Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5645014 times)
Offline hyp36rmax
« Reply #9200 on: Sun, 08 November 2015, 01:01:00 »
1UP KeyCap
Originate Black Carbon Double Shot Key Set
Is your board wrapped?
Yes, with 3M Di-Noc Carbon Fiber Style vinyl.
Cooler Master Rapid Stealth (Brown) |  Rapid-i (Blue) | XT (Brown) | XTi (Green) | XTi (Blue) | Novatouch TKL (Topre) | Topre RealForce 104UB (Topre)
Offline E3E
« Reply #9201 on: Mon, 09 November 2015, 11:34:59 »
Hotswappable backlit Alps project is lookin' good!
Offline trenzafeeds
  • **** off
« Reply #9202 on: Mon, 09 November 2015, 11:36:04 »
That's awesome, I'm really excited to see a full board with them.
demik will never leave.
Unless he gets banned.
Offline E3E
« Reply #9203 on: Mon, 09 November 2015, 11:40:48 »
Thanks trenza! Once I get the plate in, I'll be able to put it in a temporary V60 case (courtesy of eksuen) until the case I ultimately plan on using becomes available.
It's been one helluva project, with tons of hours put in, but it definitely feels rewarding!
Offline trenzafeeds
  • **** off
« Reply #9204 on: Mon, 09 November 2015, 11:42:30 »
Do you have like a making stuff together thread or somewhere with a project log? I'd love to check out the full process.
Offline E3E
« Reply #9205 on: Mon, 09 November 2015, 11:44:28 »
I've been taking pics of the entire process so I can post a build-log, but I've not been sure if I should wait until it's done or to update as I go. What do you think?
Offline trenzafeeds
  • **** off
« Reply #9206 on: Mon, 09 November 2015, 11:47:28 »
I'm ok waiting, I'm just interested to see what kind of work it required.
Offline E3E
« Reply #9207 on: Mon, 09 November 2015, 12:14:52 »
I can definitely tell you it's not for someone without dedication. It was hell! Mainly because the sockets that work for Alps are bigger than the switch mounting holes, so I literally had to bore out every single one. I bought a dremel drill press just for this purpose and it worked well. Furthermore, the Duck Eagle PCB doesn't have as many layouts for Alps as it does for MX. At first, I was going to settle with that, albeit with disappointment, but then I said screw it, I'm not going to settle, and so I drilled out positions for EVERY MX position on the board and then mounted the sockets. I didn't realize that the copper layer would contact the sockets and so many of these positions did not work until I went back and made sure the copper ground plane was not touching any of the sockets. Some of these positions needed to be reinforced with epoxy as well.
It is definitely not as easy as slipping in a socket and being done with it. Especially since Duck's PCBs have frustratingly terrible durability when it comes to pads. Just putting the sockets in caused some pads to lift.
This would be much easier with MX, as those sockets can fit without any drilling.
A huge amount of time went into hand drilling (with a pin vise) the bottoms of every linear switch for LED legs to slip through as linear Alps still does not contain holes for the LED legs on the switch's bottom housing unless it came from the factory with an LED. I also took the time to lubricate every spring for each switch in order to kill the horrendous ping that Alps always tends to have.
Overall, I've poured 30+ hours in this already, but I think the hard part is pretty much done. Now it's just getting the carbon fiber plate to mount the switches, putting it in a case, and throwing caps on! Cherry stabs will work with the recent DCS Alps caps. :D
Did I mention that I grinded the flanges off of 480 2x5x7mm LEDs this morning? :P
« Last Edit: Mon, 09 November 2015, 16:38:43 by E3E »
Offline alienman82
« Reply #9208 on: Mon, 09 November 2015, 14:15:57 »
removed.
« Last Edit: Thu, 01 March 2018, 17:01:04 by alienman82 »
« Reply #9209 on: Tue, 10 November 2015, 03:52:19 »
Square LEDs just look so right with Alps switches.
Offline mason
  • have fun with her, ryan
« Reply #9210 on: Tue, 10 November 2015, 21:40:58 »
116965-0
If only I had two more R1 keys, 1.75 shift, and the bottom row. It reminds me of an hhkb.
Offline julayyy
« Reply #9211 on: Wed, 11 November 2015, 00:07:22 »
Got new O-rings for my keyboard and decided to mess around with my keycaps.  (yes I mixed different profiles but who cares)
Cyan dyesub pbt from geekkeys
Think Different DSA modifiers
GMK Cyan Blank  :D
« Last Edit: Wed, 11 November 2015, 00:10:01 by julayyy »
QuickfireTK MX Reds         v60 mini MX Clears
Offline gadzkun
« Reply #9212 on: Wed, 11 November 2015, 00:43:03 »
woow you actually did it  :thumb:
and its works  :p
Offline phoenix1234
« Reply #9213 on: Fri, 11 December 2015, 08:52:34 »
Testing Table Mat on my keyboard to see if the feeling can change
I like linear switches
Offline E3E
« Reply #9214 on: Fri, 11 December 2015, 08:54:19 »
I dig the look of that mat, haha. Do you mean that you're using it as a dampening sheet in between the PCB and the case, or are your resting the board on it?
Ever since I've been using my desk, I've had my boards on some kind of rubberized mat, so I have no idea what they'd feel or sound like on an exposed hard surface.
Offline phoenix1234
« Reply #9215 on: Fri, 11 December 2015, 09:27:26 »
I'm using it as a dampening sheet in between PCB and the case.
It is thick enough to create a damping layer. I hope it can deliver a better feeling (or not  :)))
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #9216 on: Fri, 11 December 2015, 09:41:53 »
I *think* the dampening layer is used to either eliminate ping or to dampen the bottom-out of PCB-mounted switches. If you experienced ping before you might find that this helps, but I don't expect you'll feel much difference in the keystroke since it looks like your switches are plate-mounted. But I may be wrong! Definitely worth a shot either way.
Offline xondat
  • i'm not a star
« Reply #9217 on: Fri, 11 December 2015, 09:42:28 »
You'll have to provide a couple of updates on this, not heard of this before but sounds interesting.
Offline ramnes
  • T fou, mec?
« Reply #9218 on: Fri, 11 December 2015, 16:53:32 »
The Lindy cable:
Offline E3E
« Reply #9219 on: Fri, 11 December 2015, 16:54:49 »
The Lindy cable:
Hammer Bros. :thumb:
Offline ramnes
  • T fou, mec?
« Reply #9220 on: Fri, 11 December 2015, 16:58:44 »
 :cool:
Offline xondat
  • i'm not a star
« Reply #9221 on: Fri, 11 December 2015, 18:11:50 »
The Lindy cable:
The cap next to the P looks really unhappy...
Offline gerijamide
« Reply #9222 on: Fri, 11 December 2015, 18:38:35 »
new aluminium case, cable from the lovely pexon pcs for the 60% I use at work currently
Offline kohi
« Reply #9223 on: Fri, 11 December 2015, 19:16:06 »
enjoy pbt olivetti set yey
« Reply #9224 on: Fri, 11 December 2015, 19:17:26 »
dude, need to hit up whomever sold you that set and tell them they shipped you the wrong spacebar.
Offline ideus
  • Björkö.
« Reply #9225 on: Sat, 12 December 2015, 12:28:23 »
I add a Zelio tactile with trampoline mod to my space bar in one of my GON Nerd60; it gets all the hollow sound out of the space bar, now it has a very solid feeling. I like it. I made the trampoline mode with a small piece of 50A White Rubber O-Ring, I am considering to add the same to the enter and to the backspace keys.
« Reply #9226 on: Sun, 13 December 2015, 08:15:37 »
My daughter decorated her keyboard.
Offline Jokrik
« Reply #9227 on: Sun, 13 December 2015, 08:21:36 »
Best keyboard ever, I like
give her my compliments
Offline xqwtz
« Reply #9228 on: Sun, 13 December 2015, 12:54:49 »
Put some chocobo and 8bit heart keys that I forgot I had on my choc mini.
Offline xondat
  • i'm not a star
« Reply #9229 on: Sun, 13 December 2015, 15:43:31 »
1 of a kind artisans right there :eek:
Offline ramnes
  • T fou, mec?
« Reply #9230 on: Sun, 13 December 2015, 15:58:15 »
Awesome, how much did you pay for it?
Offline kohi
« Reply #9231 on: Sun, 13 December 2015, 16:06:54 »
my friend helped proxy it over to me, so overall it was around $75 shipped~
Offline dan002
« Reply #9232 on: Sun, 13 December 2015, 20:13:14 »
Really digging that blue legends on the olivetti key set.
Peace, love and keyboards.
Offline ideus
  • Björkö.
« Reply #9233 on: Sun, 13 December 2015, 21:09:33 »
Nice looking blue legends, however I just cannot use PBT at all.
Offline ryof
« Reply #9234 on: Sun, 13 December 2015, 21:29:35 »
This is my first post.
Ergo Dox with Charred Orange and Magic Trackpad 2
Offline ideus
  • Björkö.
« Reply #9235 on: Sun, 13 December 2015, 21:44:42 »
Very nice, and welcome to GH.
Offline Jokrik
« Reply #9236 on: Sun, 13 December 2015, 22:02:35 »
Welcome, that's a really nice setup :)
We have the same macbook riser heh
« Reply #9237 on: Sun, 13 December 2015, 22:26:16 »
Couldn't handle the blanks
120027-0
Offline DanielT
« Reply #9238 on: Mon, 14 December 2015, 03:51:46 »
This weekend I soldered resistors on my NerD60 [CTRL]ALT , it was the first time I've done that, for the first row my hand was shaking like hell :)) After I got the hang of it it was really easy, and no fancy soldering station just a good iron. It took a hour :)
Added purple/pink LED's on the bottom row, waiting for the rest of the LED's , I want a RAINBOW 60% :)
Anyway it was fun and I plan to do next my B.face  :cool:
P.S: The LED's are installed inside the switch, this way I can still open the switch and also the light is warmer and less intense. Can't wait to get the whole board done
« Last Edit: Mon, 14 December 2015, 03:53:19 by DanielT »
Offline MAR82
  • Keyboard Addict
« Reply #9239 on: Mon, 14 December 2015, 05:03:05 »
1 hour to solder all the resistors, on your your first try! I'm impressed  :eek: :thumb:
I don't remember how long it took me to solder all those little bastards on my NerD60. But it felt like it took me forever, and I feel like it should look better (seeing how long it took)  :-[ :(
Offline DanielT
« Reply #9240 on: Mon, 14 December 2015, 05:20:32 »
I have to admit that I was impressed by my performance too  :)) The secret was to organise everything, I've had all resistors ready aligned for pick and place, a good tweezer, good light. Placed a drop of solder on one pad for all the rows and after that it was just a matter of setting a constant pace. After each row I tested if the LED's work. I used an angled 1mm tip on the iron.
It was pure fun, I've always been afraid of those tiny buggers.
Offline E3E
« Reply #9241 on: Mon, 14 December 2015, 05:34:43 »
SMD soldering always intimidates people, but it's not half as bad as it might seem! You are definitely right when you say that organization is the secret of doing something quick and with quality! That goes for things like switch tuning as well. :)
Offline MAR82
  • Keyboard Addict
« Reply #9242 on: Mon, 14 December 2015, 10:30:20 »
After seeing your success, I think you've motivated me to go and finish a board that I had started and never finished.
Now I only need to find the time... :rolleyes:
Offline DanielT
« Reply #9243 on: Mon, 14 December 2015, 10:37:03 »
Glad I've inspired you :) Now I have to find time for my B.face :)) but I feel it will be soon, not this week as I have the graveyard shift at work and I lack the required concentration in the evening :(
Offline tigersharkdude
« Reply #9244 on: Mon, 14 December 2015, 15:02:58 »
a Dolly V2 set
Offline baldgye
  • Will Smith Disciple
« Reply #9245 on: Mon, 14 December 2015, 15:16:59 »
a Dolly V2 set
**** me that reaper is so god damn nice... also the colour on that dolly is insane
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #9246 on: Mon, 14 December 2015, 15:34:20 »
a Dolly V2 set
Those green caps are making me jelly!
Especially that Reaper and Orc!
« Reply #9247 on: Mon, 14 December 2015, 15:36:07 »
Gracias peeps. I was unsure if I'd like the green Dolly but it shoes detail SOOOOO well
Offline mogo
« Reply #9248 on: Mon, 14 December 2015, 16:37:07 »
a Dolly V2 set
Hot damn. I can't pick out what I like most in this pic. Nice board TSD  :thumb:
« Reply #9249 on: Mon, 14 December 2015, 20:20:23 »
Welcome to Geekhack!
Do you use the Trackpad with both hands?
