 18 May 2012, 22:38:18 »
Quote from: MagicMeatball;595188
Don't really have the time or money to waste on "testing" dyes and such.
I may just have to buy a set from qtan and use his dyeing service at some point!
Crush80
Filco MJ2 TKL
Offline reaper
« Reply #22 on: Sat, 19 May 2012, 09:19:27 »
Quote from: longweight;595238
No, he is not. =D
Din Eli
