Author Topic: Keyboard lube?  (Read 11521 times)
Offline The_Beast
  • I like wood ಠ_๏
Keyboard lube?
« on: Sat, 09 June 2012, 17:23:06 »
I want to get sensual with my keyboard tonight but I want it to got smoothly, so I'm going to need some lube.....
jk, the backspace on my new Rosewill is squeaky and needs some lube, what do GH use to lube their keyboards?
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Keyboard lube?
« Reply #1 on: Sat, 09 June 2012, 17:30:26 »
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline reaper
Keyboard lube?
« Reply #2 on: Sat, 09 June 2012, 17:48:08 »
Quote from: The_Beast;610486
This one.  Cheap, easily obtainable and it works.
Din Eli
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Keyboard lube?
« Reply #3 on: Sat, 09 June 2012, 18:25:00 »
Beings that I have a large collection of fountains pens I use silicone (which I believe is on the GH link as well) that works real well on plastic and is available at LOWES or Home Depot.
Quote from: thegunner100;610491
Here you go
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline itznfb
Keyboard lube?
« Reply #4 on: Sat, 09 June 2012, 22:01:16 »
I've been using the WD-40 White Lithium Grease spray bottle. Just spray it on a q-tip and dab a little where it's squeaky and it has worked great. Cheap and easily accessible from most super stores and hardware stores.
Offline The_Beast
  • I like wood ಠ_๏
Keyboard lube?
« Reply #5 on: Sat, 09 June 2012, 23:36:59 »
I'm going to go to Home Depot tomorrow and see if they have any SuperLube or something similar
Offline Spinsle McGee
Keyboard lube?
« Reply #6 on: Tue, 12 June 2012, 23:45:22 »
When I needed to lube my Leopold's spacebar, I just used Chap Stick and a paperclip. It worked, but there are probably some much better alternatives out there that have already been stated in this thread.
Keyboards: Leopold Tenkeyless, Steelseries 6Gv2, Wants an IBM Model M
Mice: Microsoft Intellimouse Explorer 3.0, Razer Deathadder
Offline Netdewt
  • OLKB
Keyboard lube?
« Reply #7 on: Wed, 13 June 2012, 00:10:37 »
I think I have some white lithium... I'll be trying that if I can find it. Squeaky left shift!
Offline Netdewt
  • OLKB
Keyboard lube?
« Reply #8 on: Wed, 13 June 2012, 23:34:49 »
I tried the grease... and my left shirt is still super squeaky. I haven't even used this board much yet! It's weird, it's only squeaky when I push on the right side of the key. It doesn't seem to be the switch itself at all.
Offline itznfb
Keyboard lube?
« Reply #9 on: Thu, 14 June 2012, 08:33:20 »
It's usually the stabilizer that is squeaky. Not the switch. Where the metal rubs the plastic clips is where the squeak comes from.
Keyboard lube?
« Reply #10 on: Thu, 14 June 2012, 08:43:53 »
Quote from: reaper;610498
I concur. This stuff works great and only takes a tiny amount. The curved syringe is perfect.
Don't screw around with something made for brake pedals or screen doors.
( Chap Stick ? and how much did you pay for your keyboard ? )
- D Trump 2026-10-24
Offline Netdewt
  • OLKB
Keyboard lube?
« Reply #11 on: Thu, 14 June 2012, 10:45:00 »
Quote from: itznfb;613267
How do you get in there to grease it?
Offline modulor
Keyboard lube?
« Reply #12 on: Thu, 14 June 2012, 11:55:59 »
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Keyboard lube?
« Reply #13 on: Thu, 14 June 2012, 12:10:26 »
Krytox GPL-205 lubes the inside of mx red switches quite nicely. My capslock switch is buttery smooth now. I needed to lube it because my off-center un-stepped capslock made the switch jitter. It probably works just as well for squeaky stabilizers. It's expensive, but worth it. There are 4 spots on the inside of the switches that need lube. And 4 spots on costar stabilizers that need lube.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
