Author Topic: Price Check- What's it Worth?  (Read 4291912 times)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • Trade Count: (0)
  • ʕ ͡·ᴥ ͡· ʔ
Re: Price Check- What's it Worth?
« Reply #1250 on: Fri, 21 June 2013, 18:15:42 »
Price check on the mintgum wasd mx ?
Thanks in advance
Offline BunnyLake
  • The OG HHKB Master
  • Trade Count: (3)
  • X
« Reply #1251 on: Fri, 21 June 2013, 18:26:45 »
  • Trade Count: (3)
« Reply #1252 on: Fri, 21 June 2013, 18:49:22 »
  • Trade Count: (0)
« Reply #1253 on: Fri, 21 June 2013, 18:55:43 »
What's a fair price to charge for a 2 month old ducky shine 2 with clears?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • Trade Count: (0)
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #1254 on: Fri, 21 June 2013, 19:23:49 »
Offline ping111
  • Trade Count: (0)
« Reply #1255 on: Fri, 21 June 2013, 21:39:12 »
Something that I can afford.  PM me and we'll talk.
In My Possession:
Max Keyboard Nighthawk X8 Mechanical Keyboard - Cherry MX Brown - Blue LED Backlighting
Wanted:
KBTalking PURE - Tenkeyless - Cherry MX Brown - Green LED Backlighting
Offline Hente
  • Trade Count: (0)
  • huehuehue
« Reply #1256 on: Sat, 22 June 2013, 21:32:24 »
Is pricing a dead Dell AT101 (spilled soda on it) or it's keycaps at $10 good?
Possible at all that I could get more?
How much should I price the harvested working switches for (black alps, not sure if complicated or not)?
Anyone?
If spilling soda on it killed it then how are the switches still good?  Did you magically only spill on the controller or something?
To be honest I don't really know how PCBs or switches work, so I just assumed that some of the switches were good if the soda did not hit them.
Offline elton5354
  • Trade Count: (0)
« Reply #1257 on: Sun, 23 June 2013, 16:51:17 »
What's a reasonable price for Raspberry Pi 512 ram with case and SD card w/ software? Only turned it on couple times.
Offline Smeagol_RP
  • Trade Count: (0)
  • your ad here
    • Steam
« Reply #1258 on: Mon, 24 June 2013, 21:38:13 »
How much can I ask for 90 plate mounted MX blacks? Used for about 8 months.
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
  • Trade Count: (0)
« Reply #1259 on: Mon, 24 June 2013, 21:58:39 »
I always say $0.50 per switch is a fair price for used switches.
Offline Smeagol_RP
  • Trade Count: (0)
  • your ad here
    • Steam
« Reply #1260 on: Mon, 24 June 2013, 22:16:07 »
Thanks for the tip. It's more than I thought.
Offline jonathanyu
  • Trade Count: (0)
« Reply #1261 on: Mon, 24 June 2013, 22:44:56 »
Hi everyone ;)
I have a ducky shine 2 78version. I am pending on sell it, but I don't know how much should it be.
It bought form tigerimports.net in 03-06-2013.  When I bought it, it is $147.
It is 80% new, I have used it for 3 months.
"1"key in row4 is not smooth on the top(like some sand on the keycap, not in the switch), but the whole keyboard work well.
All of the stuff that come with the keyboard is include except the key chain.(A ducky key cap puller, red wasd key cap, a ducky USB cable(one end is mini usband one end is regular male usb), and a ducky magic tap.)
It also come with the original case, but it is a little bit broken.
So how much should it be? ;)
« Last Edit: Mon, 24 June 2013, 22:51:17 by jonathanyu »
Offline kenmai9
  • Unicornforce
  • Trade Count: (0)
  • Skrrr
« Reply #1262 on: Mon, 24 June 2013, 23:02:08 »
HPE 104 - MX Brown. Retailed at $90.
No one seems to want to buy it from me, even for a hugely discounted price.
Offline Photoelectric
  • Trade Count: (1)
« Reply #1263 on: Mon, 24 June 2013, 23:15:23 »
It's probably because of the full size :(  You might find some buyers on other sites, where people are not as much in "the tinier the better" clubs :)
Offline Kayliss
  • Trade Count: (0)
« Reply #1264 on: Tue, 25 June 2013, 05:50:31 »
Unused WYSE tsangan? Anyone remember the techkeys price?
Offline MrexD
  • Trade Count: (0)
  • aka mrwoodyxd
« Reply #1265 on: Tue, 25 June 2013, 06:14:38 »
I'm thinking of selling my 6GV2 with MX Blacks for spares.
Hopefully going to be upgrading it to something with Reds but i don't want this to go to waste.
Think it'd be better just to sell them as switches? If i learn how to desolder them etc.
Pok3r MX CLears
  • Trade Count: (1)
« Reply #1266 on: Tue, 25 June 2013, 11:24:59 »
If you're happy with the board and just want something with reds you could just swap the springs for some 62g springs from originativeco.com. These are very similar to springs from reds and would be practically exactly the same. The would involve desoldering and resoldering but would probably work out much, much cheaper than buying a new board.
There's no point buying soldering equipment so you can sell the blacks - you wouldn't get very much for them.
TL;DR sell the board or swap the springs. Don't desolder and sell the switches.
Offline MrexD
  • Trade Count: (0)
  • aka mrwoodyxd
« Reply #1267 on: Tue, 25 June 2013, 12:00:23 »
Yea, i was thinking about swapping the springs. It'd be a learning process for sure. However, i'll be looking to replace it anyways. No need for full size board :)
Thanks for the input though!
Pok3r MX CLears
Offline tgujay
  • Trade Count: (0)
« Reply #1268 on: Tue, 25 June 2013, 12:26:33 »
I love them Fullsize if you know what I mean ;)
Gotta collect them all
Offline jonathanyu
  • Trade Count: (0)
« Reply #1269 on: Tue, 25 June 2013, 13:44:05 »
Can some one help me? I have a ducky shine2 78 version. What it's worth?
Offline IvanIvanovich
  • Mr. Silk Underwear
  • Trade Count: (0)
« Reply #1270 on: Tue, 25 June 2013, 15:41:10 »
Maybe you can explain what you mean "It also come with the original case, but it is a little bit broken." first? If it is damaged the value is effected quite a lot. If it is not damage really, then I suspect you can probably get at least what you paid it for since Ducky 78 was limited edition and seem to be out of stock just about everywhere.
Offline jonathanyu
  • Trade Count: (0)
« Reply #1271 on: Tue, 25 June 2013, 16:00:43 »
What I mean is the box of the keyboard, not the body of the keyboard.
this is the picture of the box. I don't know what it should be called...so I just put up the picture
Offline kenmai9
  • Unicornforce
  • Trade Count: (0)
  • Skrrr
« Reply #1272 on: Tue, 25 June 2013, 19:34:36 »
Poker 2 with MX ghetto greens
Poker 2 with MX Black
  • Trade Count: (0)
« Reply #1273 on: Tue, 25 June 2013, 19:39:56 »
Oh just the display box, probably not a huge deal to most people, shouldn't effect the value really. So like I said before you should probably be able to break even on the Ducky 78 or pretty close to it since it was a limited edition.
Offline jonathanyu
  • Trade Count: (0)
« Reply #1274 on: Tue, 25 June 2013, 20:31:06 »
;)Thanks a lot
Offline ImperfectLink
  • Trade Count: (0)
« Reply #1275 on: Sun, 30 June 2013, 15:36:36 »
Mint iPod 4G 32GB barely used.
Offline pandather
  • Formerly gopanthersgo1
  • Trade Count: (0)
  • Hello, I'm Mark.
« Reply #1276 on: Mon, 01 July 2013, 21:01:56 »
Cherry G80-8200 with 2 sets of pbt keys, 2 cases, and no switches?  If I were to harvest switches off a cheap board, how much?
Offline smknjoe
  • Trade Count: (0)
« Reply #1277 on: Mon, 01 July 2013, 21:07:11 »
Just got a a used IBM M for the fairly decent price of $50 (looks new.) It seems like the price of these boards has almost doubled in the last year. Is my observation correct and what is the going price?
SSKs for everyone!
Offline amzee
  • Trade Count: (0)
« Reply #1278 on: Tue, 02 July 2013, 14:20:51 »
QFR with blues, with replacement black case, keycapsless (or including keycaps, but some are quite shiny and worn, so I thought it might be best to not include them)
KBT pure with reds, also keycapless (PBT, so it's not shiny, but the letters are really worn since they're pad printed, again, not sure if I should include them)
Offline Jette
  • Trade Count: (0)
« Reply #1279 on: Tue, 02 July 2013, 14:36:11 »
I'm going to sell a few keyboards to raise money for yet more keyboards. I want to list these, but I don't know what they're worth. I washed all of these in a bucket of simple green overnight, and spritzed the electronic ones with a bit of de-oxit just to be sure, so they're devoid of cracker crumbs and the plague.
1) A Unicomp 104-key buckling spring USB keyboard, in matte black with grey keycaps. It's in pristine condition, almost unused; I never got to use it much because I kept waking the family up at 2:00 in the morning. :/ No packaging with this one, just the keyboard.
2) A black Happy Hacking Keyboard Professional, with topre capacitative switches. Comes with all original packaging, documentation, and removable USB cable. I used it for about a year before switching back to larger keyboards, so it has some minor signs of use, but functions perfectly and has no noticeable defects.
3) An IBM Model M for terminals. Part No: 1392595, I.D. No: 5213912, Date: 02-07-92 (!), Plt No: F7; Model M. No original packaging, just a brown box. This thing has a connector that looks more like an old telephone line than any modern digital connector, and has a plethora of strange, antiquated keys that only make an inkling of sense to me through using emacs for too long. More of a historical oddity than a usable keyboard, though I suspect some brave, atavastic soul willing to sauter the connection and write his own drivers the way they did in ye olde CompSci could make it usable with a modern computer. Also good for salvage, if you'd rather have a "Reset" or "Send" key instead of an Alt, or if you'd like a "Jump" key to put where escape goes so you can pretend it deploys a parachute.
4) A Topre RealForce 104-key in very good condition. I've used this board for about a year, and it works as well today as it did when I bought it. The only sign of use is some shiny texture on the spacebar where my thumbs rest. All original packaging and documentation.
I may not list all of these, depending on the price estimate. I won't be listing them on GH, because I don't have enough forum posts to make a classified ad. More likely, they'll be on eBay. I won't link any sales I make since it's probably against the rules.
Offline Frodoco
  • Trade Count: (0)
« Reply #1280 on: Tue, 02 July 2013, 14:43:06 »
Hello,
I have a Filco Majestouch with Brown Switches and the standard US-Layout. It has almost no signs of usage, but I don't have the original packaging anymore. What's it worth?
Thanks in advance for your help. :)
« Last Edit: Tue, 02 July 2013, 14:49:22 by Frodoco »
Offline smknjoe
  • Trade Count: (0)
« Reply #1281 on: Tue, 02 July 2013, 14:50:29 »
Hello,
I have a Filco Majestouch (the first version, not the second) with Brown Switches and the standard US-Layout. It has almost no signs of usage, but I don't have the original packaging anymore. What's it worth?
Without pics and assuming it has a lot of usage (even though it doesn't look like it) $85-$115 depending on the condition? You can get em new for $150.
SSKs for everyone!
Offline Tango
  • Trade Count: (0)
« Reply #1282 on: Wed, 03 July 2013, 15:37:33 »
I just got a HHKB lite 2 with japanese layout, brand new, will €60(I'm in France) or $80 be a good price?
Offline Chewy
  • Trade Count: (0)
« Reply #1283 on: Sat, 06 July 2013, 15:22:41 »
Hi,
I've got a mint (unboxed) Microsoft Natural Keyboard Elite UK, I've seen it mentioned a few times on here, just wondering if these are worth anything?
Thanks,
Chewy
Offline davkol
  •  Post Editing Timeout
  • Trade Count: (0)
« Reply #1284 on: Sun, 07 July 2013, 08:42:35 »
People sell them for $30 @ eBay. There are some hardcore fans of that design.
Offline CalmB4tehPwn
  • Trade Count: (0)
  • Demon of the Fall
« Reply #1285 on: Mon, 08 July 2013, 08:10:05 »
I've got a used Razer Blackwidow (retail at $99), with a little bit of shine on the space bar, and the cabling, near the termination point at the keyboard end, came twisted from the factory. Unfortunately, I play in a recliner with keyboard in my lap, so after about 5 months lifting it to my lap and placing it back, the twist turned into a short. About once every two days, bending the cable the wrong end near the base, I get a BSOD.
Definitely a cable issue, and an absolutely great keyboard otherwise.
Price check?
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
« Reply #1286 on: Mon, 08 July 2013, 08:11:03 »
Price check?
Like $60 shipped. Most people around here hate anything Razor
Offline davkol
  • Trade Count: (0)
« Reply #1287 on: Mon, 08 July 2013, 08:33:12 »
Yep, it's more or less about one hundred switches that need to be desoldered for most people around here.
  • Trade Count: (0)
  • Demon of the Fall
« Reply #1288 on: Mon, 08 July 2013, 08:45:50 »
I've definitely seen the light as far as Razer goes. I've moved on. Still looking for an alternative for the Razer Mamba however. This mouse has treated me well
Offline do_Og@n
  • Trade Count: (0)
« Reply #1289 on: Tue, 09 July 2013, 01:22:09 »
As far as the razor goes you might be better off either selling it on Ebay or harvesting the switches, stabilizers, and maybe keycaps and selling them all separate. You could even sell the LED's...
As far as the mouse goes I would try either the Logitech G400, G400s, Razer Deathadder, CM Storm Spawn, or Logitech G500. I personally use the Logitech G400s and LOVE IT!!!! It may be optical but it has no built in acceleration which makes it awesome for gaming. I also use trackballs but we won't go to far into that. ;)
Offline fredb1969
  • Trade Count: (0)
« Reply #1290 on: Tue, 09 July 2013, 09:08:02 »
Hi everyone - I've dug up an old IBM Model M "SSK" and will be selling it soon. It's used but in great condition and hasn't ever been disassembled.
What's it worth?
Specs:
Part No: 1391472
ID No: 2099875
Date: 02SEP87
Plt No: F2
Model: M
Manufacturer: (C) IBM Corp. 1984
Thanks in advance.
Offline tgujay
  • Trade Count: (0)
« Reply #1291 on: Tue, 09 July 2013, 09:17:42 »
What's it worth?
Specs:
Part No: 1391472
ID No: 2099875
Date: 02SEP87
Plt No: F2
Model: M
Thanks in advance.
$150 plus easily but depends on the condition.
Offline remedyhalopc
  • Trade Count: (0)
« Reply #1292 on: Wed, 10 July 2013, 22:06:45 »
Offline Masterchief79
  • Trade Count: (0)
« Reply #1293 on: Fri, 12 July 2013, 04:14:16 »
Compaq-branded G80-11800 with lasered keycaps, MX Browns and a Trackball?
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
Offline Hypersphere
  • Trade Count: (0)
« Reply #1294 on: Sun, 14 July 2013, 12:28:36 »
What's it worth?
Specs:
Part No: 1391472
ID No: 2099875
Date: 02SEP87
Plt No: F2
Model: M
Thanks in advance.
Interested if it is in excellent condition. Pics?
Offline Merloobi
  • Trade Count: (0)
« Reply #1295 on: Sun, 14 July 2013, 19:42:52 »
Anyone have any idea what an Optimus Maximus would be worth?
I have one sitting in my closet with the original box and all of its accessories. Used it maybe twice.
Offline grave00
  • Trade Count: (0)
« Reply #1296 on: Sun, 14 July 2013, 23:17:32 »
ssk one piece keys
Offline smknjoe
  • Trade Count: (0)
« Reply #1297 on: Sun, 14 July 2013, 23:21:26 »
Up to $150.
SSKs for everyone!
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
« Reply #1298 on: Sun, 14 July 2013, 23:27:16 »
ssk one piece keys
What's the date of manufacture?
Offline grave00
  • Trade Count: (0)
« Reply #1299 on: Mon, 15 July 2013, 00:39:52 »
[/quote]
