Author Topic: My first mech arrived! How long will I take to get used to it?  (Read 4034 times)
Offline Lorem-Ipsum
  • (╯°□°)╯︵ɯnsdı-ɯǝɹoן
    • mattwall.co.uk/
I just got my Filco Majestouch 2 with Blues.
Previously the keyboards I've used most have been the Logitech Illuminated and the apple aluminium keyboard.
As both of these have been very flat keyboards and both have scissor switches this mech feels very different and I'm sort of struggling to type on it.
I'm going to have to get a wrist wrest, but apart from that, how long does it usually take to become accustom to a mechanical keyboard?
EDIT: Might get some O-Rings too
« Last Edit: Thu, 07 June 2012, 15:56:58 by Lorem-Ipsum »
Currently Using: Corsair K65 (MX Reds)
Own: IBM Model M | Logitech Illuminated | Filco Majestouch 2 (MX Blues) [Waiting for Toxic] | Cherry D-91275
OS: ArchLinux | Herbstluftwm | Termite | Zsh
"In a world without walls and fences, who needs windows and gates?"
Offline Reptile
« Reply #1 on: Thu, 07 June 2012, 15:58:33 »
Took me a couple weeks, others more.
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
« Reply #2 on: Thu, 07 June 2012, 15:58:39 »
10 seconds
get the o-rings
the harder and smaller, the better
- Plato
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #3 on: Thu, 07 June 2012, 15:59:54 »
It took me about a day, though I came from other high profile keyboards.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline minifridge
« Reply #4 on: Thu, 07 June 2012, 16:00:12 »
Congrats, just got my first one as well this afternoon. After getting a wrist rest, I'm already becoming pretty accustomed to typing on it. I got a Rosewill which is basically rebranded Filco, so your experience shouldn't be too much different from mine.
[SIGPIC][/SIGPIC]
ROSEWILL RK-9000
Offline Lorem-Ipsum
    • mattwall.co.uk/
« Reply #5 on: Thu, 07 June 2012, 16:12:34 »
Thanks folks, anyone got a wrist rest recommendation. I'm in the UK and I'd like to keep it under £20, as much as I'd like the leather filco one I can't justify it.
Offline minifridge
« Reply #6 on: Thu, 07 June 2012, 16:18:16 »
Just picked up a random microfiber one from my Best Buy :X pretty comfortable though I can't speak for it's longevity. Don't think you can really go wrong with wrist rests as long as you don't get some super cheap-ass gel plastic one...
[SIGPIC][/SIGPIC]
ROSEWILL RK-9000
Offline Lorem-Ipsum
    • mattwall.co.uk/
« Reply #7 on: Thu, 07 June 2012, 16:23:01 »
Thanks. I'll have a look on amazon at some point.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Thu, 07 June 2012, 16:26:00 »
It didn't take me long, just getting used to a ANSI layout vs a Microsoft media keyboard layout
I would say about 2 days, but I type kinda a lot
« Reply #9 on: Thu, 07 June 2012, 16:55:14 »
I absolutely adore gel wrist pads and would not use anything else.
The one I have is long and tall, but relatively narrow front-to-back, and I don't know how to recommend it because my wife brought it home from work and it has absolutely no markings on it. The bottom is sticky rubbery and it does not move AT ALL.
It is sleeved with a moderately slick nylon fabric, and I consider it perfect.
I will really mourn it when it finally fails.
« Last Edit: Thu, 07 June 2012, 17:27:00 by fohat.digs »
- Plato
Offline Lorem-Ipsum
    • mattwall.co.uk/
« Reply #10 on: Thu, 07 June 2012, 17:00:25 »
This looks nice so I think I'll go for it. I can always get another one if I don't like it.
« Reply #11 on: Thu, 07 June 2012, 17:38:08 »
This one looks more like mine.
Perhaps the indentations near the center of yours will be helpful.
My feeling is that many wrist rests are not tall enough to be effective. It would be nice for the entire system of forearm/wrist/fingers/keys to be straight and in the same plane.
http://www.amazon.co.uk/Fellowes-Premium-Keyboard-Wrist-Support/dp/B00006B8J8/ref=pd_cp_computers_1/277-9587175-7252706
- Plato
Offline Lorem-Ipsum
    • mattwall.co.uk/
« Reply #12 on: Thu, 07 June 2012, 17:44:30 »
I currently have an ikea desk but I'm very tempted to build the next one and make the space for the keyboard slightly recessed. Not sure exactly how I'd go about it though, especially if I change keyboards occasionally.
« Reply #13 on: Thu, 07 June 2012, 20:47:43 »
The keyboard is not the biggest determinant. I am typing on an absolutely mammoth Model F 122-key terminal right now, and the peak of the uppermost key is perhaps 2 Imperial inches above the tabletop (that is 5 cm to non-Americans) and my wife's svelte Apple Aluminum (with a little built-in leg-like protrusion at the back) is about 3/4" or 2 cm maximum.
90% of the other keyboards in the world probably split that difference about halfway, and so the usual variation between boards is probably not more than single centimeters. (I never use the legs, although that would give me even more reason to use a wrist rest.)
Desk heights are pretty standard, meant to rest elbows on, so dropping the keyboard tray 2"-3"-4" is probably a good idea for most people. But being a big guy, I can't stand keyboard trays because they interfere with my leg room. My wife depends on them.  Also, my chair has more height adjustment than that. For a keyboard tray to be comfortable to me, I would have to raise the desk a couple of inches.
I gauge the wrist rest height to the height of the spacebar, because I am looking for it do just that, provide a rest for my wrist.
« Last Edit: Thu, 07 June 2012, 20:50:55 by fohat.digs »
- Plato
