Author Topic: rosewill cherry brown. backspace problem?  (Read 3574 times)
Offline nullstring
« on: Fri, 01 June 2012, 17:16:03 »
I just received my first mechanical keyboard; rosewill cherry bown.
So, far I am liking most of it.
However, the backspace key seems weird. It's not smooth to press like the other keys.
It almost feels "crunchy"
Pressing it feels weird, and then after pressing, it doesn't come up as fast as the other keys
Offline Maarten
« Reply #1 on: Fri, 01 June 2012, 17:18:33 »
Pop the cap off, press the switch a couple of times with a vacuum cleaner hovering over the switch as close as possible. Prolly just some dirt in there that needs to come out. If thats not it lube the stabilizer a bit.
Offline nullstring
« Reply #2 on: Fri, 01 June 2012, 17:20:59 »
How do i pop the cap off?
Normally I would just take a small screw driver and pry it off, but I want to make sure I don't damage this thing in case I need to return it.
Offline nullstring
« Reply #3 on: Fri, 01 June 2012, 17:42:01 »
Ok, I got the cap to come off, but the metal piece is still attached.
How do I remove that?
It isn't budging even with quite alot of force.
Offline nullstring
« Reply #4 on: Fri, 01 June 2012, 17:50:48 »
I remove the two below keys and was sort of able to move the backspace off the switch, but not remove the metal peice.
I think hit the switch a key times. it seems fine. It looks like the issue is with the metal peice.
feeling around, it seems that all the "big keys" other than the space bar, have this issue. It's just worse on the backspace.
Any thoughts?
Offline Maarten
« Reply #5 on: Fri, 01 June 2012, 18:21:09 »
What kind of metal pieces does it use, these;
[ Attachment Invalid Or Does Not Exist ] 52060[/ATTACH]
If so you should be able to slide em out forwards (look closely at the picture) and give em a tiny little bit of lube (too much lube will just attract more dirt making your problems come back quicker and quicker)
Offline nullstring
« Reply #6 on: Fri, 01 June 2012, 18:52:14 »
Keycap cannot be removed from metal part..
and metal part is hard to remove from keyboard.
http://img820.imageshack.us/img820/9504/img20120601194855.jpg
I'll see if I can find some lube and try it out.
Offline urbanus
« Reply #7 on: Fri, 01 June 2012, 19:11:30 »
Quote from: nullstring;605927
You can, but you don't necessarily need to.
Having got the key off that far, you can lubricate the stabiliser then put the key back.
However if you do want to remove that key, get a flat-bladed screwdriver.  Put it underneath the key, against the stabiliser (if you're right-handed, the right side).  Push the screwdriver gently to the right, while you pull the keycap gently to the left.  The top of the stabiliser will unhook from the white plastic clip and you can remove the keycap.  Remember it shouldn't require much force, and that you're trying to stretch the stabiliser ever so slightly, not bend it.
Offline OddOne
« Reply #8 on: Fri, 01 June 2012, 19:17:53 »
Scroll down at this link.  Instructional video on how to remove the key cap from the stabilizer.  WASD Keyboards has a few  other videos on keyboard maintenance here as well.
http://www.wasdkeyboards.com/index.php/blog
p.s. I love my Rosewill w/ Browns
|  CM Quickfire Rapid   |   Rosewill RK-9000BR  |  CM Quickfire Rapid  |
Offline Drew Baumann
« Reply #9 on: Fri, 01 June 2012, 19:22:01 »
Quote from: OddOne;605940
Good suggestion. I was having the same issue with my filco. Basically I just needed to play with the stabilizers a bit before it felt right. I didnt use lube, just took the stabilizers off like in the video and then back on at different angles. Took me a little while before I got it right.
Offline nullstring
« Reply #10 on: Fri, 01 June 2012, 20:59:31 »
Thanks guys.
That is helpful very helpful.
