Author Topic: What is under the keycap of my 87U?  (Read 2745 times)
Offline watduzhkstand4
« on: Thu, 07 June 2012, 08:57:44 »
The left Ctrl key
Untitled by Jэяяу, on Flickr
What lead to my discovery was when I was using the Ctrl key and noticed that the sound of the key was much more dampened.
Does anyone know what this is? Should I contact EK about it? I received the keyboard just yesterday.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline laffindude
« Reply #1 on: Thu, 07 June 2012, 09:05:29 »
Lube.
« Reply #2 on: Thu, 07 June 2012, 09:07:53 »
they actually lube the switches? I've taken my HHKB apart before and didn't notice there was lube.
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline reaper
« Reply #3 on: Thu, 07 June 2012, 09:08:58 »
Yup, those are normal.  I've seen them on pretty much all the RF from EK and even the ones I got directly from Leopold in S. Korea.
Din Eli
« Reply #4 on: Thu, 07 June 2012, 09:11:32 »
thanks reaper. I didn't know they were going to overload on lube just on one switch lol
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline DEAD_BEEF
« Reply #5 on: Thu, 07 June 2012, 10:00:35 »
I should have ordered a tube with my 87U. How often do these babies need to be lubed?
Offline reaper
« Reply #6 on: Thu, 07 June 2012, 18:06:34 »
I suppose that would depend on the usage but I haven't lubed mine yet and I have it for awhile.  Guess the one that came with it was sufficient. lol
Anywho, welcome to Geekhack! =D
Din Eli
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #7 on: Thu, 07 June 2012, 20:30:23 »
Quote from: watduzhkstand4;609102
i wonder if this explains demik's assertion that hhkb 45g is somehow wildly different from rf 45g
« Reply #8 on: Fri, 08 June 2012, 01:02:01 »
I personally find the 87U feeling much more solid in every keystroke. The sound it produces kind of explains the way the keyboard is built. (If that makes any sense) Also, the spacebar on my 87U 45g feels like it's heavier than every other key on the keyboard. I don't know if that's true or if that's just me :P
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline hoggy
  • * Ergonomics Moderator
« Reply #9 on: Fri, 08 June 2012, 02:14:59 »
Quote from: watduzhkstand4;609608
It sounds deliberate.  I don't know about Topre, but cherry make switches (the grey ones) that I've only ever seen under space bars..
« Reply #10 on: Fri, 08 June 2012, 15:03:54 »
Quote from: hoggy;609633
I remember swapping out the grey switch from my MX11800 spacebar to the scroll lock key. I like it lighter on the spacebar
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline Wildcard
  • When caffeine isn't enough
« Reply #11 on: Fri, 08 June 2012, 15:16:11 »
I wonder if the supposed "stiffening" of the switches over time, is actually due to the lube drying out and not actually from the rubber getting firmer.
Edit: going back to the OP, I had quite a bit of lube under my left modifier as well
« Last Edit: Fri, 08 June 2012, 15:20:55 by RiffRaff »
