Author Topic: Question on Topre RF key press  (Read 2052 times)
Offline dko2o
« on: Sun, 17 June 2012, 08:05:05 »
Hi everyone, I was wondering what peoples opinion of which cherry switch feels closest to a Topre RF? I have only able to try some switch types (at the shops) and its hard to make a comparison. If someone owns a RF as well as diff cherry boards and would care to comment, I would really appreciate it.
Offline longweight
  • philanthropist
« Reply #1 on: Sun, 17 June 2012, 10:47:34 »
I have blues and browns as well as a HHKB2 and neither switch feels anything like the Topre! Blues have a similar weight but the motion is very different.
Offline cleeoo
« Reply #2 on: Sun, 17 June 2012, 10:53:11 »
I only have blues and Topre, and I would agree that they definitely feel anything alike. I just took out my old Blues keyboard, and I honestly thought that it felt a little bit lighter than my Topre. The Topre is only 5 months old though, whereas the blues were used for over two years, so maybe that's part of it.
Are you planning on getting a Topre keyboard? Did you like any of the switch types that you tried out at the stores?
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #3 on: Sun, 17 June 2012, 11:55:44 »
the closest cherry to a topre would be either browns or clears. both are a pretty far cry from the famous topre smoothness though. there's just no substitute for a topre switch if you want that smooth domey feel
keep in mind there are pluses and minuses to both. when i want audible feedback, i need a big fat spring in my switch. when i want to type quickly and quietly i go for a topre
Offline daerid
    • Rossipedia
« Reply #4 on: Sun, 17 June 2012, 15:20:14 »
I'd say browns are the closest match, for sure. But there's a softness to Topre's that the cherry's don't have.
Personally, my RF 45g is the greatest board I've ever typed on.
Offline dko2o
« Reply #5 on: Sun, 17 June 2012, 20:23:03 »
Quote from: cleeoo;615487
I've just got a Topre recently and reds. Now I'm looking for something maybe closer to a Topre switch to replace my reds, I don't like the reds as much anymore after using the RF. But with the o-rings on the red I'm thinking they might be closest to the feel than the browns. I haven't tried the browns but I've read that people also think the browns are closest but doesn't the browns have a tactile bump when pressed? Isn't the Topre press pretty linear?
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #6 on: Sun, 17 June 2012, 21:03:27 »
I'd say that the 45g topres are pretty noticeably tactile when you press down on them.  Even moreso with the 55g probably.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline urbanus
« Reply #7 on: Mon, 18 June 2012, 08:07:16 »
Quote from: dko2o;615816
Browns are very similar to reds.  They have a very subtle patch of resistance just before the actuation point, but apart from that they're almost the same.  Compared with Topre: you know that feeling of smoothly increasing pressure, then when you press the key past a point and it collapses downwards?  Yeah, well browns are not like that.  They're reds with a small rough spot basically.
Browns would be more of a replacement for you red board, if you find the reds too linear.  They're not similar to Topre.
If you want something comparable to Topre consider buckling spring.  It's not the same -- heavier, clicky, and the drop off after actuation is sharper -- but the overall effect is similar.
Offline phetto
  • HHKB JP
« Reply #8 on: Mon, 18 June 2012, 08:16:01 »
I would say mx reds with a shorter distance from a to b..
