Author Topic: buy (pbt) doubleshots  (Read 3849 times)
Offline gigibecali
« on: Wed, 22 August 2012, 05:28:53 »
Where/from whom can I buy new (PBT) doubleshots?
Are they available on taobao or somewhere else?
I live in EU.
Thank you.
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline 1stGenRex
Re: buy (pbt) doubleshots
« Reply #1 on: Wed, 22 August 2012, 06:45:22 »
It's my understanding (although VERY limited) that PBTs cannot be double-shot, and that's why they are not so common. Dye Sub PBTs are common, as are laser engraved ones, but I've never seen doubleshot.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Wed, 22 August 2012, 07:18:30 »
Deck is the only company that can DS PBTs AFAIK
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Re: buy (pbt) doubleshots
« Reply #3 on: Wed, 22 August 2012, 11:21:59 »
Didn't know pbt ds was possible...got link?
-Enzo Ferrari
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #4 on: Wed, 22 August 2012, 11:27:09 »
Deck's translucent legends? Those are Painted keys with the legends lazered  off (or otherwise removed).
AFAWK Doubleshot -> ABS, Dyesub -> PBT
Is OP just looking for doubleshot keys and which ones?
Fight For Freedom. Stand with Hong Kongers
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Wed, 22 August 2012, 11:30:18 »
NO, they do not exist, or if they do only on some obscure keyboard that you will never find. And Deck are not doubleshot, they are dyesub on translucent.
It is possible in theory to doubleshot pbt, but the tolerances are so specific and calculate shrinkage etc, that there would probably be defect free yields very low which would make them very expensive to produce in comparison to abs.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #6 on: Wed, 22 August 2012, 11:36:36 »
Deck's are not double shot.  They are 2 part glue-ups with that dye-sub bit lysol mentioned.
Filco w/ Imsto thick PBT
