Author Topic: Poker PBT Question  (Read 2566 times)
Offline therecorder
Poker PBT Question
« on: Sat, 18 August 2012, 19:26:34 »
This is a Poker with PBTs (ones with pinkish lettering) that I recently bought.  Notice the small tits on the back, top, middle of each keycap. Is this normal?
Re: Poker PBT Question
« Reply #1 on: Sat, 18 August 2012, 19:33:22 »
I believe those are the sprue marks from where they pour the plastic to make the caps. Such as Signature Plastics marks like that being on the front of their caps.
Offline therecorder
« Reply #2 on: Sat, 18 August 2012, 19:39:36 »
Sounds logical...  If you expand the photo, you can see that the R3 marks are a little lower than the R4 ones.
« Reply #3 on: Sat, 18 August 2012, 19:43:56 »
I would guess that it's because of the way the mold was made. Best bet would be to find someone else with the PBT caps to ask, unfortunately my poker came with abs caps which were gone before I looked at them much.
« Reply #4 on: Sat, 18 August 2012, 19:49:46 »
Yes, I have Poker PBTs and the spruce marks are located here.
Offline therecorder
« Reply #5 on: Sat, 18 August 2012, 19:55:17 »
Thanks much for the quick reply...  Nice to know...  Learn something new all the time (even at 64).
