Author Topic: I can't tell much difference between black and red switches  (Read 3418 times)
Offline Crake
I have a been using two black switch keyboards over the last few weeks.  I was at a computer show today and Corsair had a display with two of its keyboards.  I typed on them for a second or two and asked if they were black switches (they felt like my keyboard) and the representative said, "no, they are red" and then I remembered that Corsair uses red.  I typed some more to compare and I guess they seemed lighter.  When I got home, I tried my keyboard, and I guess it seemed stiffer. But in both cases, the differences seemed slight - so slight that I am not sure if I would have noticed had I not known the reds should be lighter and was therefore expecting it.
I tend to bottom out a lot - is that why I do not notice much difference? Or do others not really notice that much of a difference either?
« Last Edit: Thu, 03 May 2012, 15:38:11 by Crake »
Offline ch_123
« Reply #1 on: Thu, 03 May 2012, 16:21:36 »
If you're pressing so hard on blacks that you bottom them out constantly, then I'd say a lot of switches will feel the same :D
At the same time, there's a big difference between pressing a few keys while standing at a booth, and sitting down and doing some serious typing on a keyboard. You need a day or two of regular usage on a keyboard to make a useful opinion (although there are cases where you will realize from one press that a keyboard is either amazing or terrible, but it's not always clear cut)
Offline fstop
« Reply #2 on: Thu, 03 May 2012, 16:25:47 »
What were you typing on before? If you came directly from rubber dome it takes some time to feel the subtleties on each switch, and even mechanical switches in general. I remember with the first few hours of my mechanical I thought the whole thing was overhyped. Then the next day I went back to my rubberdome, and I noticed the world of difference.
Reds are quite different from blacks over extended use.
CM Storm Quickfire MX Reds
CM Storm Quickfire MX Blues
Filco Majestouch-2  MX Browns
RealForce 87uw uniform 45g
Offline Squelos
« Reply #3 on: Thu, 03 May 2012, 17:47:54 »
Most people around me are like : blues suck, too much noise. Reds arent that bad, but nothing that could justify paying 100€ for a keyboard.
With Topre's, most were like : "wtf ? Feels just like any keyboard, but I prefer laptop style keyboards."
But then a lot of them are "fellow" developers, which dont type a lot :D Made my laugh when I saw this guys brand new laptop board. Considering the laptop is actually 3years old, and i have exactly the same, that I use just as he does : for school, at school.
My spacebar is shiny as hell, as are most keys, his are nearly new :D
Offline o2dazone
« Reply #4 on: Thu, 03 May 2012, 17:52:03 »
the only difference between reds and blacks are force. Corsair is pcb mount, which...doesn't change the force, but your fingers feel like they'll be doing slightly more work because of the pcb flexing. This might make your blacks and reds feel similar, especially if your black switches were plate mount.
Offline Crake
« Reply #5 on: Thu, 03 May 2012, 18:02:53 »
Quote from: o2dazone;589434
Mine now is WASD and I was using a Mionix for a few weeks.  Are both of those plate mounted?  So the Corsair's red takes more force than a plate mounted red?  A WASD red would be much lighter in force needed?
Offline o2dazone
« Reply #6 on: Thu, 03 May 2012, 18:11:16 »
Actually I was incorrect in my first post, the Corsair K60 is plate mount. So is the WASD and the Mionix. Which, overall, will take a little personality out of the switch, but their linear so there's no much personality to begin with. In your case, with them all being plate mount, the only difference is 5-10g of weight difference. Which may not be noticeable typing on them side by side for a minute or so, but requires shorter typing session of about 5 to 10 minutes before feeling the differences in weight.
Offline Crake
« Reply #7 on: Thu, 03 May 2012, 19:33:03 »
Quote from: o2dazone;589460
What are pros and cons of using a plate mount versus pcb mount?
Offline pitashen
« Reply #8 on: Thu, 03 May 2012, 20:21:01 »
Quote from: Crake;589501
no pros and cons, only personal preference.
Offline Tranquilite
« Reply #9 on: Sun, 13 May 2012, 04:26:49 »
Plate mount are sturdier (I guess), and PCB mount are easier to mod.
