Author Topic: Post Your Phantom Pictures Here!  (Read 183415 times)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: Post Your Phantom Pictures Here!
« Reply #250 on: Fri, 06 September 2013, 16:17:11 »
The lighting in my office + my crappy cell phone camera + my picture taking skills = a really bad potato pic
Now if I only had some key caps.... :-[
Nice work your almost there some caps and a case to complete it.
Sir JDCarpe did the assembly for me  :thumb:
And it's technically in a case just waiting on a custom top.  8)
cheater ;)
« Reply #251 on: Fri, 06 September 2013, 16:25:34 »
cheater ;)
It's a long story but thanks to JD again! He is a great guy.
And soon I will build (destroy) 'something' myself or I just need to sell all the sweet soldering/assembly gear I've accumulated.  ;D
« Reply #252 on: Fri, 06 September 2013, 16:26:10 »
I had fun building Ray's Phantom. Once you get into a groove on the diodes, it's not that bad.
Here is mine I built about the same time I was doing Ray's:
Offline Glod
    • YouTube Channel
« Reply #253 on: Fri, 06 September 2013, 16:30:32 »
love the layout, are you going to put some plastic to cover the exposed plate?
« Reply #254 on: Fri, 06 September 2013, 16:32:29 »
No, I don't mind it. Plus it reminds me that Ctrl is not placed there, since my finger falls into that hole. :))
Offline Glod
    • YouTube Channel
« Reply #255 on: Fri, 06 September 2013, 16:36:40 »
oh, if i would have done the same thing i would have painted the plate black then :X but that is the only critique i have of it, i love the layout, i am now telling myself why didnt i get your HHKB layout? i went for the WFD design instead :X
« Reply #256 on: Fri, 06 September 2013, 16:38:58 »
HHTKL? :D
« Reply #257 on: Fri, 06 September 2013, 16:47:19 »
Mine here is a little different from the HHK150 from the GB.
HHK150 (painted black):
The one I built uses a 6-unit spacebar, and has a 2.50-unit open space on the right, with no holes on the outsides for switches in the bottom row.
I messed up my stabilizer spacing on this plate, so I had to stem mod my 6-unit DSA spacebar to make it work. I used stabilizer spacing from a Cherry 6-unit spacebar, but with a centered stem. The DSA stab stems are closer to the middle.
Offline Glod
    • YouTube Channel
« Reply #258 on: Fri, 06 September 2013, 16:59:45 »
you tricked me haha :)
Offline duq
  • Connoisseur
« Reply #259 on: Fri, 06 September 2013, 17:20:22 »
GAHHHHHHHHHHHHHH I wish I had my plate from the GB so I can finish my project :(.
Offline MJ45
  • HHKB Pro
« Reply #260 on: Sat, 07 September 2013, 09:23:33 »
Some updated pics of my Phantom. I used a QFR case but hate the rubberized finish so I painted it with some Rustoleum metallic paint (satin nickel) it makes it look like a metal case now. It also matches my computer what should come with Apples instead of the cheap junk they come with. When I get some better keycaps I will do a different paint scheme, I have 2 more top covers from the GH Anniversary deal Cooler Master had going on.
« Reply #261 on: Sat, 07 September 2013, 12:40:28 »
so I threw on some keys I had in my desk.
34482-0
Offline Dubsgalore
« Reply #262 on: Sat, 07 September 2013, 12:45:42 »
Finally a picture
pretty funky looking haha
Offline Sai
« Reply #263 on: Mon, 09 September 2013, 20:51:30 »
so here's my phantom with acrylic case from takaki.
Offline Vintage
« Reply #264 on: Mon, 09 September 2013, 21:00:10 »
Wow! They came out nice... would love to see a side pic! :p
Is that Red/black?
CM QFR w/ MX Reds  | Logitech G900
Offline Dubsgalore
« Reply #265 on: Mon, 09 September 2013, 21:09:15 »
i think i know what that needs ;)
Offline Sai
« Reply #266 on: Mon, 09 September 2013, 21:15:24 »
i went for black/clear/black.
this is the only side pic that i have right now.
some issues though. The screw holes at the bottom are big for the screws by a few mm and because of that, i can just push down the screws with brute force ;D
Dolch ?  :))
Offline Dubsgalore
« Reply #267 on: Mon, 09 September 2013, 21:21:55 »
Bingo
« Reply #268 on: Mon, 16 September 2013, 21:06:42 »
I like it.
Offline MJ45
  • HHKB Pro
« Reply #269 on: Thu, 19 September 2013, 13:19:14 »
Here is my final completed Phantom the way I had originally envisioned it to be. It turned out fantastic considering it my first keyboard build! All the components were found on GH classifieds Phantom kit, vintage black switches, QFR (case donor), Cherry plate mount stabs., and the Dolch caps. The only thing not is the 62g Korean springs from Originative. Not up to the cost for a Korean Kustom (Kmac or LZ) this Phantom will give me a good as it gets Cherry MX experience.
« Reply #270 on: Thu, 19 September 2013, 15:38:12 »
I like it.
He looks so good on the keyboard!
Offline whiskytango
  • Don't touch the trim
« Reply #271 on: Thu, 19 September 2013, 22:32:30 »
@MJ45: very nice! Did you paint that QFR top? What kind of paint is that?
Offline MJ45
  • HHKB Pro
« Reply #272 on: Fri, 20 September 2013, 07:28:25 »
Yes I painted that with Rust-Oleum Universal Metalic paint and primer in one Satin Nickel. It turned out nice looking like a bead blasted alum. case. I just wet sanded the rubberized finish off and painted it, good stuff.
Offline whiskytango
« Reply #273 on: Thu, 03 October 2013, 22:09:43 »
Built it last week, finished spring swap today. Please ignore case imperfections as it is going to be painted eventually when I get to it.
Specs:
Phantom with ANSI150 plate
QFR case with Filco style LED holes drilled
Pink lock LEDs
Blue switches
80g springs from Originative
Orange stickers
Mixed WYSE original keys + WYSE tsangan kit + Partial WYSE moogle kit
Potato pics:
Offline MJ45
  • HHKB Pro
« Reply #274 on: Fri, 04 October 2013, 10:23:36 »
@whiskytango; nice build, I really like the pink led's!
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #275 on: Fri, 11 October 2013, 08:45:40 »
JD, please, this plate of yours - it fits into the "official" phantom PCB? They are selling the PCB at mechanicalkeyboards.com and I would like to know if it works with that PCB.
« Reply #276 on: Fri, 11 October 2013, 09:36:55 »
Yes, my HHK150 plate works perfectly with a Phantom PCB. :)
Offline esoomenona
  • Gnillort?
« Reply #277 on: Fri, 11 October 2013, 09:47:40 »
JD, I know we discussed that thing, and then I looked into my box of wonders, and I realized I actually did buy that plate. I guess I was ahead of my time in thinking it might be something I wanted. Unfortunately, MX... I'm not sure if I should keep it just in case, and grab a white Phantom PCB or what.
« Reply #278 on: Fri, 11 October 2013, 09:49:12 »
I thought you had bought one. You have to build it!!
And I'm having none of your Thorpe snobbery. MY or die!
Offline esoomenona
  • Gnillort?
« Reply #279 on: Fri, 11 October 2013, 09:57:40 »
I do have an extra case that I could put it in... I think I will build it.
MK is out of Phantom PCBs? :/
« Last Edit: Fri, 11 October 2013, 10:04:43 by esoomenona »
Offline gnubag
« Reply #280 on: Fri, 11 October 2013, 13:25:52 »
nope, still 5+ in stock for me
Offline esoomenona
  • Gnillort?
« Reply #281 on: Fri, 11 October 2013, 13:39:37 »
Yeah, I found them again. They're not under the keyboard parts with other PCBs like I thought they'd be though.
« Reply #282 on: Fri, 11 October 2013, 13:49:09 »
« Reply #283 on: Sat, 12 October 2013, 09:28:01 »
Woohoo, another chance to post my toys!
« Reply #284 on: Sat, 12 October 2013, 11:17:11 »
^ QQ
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #285 on: Sat, 12 October 2013, 11:27:46 »
Hello?  What is the name of case Colour ?  Awesome!   :thumb:
Offline Moosecraft
  • HHKB Pro
« Reply #286 on: Sat, 12 October 2013, 12:32:52 »
Looks like a sky blue vortex case to me.
Offline Glod
    • YouTube Channel
« Reply #287 on: Sun, 13 October 2013, 02:11:55 »
after all this mess http://geekhack.org/index.php?topic=26742.msg1075038#msg1075038 i finally got my 2nd Phantom together
The story behind this phantom is that it was built for the cheapest you can build one for. About a half year ago Amazon had some cherry mx blue QFR Rapids for only $55. i grabbed two. One of them i sold the PCB and i had all the parts, like the plate and case and i never ended up using the switches. So when MK came along and stocked PCBs i decided to make one using the plate and case that was collecting dust
The case is not painted, its white vinyl wrap. It looks better in pictures than it does in person, though it was my first try i think i can do better. The plate was painted white.
sadly i found that i have lost the backspace cap to my raindrop set :(
I still have 2 Phantom PCBS and 1 of those is for myself, ill be putting ergo clears on it and using a case made by MOZ. excited....
Offline deSheol
  • Thorpe
« Reply #288 on: Sun, 13 October 2013, 03:58:44 »
Is that a Filco plate?
Offline Glod
    • YouTube Channel
« Reply #289 on: Sun, 13 October 2013, 13:30:53 »
As i said in the post you are quoting, all the parts came from a QFR Rapid
Offline Photoelectric
« Reply #290 on: Sun, 13 October 2013, 14:11:04 »
Never mind--figured it out!
Offline agodinhost
    • Dr Ian O Xaman
« Reply #291 on: Mon, 14 October 2013, 08:58:31 »
Where did you got the case? please?
Offline esoomenona
  • Gnillort?
« Reply #292 on: Wed, 16 October 2013, 08:42:52 »
The case is from a QFR. I traded the insides, but kept the case.
Offline acantha
  • Aure Entuluva
« Reply #293 on: Sat, 19 October 2013, 02:16:02 »
JUST finished my phantom build! it was a bit tedious at times (see also: diodes) but a lot of fun, and it looks AMAZING!
Here's the final result:
The case is (obviously) acrylic and was made by MOZ as part of his Open Source Acrylic Phantom/TKL Case project.
A full album of my build is here: http://imgur.com/a/ZuQ4H
All the Happy Hacking Things
« Reply #294 on: Sat, 19 October 2013, 02:28:35 »
That looks great!  The Toxic Set would be ideal on that.
Is Ono Sendai a brand of something?  Or someone's name?  I recognise it from Neuromancer.
Offline acantha
  • Aure Entuluva
« Reply #295 on: Sat, 19 October 2013, 02:36:23 »
The Ono Sendai Cyberspace 7 was the deck that the main character of Neuromancer, Case, used. it was apparently SUPER LEET and my 16 year old self though it would be equally LEET to name my ****t PC after it, and i've retained the tradition since.
Offline vasouv
« Reply #296 on: Sat, 19 October 2013, 02:50:25 »
Offtopic to the thread but could you tell me where you got the keycaps for your little keyboard? (the one on top) I really LOVE the font of the keys, that's the best looking font I've seen in all the pictures people are posting...
« Reply #297 on: Sat, 19 October 2013, 02:52:48 »
Neuromancer, Count Zero and Mona Lisa Overdrive - I know them well.
Also the Fragments of a Hologram Rose by Thirteen13 :)
« Reply #298 on: Sat, 19 October 2013, 13:16:09 »
That's a pretty sweet Phantom case with a lot of personality!  Good work, acantha and MOZ!
Offline sprit
« Reply #299 on: Sun, 20 October 2013, 06:17:39 »
Beautiful ! Que Bello!
