Author Topic: Backlit mechanical numpad?  (Read 3396 times)
Offline quake4mhg
« on: Thu, 31 May 2012, 23:39:32 »
I would like to know is there a backlit MX switch mechanical numpad in the market? Any type of MX switch would be fine.
I'm really happy with my Filco MX brown numpad tho, but can't see the keys in the dark :biggrin:
Thank you in advance.
Offline Stn
« Reply #1 on: Fri, 01 June 2012, 00:11:43 »
Just went through the same thing. Received my CM Storm Trigger today. Meets all your criteria.
Offline longweight
  • philanthropist
« Reply #2 on: Fri, 01 June 2012, 00:54:01 »
Quote from: Stn;605301
Meets none of them as it is a full-size keyboard, the OP wants a separate number pad.
There aren't many number pads around and very few of them actually look nice! Never seen a backlit one sadly....
Offline ricercar
  • mostly abides
« Reply #3 on: Fri, 01 June 2012, 13:12:59 »
Deck made a backlit numpad once, but I've never seen one for sale. If you see one, best snap it up as fast as you can, it won't be around for a second chance.
Offline Enki
« Reply #4 on: Fri, 01 June 2012, 13:23:12 »
Quote from: quake4mhg;605287
Mod it mod it mod it!
Filco TKL | Noppoo Choc Mini | KBC Poker (ghetto)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 01 June 2012, 13:23:38 »
There was some Korean kit numpad, I believe it had led mount option. If you can't find the 5 easy, get a keycap with a more noticeable nub!
Offline quake4mhg
« Reply #6 on: Fri, 01 June 2012, 16:00:42 »
Oh .. glow in the dark keyboard stickers?
Mod it would be an good idea too.
Thank you very much guys :biggrin:
« Reply #7 on: Fri, 01 June 2012, 16:39:12 »
Quote from: lysol;605740
Yeah, I saw a picture of it in the RGBy topic, I think Taeyoung has one. It matched whatever keyboard he's got. I can't tell all the awesome korean custom keyboard apart, so I don't know which.
Also, if you can't find the 5, grab some old WYSE keycaps, their nub is strong.
