Author Topic: Need something like a Model-M, but not  (Read 1687 times)
Offline Rootus
« on: Tue, 04 September 2012, 13:36:55 »
My current situation:
I have a Unicomp buckling spring keyboard at home.  I love the feel, I type well on it, everything about it is great except the noise.  Not a big deal at home, though.
At work I have a Filco tenkeyless.  Not too loud, but I type like crap on it.  Lots of errors from missing the key slightly and catching a bit of the next key.
What I want is a keyboard at work that is as close to possible to the Unicomp I have at home, but not nearly as noisy.  I don't mind the feel of the keys on the Filco, it's really just something about the spacing/shape/etc of the keys that makes it very error prone for me.  I've thought about getting a Unicomp for work that uses the squishy switches, but I'm wondering if there isn't something a little better, maintaining the same design and still having decent mechanical switches.
Recommendations?  Anybody else experience this situation?  Everybody seems to love the Filco, but I really don't care for it at all.  Makes me a bit stabby after a long day fighting it.
Offline swagpiratex
Re: Need something like a Model-M, but not
« Reply #1 on: Tue, 04 September 2012, 13:40:56 »
I think the closest thing would be o-ringed blues. Try and see if you can find someone with a setup close to what you're looking for and check it out.
Sent from my HTC Sensation
Offline jkercado
  • Green XM clickclacker
« Reply #2 on: Tue, 04 September 2012, 13:42:09 »
All I can think of is the floss mod. Basically you can buy some of that Oral-B weird dental floss that has a sponge-like part. Cut a tiny piece and stuff it into each spring. It does mute the sound a lot, but at least in my opinion it also changes the tactile response somewhat.
Give it a spin on a few keys, see if it works!
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Tue, 04 September 2012, 13:48:34 »
What type of MX switches on the Filco? Blues? How long have you used it for?
If you want stiff, tactile, and to not accidentally press other keys I'd look at trying out some ALPS.
« Reply #4 on: Tue, 04 September 2012, 13:53:16 »
I totally recommend the floss mod. Too bad the wikis are all gone, it is easy enough to do when the keyboard is apart and the springs are loose, it is probably a lot harder to do with springs in place, but not impossible. Be careful not to fray the ends, after a couple of tries it will be fluffed out to the point where you will never get it in.
The change to the feel is minimal, but the noise reduction is great, because what it takes out are the ringing overtones that carry so far. I have used them for quite a while and have come to hear the "stock" Model M/F sound as harsh.
Also, get some rubber "drawer liner" material and cut a pad to go under the board. That deadens the sound somewhat, plus it keeps the board from moving around.
That same morning, the Financial Times revealed that for the past three years Russia has been helping Iran build a supersonic cruise missile capable of blowing our ships out of the water, and at an Iran/Russia/China summit with Iran’s president, Putin, and Xi in Bishek this week, Putin said he’ll continue to supply Iran with “the necessary goods” that can be used to kill Americans.
