Author Topic: What did you get in the mail today?  (Read 25547240 times)
0 Members and 7 Guests are viewing this topic.
Offline 4LI4Z
« Reply #400 on: Sat, 08 September 2012, 07:01:59 »
3954-0
My Filco MJT2 TKL with retro-looking cherry beige/grey keycaps. ;D
3956-1
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
Offline es20641
  • They don't think it be like it is, but it do.
« Reply #401 on: Sat, 08 September 2012, 08:43:09 »
ES, do you have an amazon link to that covered cable?
I sure do. Here you go.
http://www.amazon.com/Cloth-Jacketed-Ruggedized-Micro-Cable/dp/B003V42O6K/ref=sr_1_4?ie=UTF8&qid=1347111714&sr=8-4&keywords=covered+mini+usb
EDIT: Sorry, I didn't see that someone had responded to that already.
Stock KBT Pure
Offline MMB
« Reply #402 on: Sat, 08 September 2012, 10:36:23 »
I got my first little order from WASDkeyboards for my new QF Rapid Red!  :)
What was included:
  • red spacebar to replace the stock one with the "quickfire" branding
  • white Mac-style "Command" keys (I'm working on iMac)
  • blank blue cap to replace the FN key, which is working like on a Mac keyboard with the volume controls on F10-12
  • two orange blank caps to replace scroll lock & pause, which directly control screen brightness on mac
  • red cap with radial texture to replace escape
  • blank yellow caps for numbers 1-4, tab, left shift and left alt -> this is my Diablo 3 grip  ;)
My next plan is to order a 39-key ISO keycap set from wasd to replace all the letters, maybe in dark grey. We'll see.
I really like some of WASD's designs. I just wish they would make a move towards PBT material.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #403 on: Sat, 08 September 2012, 10:41:04 »
and Cherry profile =)
Offline AKIMbO
  • HHKBro
« Reply #404 on: Sat, 08 September 2012, 15:09:01 »
My last keyboard purchase before my fire sale.  I'm definitely keeping this keyboard, it's a Chicony KB-5181 with monterey blue switches in excellent condition.  I rank it among my top two favorite keyboards...can't decide whether I enjoy monterey blues or IBM Model  F springs more.
| KBD75 (box reds)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #405 on: Sun, 09 September 2012, 01:32:03 »
Curse you for getting that keyboard!  I've been looking for one for a while now.  If you ever want to let it go you know who to PM. ;D
Offline AKIMbO
  • HHKBro
« Reply #406 on: Sun, 09 September 2012, 09:12:51 »
I don't think so.  I really like it.  This KB-5181 is going into my permanent collection.
| KBD75 (box reds)
Offline Anynoupy
  • French Fries
« Reply #407 on: Sun, 09 September 2012, 11:08:28 »
Got the Fingerprint Keycap, made by i3oilermaker, loving it, thanks ! :D
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #408 on: Mon, 10 September 2012, 13:30:58 »
W00P W00P! DOUBLESHOTS! :D
Offline TheProfosist
  • Custom Layouts Only!
« Reply #409 on: Mon, 10 September 2012, 13:46:16 »
This isnt keyboard relate but my Pen Type-A finally came and man its one nice piece of work.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #410 on: Mon, 10 September 2012, 14:11:52 »
Cherry RGB dyesub set.
Thanks, T-dawg! :D
Mad jelly. Those things are epic
-Enzo Ferrari
Offline sth
  • 2 girls 1 cuprubber
« Reply #411 on: Mon, 10 September 2012, 18:11:03 »
the cherry key is too tight, i need to file it out or something. backspace is neat but it sounds bad on my poker. I think it's hitting the stabilizer bar or something.
GeekHack esc made the cut though :)
Offline MMB
« Reply #412 on: Mon, 10 September 2012, 19:55:38 »
Metal Lube Station. Demik is the mutha phucken man fo sho!
« Reply #413 on: Mon, 10 September 2012, 19:57:48 »
unnecessarily huge box + other small boxes to keep it still.
i MacGyver'd that ****
Offline MMB
« Reply #414 on: Mon, 10 September 2012, 19:58:51 »
I thought it was awesome! I also was running out of those boxes, so +kudos to you, sir :D
Offline jcrouse
« Reply #415 on: Mon, 10 September 2012, 19:59:56 »
so what is the big round hole for in your lube station. Looks a little weird to me.
Offline MMB
« Reply #416 on: Mon, 10 September 2012, 20:00:33 »
I use my junk to hold it in place while I lube.....
Offline sth
« Reply #417 on: Mon, 10 September 2012, 20:00:34 »
it's the pee pee hole duh
Offline sth
« Reply #418 on: Mon, 10 September 2012, 20:01:03 »
hmm. let me specify that i want SYNTHETIC and not organic lube on my switches, meatball :))
Offline jcrouse
« Reply #419 on: Mon, 10 September 2012, 20:01:36 »
I'm guessing the hole is way too big
Offline MMB
« Reply #420 on: Mon, 10 September 2012, 20:01:50 »
I tend to go with a hybrid mix when I lube switches..... ;)
Offline MMB
« Reply #421 on: Mon, 10 September 2012, 20:02:20 »
Like the 3 bears... it's just right.
« Reply #422 on: Mon, 10 September 2012, 20:14:33 »
to answer your question.
your container of lube goes in that hole.
like in this pic
Offline MMB
« Reply #423 on: Mon, 10 September 2012, 20:15:15 »
Whatever you put in that hole, lube is coming out...
Offline oluf
  • formerly olaph
« Reply #424 on: Tue, 11 September 2012, 15:49:19 »
...Some sweet double-shots from TechKeys! I really dig the green stepped caps lock.
« Reply #425 on: Tue, 11 September 2012, 16:10:23 »
My pi came in today! Less than 24 hours from send to arrive, amazing. I'm playing eat the squirrel, and I am indeed the OMEGA SQUIRREL!!!
Oh and it works fine with my slimblade and poker.
Offline DarkShot
  • Professional Procrastinator
« Reply #426 on: Tue, 11 September 2012, 16:21:18 »
Neat!
Next thing to do: Get a full sized keyboard, fix up the case so that only the 60% space is open and drop in the Pi, a USB hub, and whatever else you need to have single component computer!
« Reply #427 on: Tue, 11 September 2012, 16:24:34 »
Neat!
That'd be pretty sweet! Maybe I'll fashion some sort of wooden case to hold everything. Also need another HD cable, only have one I'm stealing from my dual display. And I am stealing my room mates phone charger, going to need to find my own I suppose.
Offline Grimey
« Reply #428 on: Tue, 11 September 2012, 19:35:10 »
Neat!
This is my thought every time I look inside a Dell AT101W, there really is space for a full computer inside that upper portion of the case.
Erlang your pants off
Offline sth
« Reply #429 on: Tue, 11 September 2012, 19:36:05 »
There's always the cherry g8x-3000
« Reply #430 on: Tue, 11 September 2012, 20:01:03 »
Got my motherboard ASUS P8Z77-v LK back from RMA and got a keyboard from someone that I need to fix up.
Offline mistakemistake
  • Global Loveinator
« Reply #431 on: Tue, 11 September 2012, 20:02:18 »
great mobo :)
« Reply #432 on: Tue, 11 September 2012, 20:03:51 »
great mobo :)
Well it was when it was working, now that its fixed (hopefully) itll be as awesome as it was before.
Offline m00nshake
« Reply #433 on: Tue, 11 September 2012, 20:48:55 »
Just got this. God bless you, Sheraton. My keyboard collection is complete, for now!
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
Offline DanGWanG
  • Higher Standards
« Reply #434 on: Tue, 11 September 2012, 20:57:14 »
Kinda cool how you use the red modifiers and it blends in with the case.  Looks sorta pseudo-winkeyless!
Offline WRXChris
« Reply #435 on: Tue, 11 September 2012, 21:18:53 »
@Halverson check this out!
(credit to twodayslate on /r/mechanicalkeyboards)
Offline m00nshake
« Reply #436 on: Tue, 11 September 2012, 21:19:38 »
Yes it's the bees knees! These modifiers came with the case!
Offline SmallFry
« Reply #437 on: Tue, 11 September 2012, 21:56:42 »
Very nice board M00nshake! I like the red, granted red is my favorite, but nonetheless very nice!
« Reply #438 on: Wed, 12 September 2012, 00:24:49 »
no longer the only cool kid with a red filco :(
now im the only cool kid with a phantom in a red filco case!
« Reply #439 on: Wed, 12 September 2012, 00:38:56 »
That is pretty ballin! Wonder if there is enough room in this big ol Cherry I have sitting here. Would definitely be a cool project!
Offline alixinhzai
« Reply #440 on: Wed, 12 September 2012, 00:45:32 »
Offline MMB
« Reply #441 on: Wed, 12 September 2012, 00:54:50 »
Why will you not share how you modded the WASD with LED's? SHARE BRO. THAT'S WHAT A COMMUNITY DOES KTHX :)
« Reply #442 on: Wed, 12 September 2012, 01:04:23 »
great mobo :)
motherboard officially fixed and working im on happy man.
Offline m00nshake
« Reply #443 on: Wed, 12 September 2012, 04:47:51 »
Well I remember seeing pictures of Italian Red Filco full set keyboards on the Internet a while back and really liking them, but of course not being able to find one for sale anywhere. I never thought I'd own one, and this being tenkeyless as well makes it all the more special , I think. Either way, I feel like a kid again! Now if I had the money for and could find a red cc key and a nice red key set, that'd be amazing!
Offline DarkShot
« Reply #444 on: Wed, 12 September 2012, 18:09:45 »
My [Ten]Keyless Filco arrived!
Currently waiting on some keycaps that are also in the mail so can't use it right yet, but I'm looking forward to it! This thing has some heft compared to my Poker :D
« Reply #445 on: Wed, 12 September 2012, 18:49:22 »
I didnt get this in the mail but rather had to pick it up, its my custom phantom plates so I can complete my Phantoms.
Offline sth
« Reply #446 on: Wed, 12 September 2012, 18:50:33 »
do you plan on sticking with T-arrows and a 6 pack or are you going to use the rest of the available switch mounting area for other stuff?
« Reply #447 on: Wed, 12 September 2012, 18:54:25 »
Hopefully this answers your question
*Note: LWin and LAlt are opposite of the way they should be. I am working on getting this changed.
Offline sth
« Reply #448 on: Wed, 12 September 2012, 18:56:49 »
they are normal for mac users :) can't wait to see it finished.
« Reply #449 on: Wed, 12 September 2012, 19:07:50 »
Yea im currently waiting on WASD as he is out of town this week so I probably wont get my matching caps until next week or the week after.
