Author Topic: Made a sleeved USB Cable (:  (Read 18596 times)
Offline mistakemistake
  • Global Loveinator
« on: Mon, 06 August 2012, 20:32:05 »
Made my first sleeved USB cable to go with my HHKB
A-Bmini Cable with a new A end assembly
1/4'' Sleeving
« Last Edit: Sat, 25 August 2012, 09:42:42 by mistakemistake »
Offline sth
  • 2 girls 1 cuprubber
Re: Made my first sleeved USB Cable (:
« Reply #1 on: Mon, 06 August 2012, 20:32:51 »
Looks great!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Mon, 06 August 2012, 20:39:15 »
Looks really good. Where did you source the parts?
  • Global Loveinator
« Reply #3 on: Mon, 06 August 2012, 20:43:02 »
I used the USB cable that came with my first keyboard
Sleeves/Heat shrink from Frozencpu
USB connectors from L-com
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Mon, 06 August 2012, 20:46:43 »
Thanks for the tip, I'll keep those place in mind ;D
« Reply #5 on: Mon, 06 August 2012, 21:02:17 »
Y U (: IT'S : )
Offline whiskerBox
« Reply #6 on: Mon, 06 August 2012, 21:10:29 »
Nicely done! You won't lose that lol
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
  • Global Loveinator
« Reply #7 on: Mon, 06 August 2012, 21:12:27 »
hah, thanks. not as pro as your cables though
Offline whiskerBox
« Reply #8 on: Mon, 06 August 2012, 21:16:06 »
Shiiit I just slop things together and hope they look decent lol.
  • Global Loveinator
« Reply #9 on: Mon, 06 August 2012, 21:40:48 »
Hah! Well either way, your cables are still hella pro!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Re: Made my first sleeved USB Cable (:
« Reply #10 on: Mon, 06 August 2012, 22:10:40 »
Nice job, what type of sleeve are you using?
-Enzo Ferrari
  • Global Loveinator
« Reply #11 on: Mon, 06 August 2012, 22:43:02 »
thanks, bitspower
Offline Anynoupy
  • French Fries
« Reply #12 on: Wed, 08 August 2012, 08:02:07 »
Nice one ! :)
I tried to do some sleeving myself, but ended up with not enough tightened sleeve and, more importantly, heatshrinks ... :(
  • Global Loveinator
« Reply #13 on: Wed, 08 August 2012, 13:03:04 »
Yeah, I didn't have the right size heatshrink at first either. Just need to play around with different sizes until you get the fit you want.
Offline ACallander
    • Portfolio
« Reply #14 on: Wed, 08 August 2012, 13:10:55 »
Wow looks great! I've always wanted to sleeve my USB keyboard and mouse cable. You should create and post a tutorial on GH.
Sent from ACals iPhone using Tapatalk
  • Global Loveinator
« Reply #15 on: Wed, 08 August 2012, 13:17:54 »
Eh, I'll think about it. But if you're looking to get a sleeved cable, Whiskerbox is the man to hit up
Offline Asininity
« Reply #16 on: Fri, 10 August 2012, 13:33:05 »
Sleeved cables look so fantastic. Great job.
I second a tutorial!
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #17 on: Sat, 11 August 2012, 23:42:11 »
I'll third it :D I want a green one to match my new KB, so unless someone wants to sell, I guess I'm gonna be making one myself.
TOO BAD FOR YOU
              Phantom 62g MX Whites
  • Global Loveinator
« Reply #18 on: Sat, 11 August 2012, 23:49:13 »
I'm still waiting on a few parts I ordered. In the mean time, check out Whiskerbox Cables Hella pro
« Last Edit: Sun, 12 August 2012, 00:05:53 by mistakemistake »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #19 on: Sun, 12 August 2012, 00:46:58 »
Looks great!
Offline Viz
« Reply #20 on: Fri, 17 August 2012, 09:05:31 »
Very nice, they look professional :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #21 on: Fri, 17 August 2012, 09:11:04 »
Is this a stock cable that came with your keyboard? What dia. sleeving did you get? What dia. heat shrink did you get?
  • Global Loveinator
« Reply #22 on: Fri, 17 August 2012, 15:36:20 »
Yeah, cable from my leopold, 1/4'' dia on the sleeving, 1/4'' and 1/2'' heatshrink. I'm about to make a purple one
Offline Rafen
« Reply #23 on: Sat, 18 August 2012, 09:30:01 »
This looks amazing! I think I might have to try and do one of these myself.
Offline never4getthis
« Reply #24 on: Fri, 24 August 2012, 10:52:18 »
For those requesting a tutorial it is not that hard. Go to your hardware store and buy computer cable sleeving. you can get it in different sizes. The only tricky part is making a clean finish where the cables end. In the picture above I think that the ends are simply tucked under the rubber head.
Typist
Noppoo Choc Mini (Cherry MX Blue)
Offline 1stGenRex
« Reply #25 on: Fri, 24 August 2012, 10:55:09 »
Sweet tutorial, Bro!
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #26 on: Fri, 24 August 2012, 11:16:59 »
Can you share what thickness sleeve and heat shrink you used?  They seem to come in a lot of sizes
« Reply #27 on: Fri, 24 August 2012, 12:10:11 »
I am not sure, what the size of the heatshrink is. I took my keyboard to the hardware store, they had wheels (you payed by length) with different cable sleeve sizes (and colours). My Choc Mini has 4mm cable so I got a 3mm for it to fit on nicely. The shopkeeper supplied the heat shirk suitable for my cable.
If any of you want to make one, take the cable with you, a visual reference of the cable is the best way to make sure that you get the right size. I'
P.S. If any of you are attempting to do this in a keyboard with a non-detachable cable (like me) please share how you made a nice finish in the end of the cable that touches the keyboard. I have tried  heat shrink and it looks horrible  :(
Typist
  • Global Loveinator
« Reply #28 on: Fri, 24 August 2012, 15:48:32 »
Sleeve size is 1/4'' In the original pictures above, I used a standard size USB A Hood.  I also tried it again with a smaller size heat shrink and came up with this, which also didn't have a very good heatshrink seal:
I just got some ordered parts in and just made these a few minutes ago:
So...
Sleeve size: 1/4'"
Heatshink size: 3/8"
USB A 1.5" End Connector
hope that helps!
  • techkeys.us
    • TechKeys
« Reply #29 on: Fri, 24 August 2012, 16:17:32 »
So...
Sleeve size: 1/4'"
hope that helps!
Thanks! I might take a shot it it!
Offline ra7c7er
« Reply #30 on: Fri, 24 August 2012, 16:27:33 »
Looking good. Building cables is fun... at least to me. Though mine never come out as clean as yours have.
  • Global Loveinator
« Reply #31 on: Sat, 25 August 2012, 09:06:48 »
thanks, just keep trying and use different materials until you like what you come up with..
Offline Tenkey
Re: Made a sleeved USB Cable (:
« Reply #32 on: Sat, 25 August 2012, 18:55:17 »
Lol nice i take that you've done some pc builds before and sleeved some psu cables? Otherwise if thats your first time sleeving thats just awesome.
  • Global Loveinator
« Reply #33 on: Sat, 25 August 2012, 19:03:36 »
actually the first green cable picture in the thread was my first. The second set of pictures was my second run I did just within the last few days.
  • Global Loveinator
« Reply #34 on: Sun, 09 September 2012, 21:20:04 »
So...
Sleeve size: 1/4'"
hope that helps!
Were you able to come up with anything? I have a little bit of left over material if you'd like it.
Offline mushupork
  • I am not knowing
« Reply #35 on: Fri, 14 September 2012, 23:34:00 »
The sleeved cable is very sharp - has anyone tried with a non-removable cable and have pics?
Wanted:  Windowed capslock for a QFR
Offline swagpiratex
« Reply #36 on: Mon, 17 September 2012, 00:38:51 »
All you military buffs should try with 450 or 550 paracord :D
Offline suprsmo
  • Sydney, Australia
« Reply #37 on: Mon, 17 September 2012, 00:59:03 »
Nice dude.. and cheers for the measurement.
May have to make a purple cable with white heat shrink maself :D
Poker
QFR
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: Made a sleeved USB Cable (:
« Reply #38 on: Mon, 17 September 2012, 01:04:40 »
check out wiskers cable i believe he has.
Offline sth
« Reply #39 on: Mon, 17 September 2012, 01:06:21 »
you can use bootlaces too!
Offline suprsmo
  • Sydney, Australia
« Reply #40 on: Mon, 17 September 2012, 01:08:19 »
Mmm based on your measurements, this shop is no good.. http://www.pccasegear.com/index.php?main_page=index&cPath=1354_1357
Oh well.. Might have to do some scouting around next weekend or something.
Poker
QFR
Offline Input Nirvana
« Reply #41 on: Mon, 17 September 2012, 01:11:57 »
Like this thread. So nice to dress up/personalize the plain, mega-milions of techy shizz. It's motivating, fun, reduces your blah days and will get you laid A LOT.
Offline Calade
« Reply #42 on: Mon, 17 September 2012, 06:18:17 »
Looks really good, may have to try that myself. Although I'm horrible at handicrafts of all sorts. :rolleyes:
Offline swagpiratex
« Reply #43 on: Mon, 17 September 2012, 10:50:13 »
Found this site yesterday, seems like he knows what he's doing:
http://www.overclock.net/a/lutro0s-video-guide-to-sleeving
Offline sth
« Reply #44 on: Mon, 17 September 2012, 14:47:43 »
practice and patience :)
Offline whiskerBox
« Reply #45 on: Tue, 30 October 2012, 20:58:55 »
Thats actually got some good tips in it, although it is aimed more a t PC components.
  • Global Loveinator
« Reply #46 on: Wed, 01 May 2013, 04:21:31 »
Wow, this thread is OLD and that cable looks terrible.
Offline esoomenona
  • Gnillort?
« Reply #47 on: Wed, 01 May 2013, 09:03:03 »
Aww, everybody loved your cables right from the beginning. And as you grew in making them, our love grew with you.
