Author Topic: Post your Poker!  (Read 1347488 times)
Offline Goodfella
Re: Post your Poker!
« Reply #1050 on: Sun, 30 June 2013, 09:20:15 »
Here is my Poker2, I wanted an ali case but it's just too much a stretch for me, so I decided to modify the plastic case. The bottom is vinyl dyed white, I would like to paint the edge of the circuit board black too. Hope to add some leds (and keycaps!) in the future :)
Any more shots of your desk and the rest of the setup? The stands you made up for the base of that Dell monitor looks pretty clean, I bet the rest of the desk looks pretty amazing!
QFR | QFR | QFR | Pure LED
Offline dave23
« Reply #1051 on: Sun, 30 June 2013, 11:55:19 »
Thanks man :) I posted a reply to the desk setup up thread here with a link to an imgur folder with some pics. Can you guess what the Dell stand is made from ?  :)
Offline Goodfella
« Reply #1052 on: Mon, 01 July 2013, 09:15:40 »
Ha! That is awesome! Really such a clean little addition. Where did you buy the colors etc that you needed to make those from?
Offline dave23
« Reply #1053 on: Mon, 01 July 2013, 12:44:54 »
Each block is 6 x 10 lego units, I already had the 6x10x1 grey bases (two of these per block) in my loft. The white blocks I bought from this ebay listing (6 of these per level), but the blocks around the back that you can't see are older ones from my loft stash. The Flat tiles on the top of each block are from this ebay listing, 15 of these per block (the block at the back has flat tiles I already had).
Regarding the grey colour, I've done some quick googling before just announcing they are just grey  :D The 6x10x1 panels are original Lego grey, but apparently Lego changed their grey colours to a more bluish grey in 2004, and Lego aficionados called this bley lol The blank tiles (part number 3068) I have are Medium Stone Grey (Lego colour ID 194), aka light bluish grey / light bley.
The 6x10x1 plate part number is 3033, and the iconic 2x4 brick is 3001.
My 24" Dell monitor is therefore sitting on 6 3033's, 45 3068's, and 90 3001's :D
More info than you probably wanted lol
Offline POFFINGTON
  • Ninja keys...everytime
    • Polycount
« Reply #1054 on: Thu, 04 July 2013, 20:05:33 »
Got bored. Put my Ducky gold ninja keys on my poker. Might stay like this for a while until I mod the key switches.
Keycool 84 (Browns) | Ducky DK9008G2 Pro (Hybrid) | KBC Poker (Black)
Offline Neal
  • Skype: iNewbcake
« Reply #1055 on: Sat, 06 July 2013, 01:31:01 »
Potato phone pic of my Poker.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #1056 on: Sat, 06 July 2013, 02:18:57 »
Seriously need to get my hands on those poker modifiers
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1057 on: Sat, 06 July 2013, 04:03:55 »
I just jizzed
Offline KaLam1ty
« Reply #1058 on: Sun, 07 July 2013, 01:54:24 »
Some pretty terrible phone pics. Sorry about the lighting  :-[.
Offline Rule16
  • R.I.P. SmallFry
« Reply #1059 on: Sun, 07 July 2013, 02:21:56 »
That looks amazing! I'm assuming you got those caps made by wasd?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline BlueBär
« Reply #1060 on: Sun, 07 July 2013, 04:21:02 »
Beautiful! The lasering could be a bit more even but that looks very nice.
Offline badcop
  • thorpe thocking master race
« Reply #1061 on: Sun, 07 July 2013, 06:51:49 »
that is a really cool idea
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1062 on: Sun, 07 July 2013, 10:57:50 »
Really awesome! Is it a WASD work?
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline megaxpop
« Reply #1063 on: Sun, 07 July 2013, 11:33:17 »
So cool, i have some idear for my keyboard
Offline KaLam1ty
« Reply #1064 on: Sun, 07 July 2013, 12:52:55 »
Thanks guys!
Those caps are, indeed, a WASD etched set.
Some areas are a bit uneven but I don't think the etching process was ever made to do solid colors like this anyway. They look a lot better in person too.
« Last Edit: Sun, 07 July 2013, 12:55:01 by KaLam1ty »
Offline Photoelectric
« Reply #1065 on: Sun, 07 July 2013, 13:09:42 »
That is such a cool idea!  Minimalistic and very tasteful.
Offline YongJK
« Reply #1066 on: Sun, 07 July 2013, 16:15:06 »
self tuned poker2.
62g mx red, fully lubed & stickered
Heh, nothings could compared to vintage black  :mad:
Thought I could create something like France flag but the it seems the colors are not matching
Keyboard: PLU ML87 Mx Blue
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1067 on: Sun, 07 July 2013, 16:36:10 »
What's the difference between MX blacks and those vintage blacks?  :-X
« Reply #1068 on: Sun, 07 July 2013, 16:44:04 »
Vintage blacks were made of different material, supposedly, so they feel smoother (low friction) vs. modern black.  The spring is also VERY slightly lighter.  Smoothness is not something you can fix with lubrication--it only helps a little.  To get smooth switches, you need to use them a lot or get lucky and start out with a good smooth batch.  Vintage blacks happen to start off with low friction.
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1069 on: Sun, 07 July 2013, 16:47:13 »
Thanks for explaining. Is there a spring that feels almost the same as the vintage?
« Reply #1070 on: Sun, 07 July 2013, 16:48:17 »
The difference is quite small.  Something like a 67-68g Korean spring maybe--just a guess.
Offline YongJK
« Reply #1071 on: Sun, 07 July 2013, 17:10:39 »
Spring doesn't matter.
What matter the most is how much the friction it is.
Well, vintage black basically you can almost feel no friction at all.
Unlike the modern black, red as well.
« Reply #1072 on: Sun, 07 July 2013, 17:24:53 »
In contrast to what has been said in the thread, some people also feel that vintage blacks are just more broken in, so the differences you see are the result of age and wear.
« Reply #1073 on: Sun, 07 July 2013, 17:27:14 »
How about vintage Blacks that come directly from brand new "old stock" of keyboards, like Wyse terminal keyboards.  Those have not been used.
Offline PointyFox
« Reply #1074 on: Sun, 07 July 2013, 17:32:00 »
New MX black switches begin to feel like vintage MX blacks after using them a lot.  They get smoother with use.  My W, A, S, D keys feel very similar to vintage blacks, though keys I don't use often feel rough.
Offline TimIsABat
    • Instagram
« Reply #1075 on: Sun, 07 July 2013, 18:03:16 »
Tempted to ditch my black blank PBT caps for this
Offline Potologue
« Reply #1076 on: Sun, 07 July 2013, 20:06:53 »
That's really cool.
Offline Latin00032
« Reply #1077 on: Sun, 07 July 2013, 20:14:09 »
That's really cool.
That's the sex.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #1078 on: Mon, 08 July 2013, 05:42:27 »
Those looks sick !  ;D
Here's my Poker II.
Nothing much has been added yet, just raindrop and some random keys.
Finally received the spacebar without those hideous words  :p
Will try and mix and match later.  ;D
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1079 on: Mon, 08 July 2013, 05:47:21 »
Here's my Poker II.
That looks a bit weird. You have your controls as blue when they should be red on a typical RGB setup, the spacebar should be white and so should the |\ key......
Just looks odd, but to each is own
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #1080 on: Mon, 08 July 2013, 05:52:58 »
Here's my Poker II.
:x still trying to mix and match around.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1081 on: Mon, 08 July 2013, 19:20:44 »
Here's my Poker II.
If you like it then that's all that matters. Don't worry about how it "should" be, because its your keyboard and not anyone else's.
« Reply #1082 on: Mon, 08 July 2013, 20:13:11 »
My QFR is a testament to that.
« Reply #1083 on: Mon, 08 July 2013, 20:24:09 »
Your QFR looks fine, sir!
Offline YongJK
« Reply #1084 on: Tue, 09 July 2013, 14:01:19 »
Using thin abs to snap photo is back idea back then.
Stock PBT ftw.
Offline evolyn
« Reply #1085 on: Tue, 09 July 2013, 14:34:01 »
hey is someone selling a poker with case with stickers and lube ? write me
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1086 on: Tue, 09 July 2013, 15:47:26 »
For now this is my only keyboard. I put the QFR caps to don't spoil the originals.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1087 on: Tue, 09 July 2013, 19:16:21 »
Stock PBT ftw.
Nice! LEds are cool. Is there a resource or guide anywhere on how to install them?
Here's how my poker 2 looks now, I vinyl dyed the spacebar charcoal grey, which looks more black actually, and burgundy on the mods. I mighttt paint the rest of the keys charcoal grey, but I'm not sure yet. I'll stick with this for awhile to see how it goes.
The tab is kind of dirty, but I cleaned it already, don't worry :p
Enjoy
« Reply #1088 on: Tue, 09 July 2013, 19:19:25 »
Stock PBT ftw.
Enjoy
I really like how that turned out.  That burgundy looks fantastic.  Then again, I've been wanting a burgundy/maroon and white set for a while now.  Just for symmetry's sake, I wish the "|\" key was that burgundy color too.  And it reminds me that I shoud probably swap the SP BoW caps onto my QFR so I don't have a mix of blank and legended caps.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1089 on: Tue, 09 July 2013, 19:22:44 »
Stock PBT ftw.
Enjoy
Thanks. Is there a standard on the \| and `~ keys? I often see them colored the same as alphas, so that's why I did it like this. But I guess its all preference isnt it?
You should really check out vinyl dye if you like blank caps. It retains the texture pretty nicely, way better than spray paint imo, and no other prep is necessary. Its quite awesome.
Offline jcrouse
« Reply #1090 on: Tue, 09 July 2013, 19:26:08 »
Trick or Treat. My daily driver for October is getting closer.
The case is an acrylic from ALI. The quality seems good I'm quite happy with what I have seen so far. There is no PCB inside so the spacebar may appear a little crooked.
27681-0
27683-1
Enjoy,
John
« Last Edit: Tue, 09 July 2013, 19:36:18 by jcrouse »
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1091 on: Tue, 09 July 2013, 19:31:25 »
The case is an acrylic from ALI. The quality seems good I'm quite happy with what I have seen so far. There is on PCB inside so the spacebar may appear a little crooked.
Enjoy,
John
That looks awesome. Nice skull! Is it just me or is your spacebar tilted to the right?
« Reply #1092 on: Tue, 09 July 2013, 19:36:41 »
Some sets match them to the Alphas, some to the mods.  I prefer them matched to the mods, same with the "~`" key.
Offline Jocelyn
  • 조셀린
« Reply #1093 on: Tue, 09 July 2013, 19:41:12 »
Enjoy,
John
I love it, but THAT Tab key :(
Talking about how the arrows are too high and the bottom one is centered on the word Tab instead of evenly spaced?
Yes, but I don't want jcrouse to think I'm bashing his board/caps. It's something Sherry and/or GMK did wrong and I think jcrouse's board looks lovely despite this :)
« Last Edit: Tue, 09 July 2013, 19:50:21 by Jocelyn »
« Reply #1094 on: Tue, 09 July 2013, 19:43:32 »
Offline Thimplum
  • Master of all Ponies
« Reply #1095 on: Tue, 09 July 2013, 20:17:41 »
Stock PBT ftw.
WOW. Those LEDs are stunning.
TP4 FOR ADMIN 2013
Offline KaLam1ty
« Reply #1096 on: Tue, 09 July 2013, 20:43:07 »
Enjoy
You should totally paint the rest of those keys! The uniformity will make it look so much better imo. The colors are fantastic too!
Offline pmh1410
« Reply #1097 on: Wed, 10 July 2013, 05:11:26 »
Enjoy,
John
Hi John, Very nice Orange acrylic case with Jack O' lantern MX Skull :P
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #1098 on: Wed, 10 July 2013, 05:17:09 »
Enjoy,
John
That looks awesome, nice work.
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #1099 on: Wed, 10 July 2013, 13:13:17 »
Enjoy,
John
nice acrylic case !! , with the cc inside  ;)
