Author Topic: Post your Poker!  (Read 1317832 times)
Offline rurushu
Re: Post your Poker!
« Reply #1150 on: Fri, 26 July 2013, 23:59:17 »
They do smooth out with use, so I don't really mind.
oh... meaning have to let it break in?
Offline PointyFox
« Reply #1151 on: Sat, 27 July 2013, 00:13:59 »
Yeah, they will smooth out eventually.
Offline PointyFox
« Reply #1152 on: Sat, 27 July 2013, 02:34:11 »
I want to turn my Poker's case white.  What is the best way to do that?
Offline tmk1207
  • Yêu Màu Tím
    • Vietnam Mechanical Keyboard Club <3
« Reply #1153 on: Sat, 27 July 2013, 02:49:59 »
:D
« Reply #1154 on: Sat, 27 July 2013, 03:37:52 »
:D
Those couple of pink caps really make the board - nice :)
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1155 on: Sat, 27 July 2013, 04:10:12 »
I can't stop changing the way my Poker looks.. I change it like every two weeks. -__-
DSA caps from SP
« Last Edit: Sat, 27 July 2013, 04:12:14 by kenmai9 »
Offline jil_jil32
  • Tokyo Press <3
« Reply #1156 on: Sat, 27 July 2013, 05:03:59 »
Bleu...
« Reply #1157 on: Sat, 27 July 2013, 08:29:08 »
29566-0
29568-1
29570-2
Offline rurushu
« Reply #1158 on: Sat, 27 July 2013, 11:12:02 »
that dark blue modifiers... they're so nice!!! care to tell where they're from??? i mean, from what groupbuy or what set?
Offline Photoelectric
« Reply #1159 on: Sat, 27 July 2013, 11:13:09 »
Those are purple with white (cream?) fonts double-shot modifiers from a recent group buy, which is closed and sold out.  You can try the Classifieds.
Offline rurushu
« Reply #1160 on: Sat, 27 July 2013, 11:16:10 »
those are the GMK purples???? I dont think so... unless the color is really that hard to capture.... or are you indicating another set?
Offline codyeatworld
« Reply #1161 on: Sat, 27 July 2013, 11:19:07 »
Those are the purple GMK modifiers.
« Reply #1162 on: Sat, 27 July 2013, 11:20:32 »
^^ just sucky phone camera and horrible office lighting....and it's raining outside  :-[
Offline rurushu
« Reply #1163 on: Sat, 27 July 2013, 11:23:54 »
wow... didnt know that camera quality and lighting would be such huge changer.....
from the pics alone, it looked like those keycaps from vintage type writer machine...
« Reply #1164 on: Sat, 27 July 2013, 11:31:12 »
here is the original image and another shot with same phone, this is why keys always look nicer in person haha  ;)
29600-0
29602-1
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1165 on: Sat, 27 July 2013, 14:26:37 »
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline le_doosh
« Reply #1166 on: Sat, 27 July 2013, 14:35:13 »
I think you need to get your monitor calibrated or your eyes checked out
« Reply #1167 on: Sat, 27 July 2013, 14:54:01 »
No, they do look mostly blue on the first set of photos he asked about.  Except for the Alt modifiers.  More purple on later photos.
« Reply #1168 on: Sat, 27 July 2013, 14:58:29 »
Bleu...
That is BEAUTIFUL jil. Really, I think that's one of the nicest and most minimalist colour schemes I've ever seen.
Offline JonasDK
  • Let me poo on you
« Reply #1169 on: Sat, 27 July 2013, 17:35:14 »
Added some leds to my Poker II over the weekends.
Just playing around with colours  :D
With the ducky keycaps.
End product.
Took me sometime to desolder the solder of the pcb. very tedious job indeed.  :(
But it's worth it. :D loving my poker II
Holy mother of sweet jebus. That looks cool. But i thought you could just click in the LED in the Poker 2?
Offline KaLam1ty
« Reply #1170 on: Sun, 28 July 2013, 01:54:34 »
End product.
The Poker 2 has the LED holes soldered closed for some reason; so you need to desolder and clean them first.
Then you can just drop them into place and resolder it.
It's not difficult, albeit pretty tedious like any deck soldering job.
« Last Edit: Sun, 28 July 2013, 01:56:15 by KaLam1ty »
Offline PointyFox
« Reply #1171 on: Sun, 28 July 2013, 02:18:58 »
End product.
Guess they wave soldered the boards.  I'll probably get a vacuum desolderer to do it :P
Offline JonasDK
  • Let me poo on you
« Reply #1172 on: Sun, 28 July 2013, 10:10:10 »
You make it sound easy. I wish there where more information on the process.
Offline BlueBär
« Reply #1173 on: Sun, 28 July 2013, 10:36:35 »
But it is pretty easy:
1. Put soldering iron on soldered holes
2. Wait for it to melt
3. Trigger solder pump
4. ???
5. Profit!!!
See an example:
« Last Edit: Sun, 28 July 2013, 10:38:13 by BlueBär »
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #1174 on: Sun, 28 July 2013, 11:19:23 »
With the right tools...
...there isn't much to explain!
EDIT: BlueBär was faster :3
A Ghost From The Past
Offline KaLam1ty
« Reply #1175 on: Sun, 28 July 2013, 13:00:25 »
This is surprisingly mesmerizing for some odd reason  :)).
Offline JonasDK
  • Let me poo on you
« Reply #1176 on: Sun, 28 July 2013, 13:08:01 »
4. ???
5. Profit!!!
See an example:
I was speaking of the process of disassembly and where to desolder, not how you do it ;D
Offline BlueBär
« Reply #1177 on: Sun, 28 July 2013, 13:16:09 »
That's even easier. Remove all keycaps, you will see the screws. Unscrew them. Disassembly done.
To find the correct holes, if you look on the switches, there is this a cutout where a LED can fit in. Here's a picture, red are the connectors for the switch itself which you should not desolder, blue are the connector holes for the LED. Switch picture stolen from Thechemist, markings by me.
29722-0
Edit: found a good picture by WhiteFireDragon, heres a good view from the PCB, again do not desolder red, desolder the blue holes.
29724-1
« Last Edit: Sun, 28 July 2013, 13:20:42 by BlueBär »
Offline PointyFox
« Reply #1178 on: Sun, 28 July 2013, 13:48:17 »
Is the square hole or the circular positive?
Offline BlueBär
« Reply #1179 on: Sun, 28 July 2013, 14:00:50 »
Square is usually positive.
Offline Michael
  • Formerly Bro Caps
« Reply #1180 on: Sun, 28 July 2013, 14:04:29 »
I had the Hakko 808. It was amazing. The one in that GIF looks like
http://www.hakko.com/english/products/hakko_fm204.html
  • ~ BOOO ~
« Reply #1181 on: Sun, 28 July 2013, 14:24:41 »
Correct, generated this GIF from Hakko's 204 commercial found on YT...
Looking for a 808 myself, but I need the 220-240V version which is much harder to find :(
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #1182 on: Sun, 28 July 2013, 15:49:50 »
Bleu...
This is quite refreshing
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
« Reply #1183 on: Sun, 28 July 2013, 16:22:58 »
ghetto
29728-0
29730-1
29734-3
29736-4
29738-5
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #1186 on: Mon, 29 July 2013, 06:53:06 »
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Offline wilksMJP
« Reply #1189 on: Mon, 29 July 2013, 18:36:33 »
Just got my poker II!!
29812-0
29814-1
Offline TimIsABat
    • Instagram
« Reply #1190 on: Mon, 29 July 2013, 19:17:42 »
Waaaah I want those blank modifiers for my Poker X... :(
« Reply #1191 on: Mon, 29 July 2013, 21:18:47 »
Offline TimIsABat
    • Instagram
« Reply #1192 on: Mon, 29 July 2013, 21:45:46 »
How bad?
Bad enough to pay a reasonable price for them
Offline pixel5
    • pixel5
« Reply #1193 on: Mon, 29 July 2013, 21:49:40 »
$500 final offer. Mine have never been opened. TAKE IT OR LEAVE IT.
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #1194 on: Mon, 29 July 2013, 23:41:56 »
How bad?
Shoot me a PM, I'm never going to use them ;)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #1195 on: Mon, 29 July 2013, 23:43:50 »
Shabam!
« Reply #1196 on: Mon, 29 July 2013, 23:46:02 »
Shabam!
I kept thinking who needs a shiny space bar, but that thing is hot!
Offline UniClown
« Reply #1197 on: Tue, 30 July 2013, 00:16:13 »
Shabam!
Where are these caps from? I like that shade of blue.
Offline rurushu
« Reply #1198 on: Tue, 30 July 2013, 00:45:35 »
Shabam!
the alphas... they looked like from graphite set...
Offline evolveS
  • ಠ_ಠ
« Reply #1199 on: Tue, 30 July 2013, 00:48:09 »
That is indeed the graphite set, it seems to look different shades of grey/blue in every photo (I'm typing this reply on the set btw, on a Poker nonetheless!)
"money comes and goes, but doubleshots are forever"
-a petty thief
