Author Topic: Post your Poker!  (Read 1347331 times)
Offline albus1987
Re: Post your Poker!
« Reply #1100 on: Mon, 15 July 2013, 00:02:07 »
My new DIY Poker  ;D
Offline domoaligato
« Reply #1101 on: Mon, 15 July 2013, 00:12:31 »
My new DIY Poker  ;D
looks good... I can tell the case is DIY care to tell us more?
Offline albus1987
« Reply #1102 on: Mon, 15 July 2013, 01:31:56 »
The acrylic case consists of totally 5 layers, white and transparent, as shown in these pictures. The middle white layer is also the plate.
Offline WhiteFireDragon
    • youtube
« Reply #1103 on: Mon, 15 July 2013, 03:04:16 »
Here's how my poker 2 looks now, I vinyl dyed the spacebar charcoal grey, which looks more black actually, and burgundy on the mods. I mighttt paint the rest of the keys charcoal grey, but I'm not sure yet. I'll stick with this for awhile to see how it goes.
The tab is kind of dirty, but I cleaned it already, don't worry :p
I haven't seen a successful dye in a while. That crimson color looks awesome.
What do you mean it was "vinyl dyed"? Is this the same type as RIT dye or dying cloths?
Offline damorgue
    • Personal portfolio
« Reply #1104 on: Mon, 15 July 2013, 03:22:15 »
Using thin abs to snap photo is back idea back then.
Stock PBT ftw.
Nice! LEds are cool. Is there a resource or guide anywhere on how to install them?
Enjoy
Liquid or dissolved powder dye? Did you stir or do anything special to get them that homogenous? Length of soak?
Offline Photoelectric
« Reply #1105 on: Mon, 15 July 2013, 08:59:14 »
It's spray dye, I believe.  This
http://www.duplicolor.com/products/vinylFabricCoating/
in "Burgundy"
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #1106 on: Mon, 15 July 2013, 09:57:02 »
My new DIY Poker  ;D
I really like that case :p
Offline pmh1410
« Reply #1107 on: Mon, 15 July 2013, 10:06:43 »
My new DIY Poker  ;D
You can buy this case from Alixinhzai. He make it.
Offline domoaligato
« Reply #1108 on: Mon, 15 July 2013, 13:01:36 »
My new DIY Poker  ;D
I have 2 of them on the way. I was curious what as DIY. I understand now that this is in regards to the desoldering/resoldering of all the switches and the other work required to transfer the poker into the case.
I was thinking maybe it was a hardwired poker without a pcb....
this is my next project as long as the switches plate mount into Alixinhzai''s case firmly and do not wobble without the extra metal plate. I will have to wait and see.
Offline gnubag
« Reply #1109 on: Mon, 15 July 2013, 13:10:03 »
My new DIY Poker  ;D
a poker without a pcb is not a poker :)
it would be a hardwired 60% l0l
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1110 on: Mon, 15 July 2013, 13:18:35 »
I used VHT Vinyl Dye.
Here's how my board looks now, swapped out those ugly stock alphas
I wonder how thsi would look with a titanium spacebar.. too bad I ain't got that much $$ to spare haha
« Last Edit: Mon, 15 July 2013, 13:22:16 by kenmai9 »
Offline domoaligato
« Reply #1111 on: Mon, 15 July 2013, 13:20:33 »
yeah... but there are pure's/gh60's and poker II''s in this thread also lol
Offline pixel5
    • pixel5
« Reply #1112 on: Mon, 15 July 2013, 13:44:01 »
That's a spray can? How many coats did you use and how is it holding up? Do you feel like it would fade after a while? I am thinking about getting a set of white ABS keys and custom dying them. I don't want to spend $16 on dyes and it not work well. Thanks!
Poker II
Quickfire Rapid
BUY MY CRAP
Offline damorgue
« Reply #1113 on: Mon, 15 July 2013, 13:53:02 »
I don't think ABS dyes very well usually. People use PBT for that.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #1114 on: Mon, 15 July 2013, 16:10:30 »
Black Scale clothing is awesome. And this board looks great!
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline aj-kun
« Reply #1115 on: Tue, 16 July 2013, 15:45:06 »
This Poker 2 has browns, the blues on my filco feel a lot smoother, these feel kinda scratchy. Do browns get smoother?
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1116 on: Tue, 16 July 2013, 15:55:07 »
Its a spray can, that s hoots out vinyl dye. Cool huh?
You can do 2-4 coats, depending on how light coats you did. I recommend lightest as you can with full coverage. Its kind of hard to get the hang of. I don't think they fade. But when I painted using it it left some white residue, probably a result of improper cleaning of oils on the plastic. So make sure to clean it up good. If you have white residue, get a microfiber cloth and soapy water and rub the white residue and it should go away after awhile.
This looks good!
Offline pixel5
    • pixel5
« Reply #1117 on: Wed, 17 July 2013, 22:33:36 »
Can anyone tell me what profile the Poker modifiers are? The black and red w/white legends set. They appear to be a little shorter than standard...
BONUS POINTS: Show me a picture of the poker mods on a keyboard with DSA caps and/or side by side with DSA caps.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #1118 on: Sun, 21 July 2013, 01:54:29 »
Added some leds to my Poker II over the weekends.
Just playing around with colours  :D
With the ducky keycaps.
End product.
Took me sometime to desolder the solder of the pcb. very tedious job indeed.  :(
But it's worth it. :D loving my poker II.
Offline PointyFox
« Reply #1119 on: Sun, 21 July 2013, 02:06:56 »
End product.
Kind of reminds me of these:
« Reply #1120 on: Sun, 21 July 2013, 02:14:20 »
End product.
Traffic light cake?
« Reply #1121 on: Sun, 21 July 2013, 14:32:04 »
I would totally love one of those with these LEDs: (function row to spacebar:) orange, amber, yellow, neutral white, purple (pink)--as a gradient.
Offline yearn4
  • formerly known as 4en
« Reply #1122 on: Mon, 22 July 2013, 15:30:50 »
i'm done adding caps to my pokers for now :) mx blue for the shades of blue one on top and mx red for the red/black/purple on bottom
(THAT IS UNLESS I GET A CC FROM MR CC n.n)29040-0
« Reply #1123 on: Mon, 22 July 2013, 15:57:57 »
(THAT IS UNLESS I GET A CC FROM MR CC n.n) (Attachment Link)
I love the look of that blue poker :p
Offline yearn4
« Reply #1124 on: Mon, 22 July 2013, 15:59:02 »
me more!29048-0 here's a better picture
Offline Thimplum
  • Master of all Ponies
« Reply #1125 on: Mon, 22 July 2013, 16:48:46 »
End product.
yum
TP4 FOR ADMIN 2013
Offline jil_jil32
  • Tokyo Press <3
« Reply #1126 on: Tue, 23 July 2013, 21:09:57 »
simply old
Offline mr626
« Reply #1127 on: Tue, 23 July 2013, 21:29:13 »
Crappy photo, sorry.
Nothing fancy, just a set of Vortex PBT. The font grows on you.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1128 on: Tue, 23 July 2013, 21:44:14 »
^looks mighty clean!
Offline TimIsABat
    • Instagram
« Reply #1129 on: Tue, 23 July 2013, 22:21:07 »
simply old
Dude that is beautiful. I really like that retro look you got and the modifiers look crisp with it.
Offline eth0s
  • Peace & Love
« Reply #1130 on: Tue, 23 July 2013, 22:23:44 »
Pokah:
Offline Sai
« Reply #1131 on: Tue, 23 July 2013, 22:25:37 »
i want that candy corn.
Offline Ultratude
    • Ultratude's Blog
« Reply #1132 on: Wed, 24 July 2013, 06:02:26 »
I have one and I want a Topre skull. Do u have one?
« Reply #1133 on: Wed, 24 July 2013, 06:55:24 »
Pokah:
Very nice!!
Is it just me or do all the vader caps that get posted look like the nose is chipped, I'm guessing its just glare.
Offline Sai
« Reply #1134 on: Wed, 24 July 2013, 07:19:42 »
nope. i dont have a topre skull.
Offline Ultratude
    • Ultratude's Blog
« Reply #1135 on: Wed, 24 July 2013, 07:21:44 »
TAT
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #1136 on: Wed, 24 July 2013, 12:08:13 »
every most poker lately is a unicorn or loaded with novelty caps. not a bad thing but i love the simple uniform looks.
my poker hasn't been used in like 2 months though it will get some attention when i get the acrylic case for it, whenever the hell that happens....--i just really hope i don't break any traces when de-soldering off the switches for the third time.
Trick or Treat. My daily driver for October is getting closer.
The case is an acrylic from ALI. The quality seems good I'm quite happy with what I have seen so far. There is no PCB inside so the spacebar may appear a little crooked.
Enjoy,
John
oh man i love it
« Last Edit: Wed, 24 July 2013, 12:10:53 by Glod »
Offline turtle
« Reply #1137 on: Wed, 24 July 2013, 12:21:30 »
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1138 on: Wed, 24 July 2013, 12:21:55 »
^looks dope
Offline Dubsgalore
« Reply #1139 on: Wed, 24 July 2013, 12:27:31 »
you-you-you-you-you got a pm
« Reply #1140 on: Wed, 24 July 2013, 12:31:15 »
Offline pixel5
    • pixel5
« Reply #1141 on: Fri, 26 July 2013, 17:15:44 »
Just got it today. Thanks i3oilermaker for the awesome promotion and bonus keycaps!
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #1142 on: Fri, 26 July 2013, 17:18:14 »
Wait, that's the metallic set?  That looks like an older white Poker cap set.  I thought those were long out of stock.
Offline pixel5
    • pixel5
« Reply #1143 on: Fri, 26 July 2013, 17:18:57 »
Yeah, it's pretty hard to capture the color correctly. They aren't really metallic, just gray.
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #1144 on: Fri, 26 July 2013, 17:27:00 »
They look creamy white on the photo o.o  Which is why I asked.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #1145 on: Fri, 26 July 2013, 17:40:57 »
I would disagree...If you look at them compared to a regular grey cap they have more luster, and the also have some swirling effect
Offline PointyFox
« Reply #1146 on: Fri, 26 July 2013, 18:15:36 »
Got my Poker II from i3oilermaker!
First impressions:
*These mx reds are scratchy!
*DIP switch is a little off-center.
*These mx reds are almost as heavy as the mx blacks in my Filco! (That's a good thing).
*My custom cable is broken. :(
*OMG why is the right side of the space bar flashing?
*Oh, it was in programming mode.
*Wow, there are some really nice features programmed in!
*I love the program layers on this; selling Filco!
*Board is heavy and doesn't rock or flex!
*How do I mod it? :O
« Last Edit: Fri, 26 July 2013, 18:17:22 by PointyFox »
Offline Latin00032
« Reply #1147 on: Fri, 26 July 2013, 21:05:53 »
First impressions:
Scratchy? Is it that noticeable?
That doesn't sound right.
« Reply #1148 on: Fri, 26 July 2013, 21:14:29 »
Some Cherry switch batches are very scratchy brand new--I've experienced a few keyboards like that.
Offline PointyFox
« Reply #1149 on: Fri, 26 July 2013, 21:44:52 »
They do smooth out with use, so I don't really mind.
