Author Topic: looking for a machanical keyboard with blue backlit and blue swichtes  (Read 2264 times)
Offline battet
Hi all
im having hard time to make a decission on what keyboard i should buy
the first thing that fell in mind was BWU. but i have been arround here some days now and
you guys seems not to like the build quality of that keyboard. i have looked at max keyboard but it doesnt really look that good
and is it even possible to get a keyboard with macro keys that is build solid ?
what board would fit the needs ?
Offline okooko
  • afk.
Re: looking for a machanical keyboard with blue backlit and blue swichtes
« Reply #1 on: Wed, 15 August 2012, 19:27:48 »
Hi,
The first KB that came to mind was the Razer Blackwidow, it has everything that you described and macro keys also and surprisingly they use Blues.
Other options (my small KB knowledge says) Ducky's have various colored back lighting options with various switches also, might be worth looking into.
Oko
« Reply #2 on: Wed, 15 August 2012, 20:42:49 »
Lots of POS keyboards (like cherry G80-8113) have lots of programmable keys. I'm using mine for media, but there's no reason you couldn't use it for other macros as well. It's really easy to program, and super solid. No NKRO on mine, but it does exist on others.
Others like my Access-IS POS keyboards. They are fully programmable, though you need 32-bit windows and a PS2 port to program it. It has NKRO, and although the programming software isn't as good as cherry, I do think you can make arbitraty macros on it.
One keyboard you "might" consider is the infamous corsair K90. I do believe the macro keys are RD, though the main keys are cherry Red, which is nice.
The recently-arrived phantom, the upcoming XTant, and ergoDOX will also be Teensy-based, and therefore fully programmable.
None of them are backlit, though (not as far as I know, anyway).
The Razer gets a lot of hate, but some people have been using them for some time with little issues. Looking at the disassembly pictures, I wouldn't call it up to costar's high bar for quality, but it shouldn't be as awful as all that.
I'll let the BW owners chime in with firsthand accounts.
Offline wiredPANDA
« Reply #3 on: Wed, 15 August 2012, 20:48:53 »
The Ducky Year of the Dragon keyboard is blue backlit with MX Blues.  Not sure if it'll meet the rest of your criteria, though.  MechanicalKeyboards.com has some in stock, last I checked.
| HHKB Pro 2 | Leopold FC660C
| Poker.PANDAclears | ErgoDox (62g Black)
« Reply #4 on: Wed, 15 August 2012, 20:52:40 »
Just been typing on my Dragon with blues, no macros, but the board is the most solid board I own now. And amazing backlights. As for macros, could just get a program to use to make any key a macro I believe.
Offline wiredPANDA
« Reply #5 on: Wed, 15 August 2012, 20:54:30 »
AutoHotKey
And yes, it can be used to script macros on key presses.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Wed, 15 August 2012, 21:49:21 »
own a razer bwu............and really no issues. tactile and clicky
larger keys with stabilizers are a little mushier than rest, but still very responsive and own up to blues- good solid board. heard the same about duckys as well......... razer i would think due to aesthetics is geared to a younger crowd?
i swapped most of the keys out as i really don't care for the font, etc. a ducky would have been much easier ;)
3 levels of brightness on blue "leds" from soft to very bright.
actually enjoy the macro keys after set-up and the downloadable software makes it easy to do as a cinch. if you game a lot you can record macro's very easily for shortcuts.
at this point own other mechanical keyboards, but still...........could of had a filco as i don't need or use all the bling.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
