Author Topic: Just got my MaxKeyboard keycaps, backlightable  (Read 10790 times)
Offline Joe221
  • I'm new here!! Have pity.
« on: Fri, 03 August 2012, 19:34:15 »
I ordered these ($10) and got them today. Excited, as it seems really impossible to get backlit keycaps that are custom. I hope they do more!
The pic is my Tesoro Durandal Ultimate G1NL.
 ;D
Linky:
http://www.maxkeyboard.com/keyboard-parts/key-cap.html
1203-0
Joe in Los Angeles
Offline ryan92084
  • Consumer ****
Re: Just got my MaxKeyboard keycaps, backlightable
« Reply #1 on: Sun, 05 August 2012, 12:15:58 »
about time somebody got into these
RiP *ucky Shine(ing)
Offline Djuzuh
« Reply #2 on: Sun, 05 August 2012, 12:17:10 »
Sleabo is doing customisable backlight keycaps.
Just PM him, and organise a group buy.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #3 on: Sun, 05 August 2012, 12:50:44 »
From my understanding of what's been said, Sleabo's aren't standard profiles.
Filco w/ Imsto thick PBT
Offline Djuzuh
« Reply #4 on: Sun, 05 August 2012, 13:06:50 »
What do you consider standart profile?
Offline alaricljs
« Reply #5 on: Sun, 05 August 2012, 13:10:14 »
A match to either SP or Filco.  Their J series matches Cherry, which I thought didn't match SP or Filco.  Their B series they don't mention one way or the other what it's like.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #6 on: Sun, 05 August 2012, 21:00:55 »
SP can do custom backlit sets, actually.
i am curious what profile these are. maxkeyboard sells rebrands from the same ODM as Xarmor, and i assumed they had the same key OEM as every one of the ODMs over there does, but one doesn't know until one measures :D
can you take some pics comparing the profile of these keys with others you have?
« Reply #7 on: Sun, 05 August 2012, 22:06:45 »
Do you mean like the deck keycaps? I don't remember them offering this service anywhere.
Offline alaricljs
« Reply #8 on: Sun, 05 August 2012, 22:10:19 »
Last item in the list.
fartq
  •  Guest
« Reply #9 on: Sun, 05 August 2012, 22:13:47 »
specifically, they can coat their clear caps and then laser the coating off according to your design.
the nice thing about this, as well, is that the pricing should be fairly good, as they've actually started keeping most of the clear cap profiles in inventory (meaning no molding needs to be done to fill some orders). something to consider, now that we have so many backlit boards on the market.
Offline alaricljs
« Reply #10 on: Sun, 05 August 2012, 22:23:44 »
And there in the fine print is the secret to no clear in the DS's:  it's polycarbonate.
Offline mkawa
« Reply #11 on: Sun, 05 August 2012, 22:25:55 »
i'm not sure how important this is. they can dye their coating any color..
Offline Joe221
« Reply #12 on: Sun, 05 August 2012, 22:54:12 »
I can tell you this. They match my Durandal perfectly. Caps I bought on Ebay are too short for the same row spec. esc and the F keys. I'll post a pic soon with what I bought unless you have your answer.
Joe in Los Angeles
« Reply #13 on: Mon, 06 August 2012, 05:17:11 »
 ;D
Linky:
So would these be the same profile as, say, a Ducky Shine??
Offline Joe221
« Reply #14 on: Mon, 06 August 2012, 10:28:31 »
I'll leave that to the experts with the Duck. I can say these match the MaxKeyboards and my Tesoro. And the source from this manufacturer. Since Max offers no other version and uses them in customizing this series.
Joe in Los Angeles
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #15 on: Mon, 06 August 2012, 10:33:33 »
I like those keys...nice find
-Enzo Ferrari
Offline mkawa
« Reply #16 on: Mon, 06 August 2012, 10:35:15 »
i believe the xarmor boards all use the same profile as filco/ducky/et al, but someone else should confirm, as i've only owned a filco and ducky..
Offline Joe221
« Reply #17 on: Mon, 06 August 2012, 11:37:19 »
I'm trying to post two pictures. Not letting me do it. I shrank them down. just getting white screen.  :(
Joe in Los Angeles
Offline Joe221
« Reply #18 on: Mon, 06 August 2012, 12:34:11 »
From the left: The original Esc key, the Max Running Man key. Then Two keys I bought on Ebay both rated for Esc F-Key row.
Still having image issues. (1 pic uploaded) trying to upload 2nd.
Joe
« Last Edit: Mon, 06 August 2012, 13:18:25 by Joe221 »
Joe in Los Angeles
Offline Joe221
« Reply #19 on: Mon, 06 August 2012, 13:19:50 »
Got the 2nd pic up!
Joe in Los Angeles
Offline alaricljs
« Reply #20 on: Mon, 06 August 2012, 13:20:16 »
Ah GH key, that's SP profile.  :)
(I'm gonna wipe out all the extraneous posts.)
fartq
  •  Guest
« Reply #21 on: Mon, 06 August 2012, 13:22:54 »
the backlit ones are kbc profile for sure
Offline Joe221
« Reply #22 on: Mon, 06 August 2012, 13:23:36 »
Thanks. There are four choice for an attachment. The first one only worked. Was I choosing the wrong ones!?! Also, what is SP profile??
Joe in Los Angeles
Offline alaricljs
« Reply #23 on: Mon, 06 August 2012, 13:48:10 »
SP is Signature Plastics, and most GBs are for their keys.
edit:  I've just run through the attachment options, they all worked.
« Last Edit: Mon, 06 August 2012, 13:55:00 by alaricljs »
Offline Christown
  • MX Blue >
« Reply #24 on: Mon, 06 August 2012, 14:03:21 »
We should get a group buy going for some SP backlightable keys.
Offline MadScientist46
  • Snaged his first CCs -> HappyScientist now ^_^
« Reply #25 on: Mon, 06 August 2012, 14:09:16 »
+1!!!!!!
Noppoo Choc mini MX-Reds | KBT Pure MX-Reds/Green LEDs
Offline Joe221
« Reply #26 on: Wed, 08 August 2012, 16:46:51 »
Is this a possibility? It would be nice. :D
Joe in Los Angeles
