Author Topic: So the KBT race has been in some people's hands for a while...  (Read 4151 times)
Offline irjoe
What's the overall consensus?
My main question is regarding its compatability with Mac OS X.
I have a macbook pro, and would love to have the KBT race as a portable option. If not, I will get a pure instead....
The Race manual says it's N-KRO, which would (from my understanding) make it incompatible with OS X, but from some DT posts reveal that they are actually 6KRO instead...
Can anyone confirm the 6KRO/NKRO, and even better, whether it's OS X compatible?
I'd be eternally grateful!
« Reply #1 on: Thu, 31 May 2012, 22:34:33 »
The manual probably means it's NKRO in regard to the switch/PCB matrix having diodes to support it (so it's NKRO via PS2). I believe they are 6KRO via USB for apple compatibility, though I'll let a user chime in to be sure.
Offline laffindude
« Reply #2 on: Fri, 01 June 2012, 06:25:43 »
6KRO. No PS2 support. NKRO is mistakenly used in the English manual.
Offline 1391401
  • MX CLEAR
« Reply #3 on: Fri, 01 June 2012, 10:12:12 »
Hey - I am not a Mac power use by any means, I hate the window manager in OSX so much I just use the terminal for as many tasks as I can, but I plugged my Race in at work and everything seems to work fine on my iMac.  Definitely a nice replacement to that horrible keyboard that comes with the thing...  Will probably be doing a review once I can get some time to sit down and write one.
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline wilsongunawan
« Reply #4 on: Fri, 01 June 2012, 12:08:49 »
i just try it on my mac air and work perfectly even the media key and the volume key! the alt button become command button though.
Currrent : Siig minitouch <blue monterrey alps>, kbt-RACE <cherry mx-red> with green LED, Filco MJ2 <cherry mx-ergoClear>, IBM model M
Offline dbdynsty25
« Reply #5 on: Fri, 01 June 2012, 12:11:49 »
Quote from: wilsongunawan;605681
You can easily remap the alt and command buttons in the keyboard settings on your macbook if needed.
Offline irjoe
« Reply #6 on: Fri, 01 June 2012, 13:41:50 »
Awesome, this is a lot more reassuring having this confirmed by many GH'ers.
Onto a second question, what are some alternative options available for swapping out the keys? I take it that some keys are not standard... is everybody just using the given abs keycaps the keyboard comes with?
Offline 1391401
  • MX CLEAR
« Reply #7 on: Fri, 01 June 2012, 17:34:17 »
Quote from: irjoe;605753
I don't think this keyboard is a good candidate for using custom key caps.  I say that mainly because although it has the same keys as most keyboards the keys it does have are often (a) a different width (e.g. arrow keys, shift key, etc) or (b) a different row.  Finding a set that matches perfectly without that franken-cap feel will be difficult.
Pic below shows some of the non-standard keys:
I have not taken a look at how tall the keys are compared to standard cherry keys or SP DS keys but I have a feeling they are a lot taller too.
« Last Edit: Tue, 06 June 2017, 16:47:06 by trizkut »
Offline laffindude
« Reply #8 on: Sat, 02 June 2012, 06:12:27 »
Those 6 keys on the bottom right are all standard 1.25 sized R1 keys. You can just use blank modifier on it. Now, Trying to get 1.5 sized R5 keys would be a problem. Even 1x1 spaced R5 key is not easy to get.
Offline net2522
  • lollollollol
« Reply #9 on: Sat, 02 June 2012, 06:45:55 »
If someone find red ESC 1.5 please tell me!!
Offline mbc
  • -delete-
« Reply #10 on: Sat, 02 June 2012, 06:50:19 »
Quote from: net2522;606135
Got a white cherry ds 1.5 esc^^
Offline laffindude
« Reply #11 on: Sat, 02 June 2012, 06:51:32 »
They exist
Offline net2522
  • lollollollol
« Reply #12 on: Sat, 02 June 2012, 06:55:13 »
WoW!!
mbc, Do you have a pic.? So temptttt
« Last Edit: Sat, 02 June 2012, 06:57:40 by net2522 »
Offline quake4mhg
« Reply #13 on: Sat, 02 June 2012, 23:54:59 »
Race Keycap height
[ Attachment Invalid Or Does Not Exist ] 52156[/ATTACH]
Offline swi7z3r
« Reply #14 on: Sun, 03 June 2012, 02:12:29 »
Quote from: 1391401;605579
Check out Total Finder.  It's an essential OS X upgrade.  Along with Alfred.
