Author Topic: Problem with Chicony KB 5181  (Read 3981 times)
Offline n0str3ssPT
« on: Wed, 06 June 2012, 16:15:19 »
Hi,
I have a chicony kb 5181 and i am using a at to ps2 adaptor to connect it to my pc but the keyboar is not working on windows. It works in the Bios but immediatly when windows logo appears the keyboard just stop responding but the leds still on.
I dont know why he is not responding in the windows
Can someone helping me fixing this issue.
PS: This model has mx blacks and not blues montereys and the switch is in the AT mode (A).
« Reply #1 on: Wed, 06 June 2012, 16:29:04 »
Mine worked properly. I prefer the flexible adapters on a short "pig-tail" because the rigid ones seem to create too much leverage.
My only suggestions would be to verify that it is plugged in properly, or try another plug.
- Plato
Offline didjamatic
« Reply #2 on: Wed, 06 June 2012, 16:31:16 »
Try unplugging, switch to XT, back to AT, replug.  If that doesn't work try on another PC, if same result, try a different AT/PS2 to USB adapter, if that doesn't work, try another keyboard.
Offline Internetlad
« Reply #3 on: Wed, 06 June 2012, 16:33:51 »
IIRC I had this issue once before, turned out it was something goofy like the keyboard driver for windows became corrupt or something. I would try a different KB and see if you get the same result, after that, focus solely on the board.
"Beep . . . Beep . . . Beep" -Sputnik I
Offline TexasFlood
« Reply #4 on: Wed, 06 June 2012, 16:55:46 »
I saw something like this once. Might not be the same situation but IIRC it was a Gigabyte motherboard BIOS setting something like USB keyboard support in BIOS which is needed for some older OS like MS-DOS but typically not needed. Although one would not think this would have any bearing on PS/2 as I recall it caused PS/2 devices to not work in Windows so might review your BIOS settings for something like that.  Again might not be the issue just FYI.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Wed, 06 June 2012, 18:03:29 »
I also have a Chicony 5181CT which is also Cherry. It did same thing... need to wait for driver to install after logon, kind of hard to enter password for logon without keyboard working lol. I needed to logon with other keyboard, then restart. Works fine after this for me.
Offline TexasFlood
« Reply #6 on: Wed, 06 June 2012, 18:06:11 »
Huh.  I have a monterey blue KB-5181 that I've used via a PS/2<>USB converter before and don't recall any problems.
Might have to dig it out and make sure now.
Offline n0str3ssPT
« Reply #7 on: Thu, 07 June 2012, 04:03:50 »
But the windows dont recognize the keyboard but the lights on the kb still on.
« Reply #8 on: Thu, 07 June 2012, 09:50:55 »
Quote from: n0str3ssPT;609039
Does it recognize the keyboard at all in device manager? Have you tried a different OS (grab a knoppix boot CD or something) ? Have you tried didjamatic's suggestion?
Offline Touch_It
« Reply #9 on: Fri, 08 June 2012, 00:04:26 »
hmm, i have a chicony 5181 with monterays. my daily driver :).  i did a cable swap for a ps2 cable, and it works perfectly.  the ps2 cord i stole from an old rubber dome compact. connected with a 4 pin adapter i think.
