Author Topic: KBT Pure manual  (Read 7415 times)
Offline Malibu
KBT Pure manual
« on: Fri, 27 July 2012, 16:56:59 »
Hello,
I own a KBT Pure mechanical keyboard with Brown switches. I'm pretty satisfied with it, the switches feel great compared to the Blues I used previously and I like the keyboard's compactness.
The only problem is that I didn't receive a manual with the keyboard, and I can't make any accents.  I asked on other forums but got no answer...
I also type in french so I need those, and I'd like to remain in qwerty.
I tried pressing ` and a successively for example. But it just gives me `a. As for other letters, the keyboard doesn't seem to have an ALT GR key. I also can't find other accents apart from `.
It has some kind of switches at the back (I believe they're called DIP switches or something like that), could they be useful for this?
Offline MadScientist46
  • Snaged his first CCs -> HappyScientist now ^_^
Re: KBT Pure manual
« Reply #1 on: Fri, 27 July 2012, 17:40:24 »
As far as the switches on the back are concerned, maybe this could help you:
http://ck-max.minus.com/mDqxpnoAk/15
As far as I can see they have nothing to do with accents though... :(
Noppoo Choc mini MX-Reds | KBT Pure MX-Reds/Green LEDs
Offline Rumudiez
Re: KBT Pure manual
« Reply #2 on: Fri, 27 July 2012, 19:14:47 »
The keyboard is in ANSI layout, so if you have a functional ALT GR, then something is wrong. I unfortunately do not own a Pure yet, but I don't believe the dip switches toggle any significant layout changes such as ANSI to ISO.
Your best bet would be to try to emulate an ALT GR with Autohotkey: set up a script that recognizes your expected combinations with the right-ALT key.
40% layout, anyone?
Offline Hzza
Re: KBT Pure manual
« Reply #3 on: Fri, 27 July 2012, 19:17:22 »
CTRL+ALT simulates AltGr in Windows I think.
Offline laffindude
Re: KBT Pure manual
« Reply #4 on: Fri, 27 July 2012, 21:41:07 »
Right Alt = Alt-GR.
Offline Malibu
Re: KBT Pure manual
« Reply #5 on: Sat, 28 July 2012, 03:29:57 »
Right Alt = Alt-GR.
Nope. Not on the Pure, at least.
I use Ubuntu... But thanks anyway.
Thank you. But yeah, it has nothing to do with accents, I think...
Did you mean "if you DON'T have a functional ALT GR"?
Well I looked at the link MadScientist46 posted, and the DIP switches don't have any influence on the layout...
As for Autohotkey, I'll use this keyboard on several computers, not just mine. So I'd prefer sticking to the Pure's standard functions unless it is necessary...
Re: KBT Pure manual
« Reply #6 on: Sat, 28 July 2012, 05:23:52 »
received my pure today.
é='+e or right-alt+e, both working here, for example.
and ê is shift+6 and then e.
this may help you to get an overview of the ansi layout: http://en.wikipedia.org/wiki/File:KB_US-International.svg
Offline Malibu
Re: KBT Pure manual
« Reply #7 on: Sat, 28 July 2012, 05:32:38 »
Oh...
Well I tried everything and it doesn't work for me. What could the problem be coming from?
Offline laffindude
Re: KBT Pure manual
« Reply #8 on: Sat, 28 July 2012, 06:21:28 »
Scan code from Alt-GR is exactly the same as R-Alt. If the key works, it will work as Alt-GR. Make sure you're using the correct keyboard layout that actually have Alt-GR. I hate to insult your intelligence, but make sure you're not hitting FN key. It is where R-Alt is supposed to be.
« Last Edit: Sat, 28 July 2012, 06:23:01 by laffindude »
Offline Malibu
Re: KBT Pure manual
« Reply #9 on: Sat, 28 July 2012, 10:19:55 »
Well I switched my layout and it works now.
Thanks.
