Author Topic: 10 key pad  (Read 2925 times)
Offline The_Beast
  • I like wood ಠ_๏
10 key pad
« on: Fri, 17 August 2012, 09:09:21 »
I was wondering if I bought a separate number pad, would my computer see it as a separate input device and there for be able to write an autohotkey script to make it a giant macro/hot key board? Would this work with a fullsized keyboard?
Offline longweight
  • philanthropist
Re: 10 key pad
« Reply #1 on: Fri, 17 August 2012, 09:11:06 »
Mine is recognised as the numberpad, I haven't tried to do anything funky in Autohotkey though!
Offline damorgue
    • Personal portfolio
Re: 10 key pad
« Reply #2 on: Fri, 17 August 2012, 09:11:54 »
I think that the 3700 numpad I got from nntnam appears as one keyboard, and the other one which is connected to that numpad is hidden from the OS.
Edit: It also masks out macros which I have on the large board.
Offline The_Beast
  • I like wood ಠ_๏
Re: 10 key pad
« Reply #3 on: Fri, 17 August 2012, 09:13:29 »
If I have a fullsized, would it see it as a separate input device? If so, could a autohotkey script be written for that specific input device?
What I want is a number pad that works as a number pad (on the keyboard) and a separate 10 key pad for macros.
Offline alaricljs
  • I be WOT'ing all day...
Re: 10 key pad
« Reply #4 on: Fri, 17 August 2012, 09:32:32 »
It's dependent on whether the boards use the same input driver.  Most do.  There are workarounds on the AHK forums to force scripts to trigger on specific USB HIDs.
Filco w/ Imsto thick PBT
Offline The_Beast
  • I like wood ಠ_๏
Re: 10 key pad
« Reply #5 on: Fri, 17 August 2012, 09:35:50 »
Sweet! I'll look for those scripts before I buy tho ^__^
