Author Topic: Mouse speed script  (Read 4160 times)
Offline darkrazor
Mouse speed script
« on: Mon, 18 June 2012, 05:27:23 »
Hello, small question.
If I make a script which moves my mouse/cursor, does the type of mouse I have affect the speed of my script? So, if I have a high dpi mouse, would the script make the cursor move faster?
Thanks in advance.
Offline Djuzuh
Mouse speed script
« Reply #1 on: Mon, 18 June 2012, 06:15:45 »
I don't think so.
But your windows mouse sensitivy comes into account, if you have touched this, I believe.
Offline cactux
  • Topre Knight
Mouse speed script
« Reply #2 on: Mon, 18 June 2012, 06:16:34 »
which os and mouse are you using?
[FS]☠ The temple lol ->HERE<-
Offline darkrazor
Mouse speed script
« Reply #3 on: Mon, 18 June 2012, 06:52:43 »
I use a crap mouse atm. That's why I wonder, if I should get a faster mouse. I want to know if it makes my script faster.
Offline Djuzuh
Mouse speed script
« Reply #4 on: Mon, 18 June 2012, 06:54:16 »
Nop it shouldn't. Welcome btw !
Offline darkrazor
Mouse speed script
« Reply #5 on: Mon, 18 June 2012, 06:56:43 »
Thank you! And are you certain is doesn't? Is there another way to surpass the maximum speed? I already set the mouse speed to max at options. I use windows xp.
Offline Maarten
Mouse speed script
« Reply #6 on: Mon, 18 June 2012, 07:58:39 »
Wow, if the max mouse speed in XP is still usable you might consider buying a new mouse. Pumping the speed up software-wise will reduce resolution quite a bit i guess.....
Offline darkrazor
Mouse speed script
« Reply #7 on: Mon, 18 June 2012, 08:10:24 »
So my question is still unanswered:) Or atleast, one answered:) But I need to be sure before I buy an expensive gaming mouse. The question is quite simple. I just want the script to be faster, does it help to buy a new mouse with higher DPI?
Offline Djuzuh
Mouse speed script
« Reply #8 on: Mon, 18 June 2012, 08:16:47 »
why don't you modify the script?
Offline The_Beast
  • I like wood ಠ_๏
Mouse speed script
« Reply #9 on: Mon, 18 June 2012, 08:20:59 »
The physical mouse does not effect the speed of mouse movements in a script
Offline Maarten
Mouse speed script
« Reply #10 on: Mon, 18 June 2012, 10:36:00 »
Quote from: darkrazor;616152
Expensive? If high DPI is your only requirement (no fancy tricks, LOD, leds, branding or whatever) then the chinese can sell you stuff CHEAP!
http://www.dealextreme.com/p/55296
1600DPI (heck, there are even lower ones selectable with a button), price includes shipping.... just order two and one of those will probably work and keep working for a mantionable period of time :D
