Author Topic: Axsotic 3D Trackball  (Read 5090 times)
Offline tash
« on: Sun, 28 November 2010, 19:47:00 »
that thing have buttons?
it seems like not only rotative but up and down moving is used
seems very tricky
« Last Edit: Sun, 28 November 2010, 19:49:05 by tash »
Offline NamelessPFG
« Reply #1 on: Tue, 30 November 2010, 12:47:20 »
I've seen this thing before. My guess is that while the translational axes are joystick-like, just like the Spacetec/3Dconnexion devices, the rotational axes are obviously much more akin to a trackball mouse than a joystick. This should probably help a lot when playing Descent.
Watching the drawing demo gives me an idea of how people already combine 3Dconnexion devices and Wacom Cintiq monitors in their art workflows...(for some reason, 3DxWare has a Photoshop plugin despite that generally being used for 2D work.)
Offline ch_123
« Reply #2 on: Tue, 30 November 2010, 17:11:10 »
It's probably designed for/only usable as a controller for graphics software.
Offline NamelessPFG
« Reply #3 on: Tue, 30 November 2010, 20:18:47 »
Quote from: ch_123;254594
So were the Spacetec products that weren't the SpaceBall Avenger or SpaceOrb 360, as well as everything 3Dconnexion. Guess what GlovePIE does for them?
It passes off their inputs to PPJoy's virtual joystick driver, proper analog support and all, and the scripting capabilities are fairly robust, allowing me to do some crazy things with those inputs if I wanted to. Problem solved.
Of course, that all depends on whether or not such utilities bother supporting that Axsotic trackball in the first place.
Offline EverythingIBM
« Reply #4 on: Wed, 01 December 2010, 18:54:27 »
I want to get an IBM-branded spaceball:
For some reason, the IBM ones just look so much better (IBM even said to make a few of the buttons lavender).
In contrast to this dull looking HP one, yuck:
Offline spring
« Reply #5 on: Sat, 04 December 2010, 07:04:17 »
It looks like you use the digitizer pen for that.
