Author Topic: [GB] Red Alert Round 2: COMPLETE  (Read 313346 times)
Offline All The Fire
Red Alert Round 2 Order Thread [Order Submitted to SP!]
« Reply #250 on: Sun, 10 June 2012, 21:51:18 »
Yeah the pure. I got it over the Poker for the Esc and funtion layout and figured the shift key wouldn't pose any problems due to the Tsangan kits, completely forgot about the tilde. >.< There's also a serious lack of novelty keys in that profile to cover for it.
I guess I can just put a star/diamond key there.
« Last Edit: Sun, 10 June 2012, 21:54:49 by All The Fire »
Offline KylJoy
« Reply #251 on: Sun, 10 June 2012, 21:52:39 »
Quote from: DanGWanG;610668
If we can work in the front printing, I would also be interested in that.
Always for me.  I think it should be standard.
Offline MarkPharaoh
« Reply #252 on: Sun, 10 June 2012, 23:49:02 »
Hi, my order:
1x Red Alert
1x Tsangan White
Thanks.
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline duc_nckt
« Reply #253 on: Mon, 11 June 2012, 05:33:02 »
order more order more :fencing::fencing::fencing::fencing:
Offline emptyk
« Reply #254 on: Mon, 11 June 2012, 09:23:18 »
The OP has 12 uploaded pictures.  2-4 show the gray modifiers.  Will the actual color be closer to pictures 2 and 3 (which show a tan or beige hue) or closer to pictures 4 and 5 (which show more of a true gray color under the flash)?  Pictures 2 and 3 look closer to the mock-up shown in picture 7, which I prefer.
Thanks.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #255 on: Mon, 11 June 2012, 10:08:47 »
Pictures 2-4 are of the exact same set.  2-3 are taken under more natural lighting and the colors of the modifiers might be off-set a little due to the creamy white Filco case.  In any case, picture 7 is a representation/mock-up but 2-4 is what it will really look like under different lighting and keyboard conditions.
Offline remmeh
« Reply #256 on: Mon, 11 June 2012, 11:49:48 »
My order:
1x Red Alert
1x Red Modifier
Offline noir
« Reply #257 on: Mon, 11 June 2012, 12:23:54 »
1x Red Alert
1x Grey Modifier
1x Tsangan Grey
1x Iso
Offline DanGWanG
  • Higher Standards
« Reply #258 on: Mon, 11 June 2012, 12:47:50 »
16 more orders on the tenkey please =)  I want to hit the next price break!
Do I have to post pictures like I did for the grey modifiers to get this going?!
OK fine...
[ Attachment Invalid Or Does Not Exist ] 52723[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 52724[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 52725[/ATTACH]
Offline AKIMbO
  • HHKBro
« Reply #259 on: Mon, 11 June 2012, 12:48:09 »
Rag...you should check out tsangan's Cream Cheese & Green issue with center stepped stepped capslock key caps.  SP has their own meaning to center stemmed for stepped caps locks.
| KBD75 (box reds)
Offline Ragnorock
  • Group Buy Guy
« Reply #260 on: Mon, 11 June 2012, 12:56:15 »
Yeah that happened with round 3 or something like that. If anything, they will get a thorough reminder on what we want for this group buy.
Offline Ragnorock
  • Group Buy Guy
« Reply #261 on: Mon, 11 June 2012, 14:54:22 »
Update: Center stemmed stepped caps lock keys are not possible according to Melissa, so we will not be offering them in this set. I assume Tsangan isn't going to be happy about that when he hears that his CCnG set won't be getting them either. I will be revising the base set so that just the spare Geek Hack key Esc is included and not the stepped caps that is impossible. That also means that the proposed change to the mod sets to add a stepped caps is no longer feasible and that change will not be made. The off center stem stepped caps will remain in the tsangan kit however. Expect the update to the OP when I get the revised quotes from Melissa.
Dave out
« Reply #262 on: Mon, 11 June 2012, 15:16:23 »
Front printing?
Only thing holding me back from ordering.
Offline Ragnorock
  • Group Buy Guy
« Reply #263 on: Mon, 11 June 2012, 16:09:53 »
Front printing is pad printing... and adds significant cost. I really don't want them personally but the bigger problem is that so many orders have been taken already I don't want to bump prices. If everyone was to say the want them then fine but I never got the memo that they were supposed to be and its awfully late to be asking those sorts of changes. I said the same about the center stem stepped caps but was working on getting approval from the larger orders till sp said no. That won't work here because unlike the mod kits there are plenty of just base kit orders that would need to sign off on it too.
« Reply #264 on: Mon, 11 June 2012, 16:15:48 »
No memo? You said this was getting front printing since the other set.
Oh well.
iirc, it added a dollar to CCnG. But if you don't want to do it, I can't force you.
Offline longweight
  • philanthropist
« Reply #265 on: Mon, 11 June 2012, 16:45:18 »
So the Tsangan kit would work on a Choc Mini with a base set?
Offline Ragnorock
  • Group Buy Guy
« Reply #266 on: Mon, 11 June 2012, 19:12:32 »
Quote from: demik;610270
Going to front print sys req and break?
Turned out looking great on CCnG set.
This is the first I heard of it. Note no mention of it in the OP or in the interest check thread... I'd like to see a quote of where I said that. In the Ragnarok group buy, I said that the "Print" key would be fixed for the next round, nothing else. Again, the only ones fighting for it are you, Dan and Kyljoy. I need more than the desires of 3 people to add a dollar to 150-200 orders. The way Melissa made it sound in the email made it seem like it would be more than that but I'll ask anyways. Also since I don't want to have a set of 3 pad printed keys and the rest doubleshots they'd either have to be 3 additional keys or doubleshots that received just the side printing as pad printing. Not sure if that is even possible or what the cost difference is.
@ Longweight, yeah I'm pretty sure. I don't have one though so I'm not exactly sure what the requirements are. Others will know better.
Offline duc_nckt
« Reply #267 on: Mon, 11 June 2012, 22:58:36 »
I want to tkl the next price break!
Offline Ragnorock
  • Group Buy Guy
« Reply #268 on: Mon, 11 June 2012, 23:15:34 »
Its almost there.
OP Updated! 5 days left! GET EM BEFORE YOU HAVE TO BUY LEFTOVERS!
« Reply #269 on: Mon, 11 June 2012, 23:21:53 »
Quote from: Ragnorock;611579
uh, i just told you the cost.
tsangan posted pictures of what i was talking about.
a print screen doubleshot keycap with "sys req" front printed. and a pause doubleshot key with break front printed
but again, i feel like im just wasting my time asking for this.. so just forget it.
Offline whiskerBox
« Reply #270 on: Mon, 11 June 2012, 23:23:53 »
Quote from: demik;611757
All the new sets should have this
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Ragnorock
  • Group Buy Guy
« Reply #271 on: Mon, 11 June 2012, 23:26:17 »
I was unaware that those keys were doubleshots that had pad printing too. I thought the whole thing was pad printed, which I wasn't interested in. I'll ask for the quote from Melissa then and see if we can substitute that for the decrease in cost from losing the stepped caps. The price would probably stay the same if the stepped caps is gone.
« Reply #272 on: Mon, 11 June 2012, 23:27:57 »
oh trust me, i wouldnt have asked for pad printing on a complete doubleshot set. that'd be stupid.
Offline Ragnorock
  • Group Buy Guy
« Reply #273 on: Mon, 11 June 2012, 23:30:30 »
Yeah man that's what I was thinking. Thus my responses. Was like lolwtfnoplz.
« Reply #274 on: Mon, 11 June 2012, 23:32:27 »
now tell me that doesn't look nice tho?
if i may suggest. dont do the same color as legends. for red legends, do black text. for white legends, do grey text. or something similar
Offline Ragnorock
  • Group Buy Guy
« Reply #275 on: Mon, 11 June 2012, 23:35:37 »
Eeeeh, that's pushin it. I like it to be clean and adding a 3rd color that's only on 2 keys doesn't sit well with my ocd. I get how that could look pretty sharp, especially since its pretty rare to see a key with 3 colors on it that isn't a dyesubbed image, but I want it to match.
Offline naberius
« Reply #276 on: Tue, 12 June 2012, 00:23:47 »
1x Red Alert
1x Red Modifier
Offline mickd
« Reply #277 on: Tue, 12 June 2012, 05:10:36 »
Good to hear we might be getting the front printed text, definitely looks nicer :)
Offline emptyk
« Reply #278 on: Tue, 12 June 2012, 09:06:36 »
Quote from: Ragnorock;611766
I agree with this wholeheartedly.  My OCD is more severe than yours b/c I think having only two keys with front printing flanking one without front printing would make me nervous LOL.
It does look interesting and unique, however.
I guess I ought to STFU until I place an order though.
« Reply #279 on: Tue, 12 June 2012, 09:19:23 »
Quote from: emptyk;611956
All key sets have this. Or at least 90%.
Offline kaiserreich
  • HHKB Elite
« Reply #280 on: Tue, 12 June 2012, 10:03:30 »
Order sent
Offline Snooter
« Reply #281 on: Tue, 12 June 2012, 10:34:24 »
Just placed my order last night!
2x Red Alert
2x Red Modifier
2x 104
Offline Elrobo
« Reply #282 on: Tue, 12 June 2012, 20:22:59 »
Placed my order for
1x red alert
1x grey modifier
Offline emptyk
« Reply #283 on: Tue, 12 June 2012, 21:40:08 »
Ordered:
1 x Red Alert
1 x Red Modifier
Offline duc_nckt
« Reply #284 on: Wed, 13 June 2012, 05:46:09 »
104 104 :fencing::fencing::fencing::fencing::fencing::fencing::fencing::fencing:
Offline Ragnorock
  • Group Buy Guy
« Reply #285 on: Wed, 13 June 2012, 12:41:48 »
2 sets away from 150! OP updated, had a couple of orders get cancelled so look for your order in the rest if it isn't near the bottom of the list. Making steady progress toward 200, but we've only got a couple of days left so GOGO!
Dave out
Offline Glissant
« Reply #286 on: Wed, 13 June 2012, 12:49:16 »
Did you ever get a definite answer about the legends? Haven't seen an update about that yet =).
Offline Ragnorock
  • Group Buy Guy
« Reply #287 on: Wed, 13 June 2012, 12:54:26 »
I never did get a response from Sixty. I have no means to get in contact with Uranium myself, so if anyone knows him and would be willing to translate a message into Korean for me I'd like to try that. Otherwise it looks like we're stuck with standard legends. I'll send Sixty another reminder.
Edit: Sent him a reminder.
« Last Edit: Wed, 13 June 2012, 13:03:32 by Ragnorock »
Offline MarkPharaoh
« Reply #288 on: Wed, 13 June 2012, 13:04:49 »
Going to sell my Noppoo, so I would like to change my order:
-1 Tsangan White
+1 Red Modifier
« Reply #289 on: Wed, 13 June 2012, 14:04:23 »
Any word on the front printing?
Offline Ragnorock
  • Group Buy Guy
« Reply #290 on: Wed, 13 June 2012, 14:23:18 »
Even with removing the center stemmed stepped caps, its still a $2 increase. Just got the email back from Melissa. Sorry but I'm going to pass on it, its just not worth another $2 increase this late in the ordering process. I'll keep it in mind for the next group buy though, as there'll always be more. Waiting on the quote from Melissa so I can potentially lower the prices now that the center stemmed stepped caps is out.
« Last Edit: Wed, 13 June 2012, 14:27:54 by Ragnorock »
« Reply #291 on: Wed, 13 June 2012, 14:30:25 »
Well that sucks. Thanks anyway.
Offline Ragnorock
  • Group Buy Guy
« Reply #292 on: Wed, 13 June 2012, 14:45:25 »
Sorry man, you had me doing it until I saw how big the price increase was. Decreased the prices on the base set by $1 btw everyone.
Offline AKIMbO
  • HHKBro
« Reply #293 on: Wed, 13 June 2012, 15:13:34 »
Quote from: Ragnorock;612814
Sweet I'm dining like a king tonight on the McDonald's dollar menu then. XD
Any reduction is a good reduction in case you didn't detect my sarcasm in the above sentence.
| KBD75 (box reds)
Offline Ragnorock
  • Group Buy Guy
« Reply #294 on: Wed, 13 June 2012, 16:37:02 »
Yeah it saves everyone money, something I like doing much more than increasing prices. >.>
Offline kaiserreich
  • HHKB Elite
« Reply #295 on: Wed, 13 June 2012, 18:30:12 »
Quote from: Ragnorock;612750
Pretty hard to get him via PM :(
Maybe try a public shout-out as a last resort?
Offline inlikeflynn
  • file not found
« Reply #296 on: Wed, 13 June 2012, 18:45:52 »
Quote from: kaiserreich;612981
Or email him. anyone who bought the original set directly from him has an email address in their Paypal history...assuming it is the one he uses for everyday stuff.
I can look through my PP history late tonight if no one else digs it up for you first
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline mark0331
« Reply #297 on: Wed, 13 June 2012, 18:57:13 »
1 x Red Alert
1 x Red Modifier
Thanks
Offline nntnam
« Reply #298 on: Thu, 14 June 2012, 02:54:14 »
In for
1 x Red Alert
1 x Red Modifier
Thanks.
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline leeN
« Reply #299 on: Thu, 14 June 2012, 03:21:18 »
As this Groupbuy is closing soon:
Is there somewhere a complete list of keyboards which require the Tsangan addon kit?
