Author Topic: Noppoo Choc Mini on OSX without PS2 bypass **FIXED**  (Read 3713 times)
Offline skryl
« on: Mon, 11 June 2012, 22:53:35 »
Step by step instructions on how to get the Choc Mini working on OSX:
1. Make sure the Choc Mini is not plugged in
2. Download this zip file and unzip it
3. Move the IOUSBHIDDriverDescriptorOverride.kext bundle from inside the unzipped directory to /System/Library/Extensions
Code: [Select]
cd /location/of/the/unzipped/project
sudo cp -r IOUSBHIDDriverDescriptorOverride.kext /System/Library/Extensions
4. Download and install KeyRemap4Macbook
5. Restart
6. Plug in your choc mini and go to town
Notes:
The kext was compiled in Lion so I can't guarantee that it will work in other versions of OSX.
This solution was originally proposed by thefloweringhash here. I just wanted to make it a bit more user friendly.
Leopold FC200R Otaku MX Brown | Leopold FC200R Otaku MX Blue | SIIG Minitouch XM White | Noppoo Choc Mini MX Red | Ducky 1087 XM Green | Leopold FC200R MX Red | Apple M0116 Salmon Alps | Realforce 86U Topre
Offline Gerk
Re: Noppoo Choc Mini on OSX without PS2 bypass **FIXED**
« Reply #1 on: Sun, 12 August 2012, 12:54:45 »
Awesome :)
I was thinking about trying one of these board out but I have a couple of questions if anyone is using this ...
Has anyone tried this on Mountain Lion yet?  Chances are probably good it'll be fine but I have no idea what they changed in the lower levels from Lion->ML
Are there any issues with it?  Would it still work in single user mode, for bootup key combinations, etc?  (neither are a huge deal just want to know what I'm getting into)
Rosewill RK-9000RE (reds) | Das Keyboard Model S Professional Silent (browns) | Leopold TKL (browns) | F21-7D "Mechanical Keyboard" (Blue Alps) | Filco Majestouch TKL (blues) | Goldtouch V2 x 2 | Matias Ergo Pro x 2 | Kinesis Freestyle Pro (browns) | Kinesis Freestyle Edge (reds)
Offline polpo
    • http://polpo.org/
« Reply #2 on: Tue, 14 August 2012, 17:42:59 »
I'll give a report on how it does in Mountain Lion.
And I was just about to sell my Choc Mini...
Matias Mini Quiet Pro / DSI SMK-88 (Cherry Black) / IBM Model M (10 Jul 86) / ThinkPad Travel Keyboard with Ultranav
Offline frub3nz
« Reply #3 on: Thu, 16 August 2012, 15:31:41 »
Just tried this on 10.6, even compiled my own .kext and it still does not work :|
Offline mztriz
« Reply #4 on: Mon, 10 December 2012, 16:54:36 »
Has one one gotten this to work with OS X Mountain Lion? I've tried using the kext and the pkg (with KeyRemap4MacBook) and it still doesn't work properly.
